| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Wheel and tire size fitment question before I pull the trigger
I’m interested in a set of 18x9.5 +45 with 245/35/18 tires. Will these fit on my BRZ with 1.5” lowered without any issues? Will the alignment specs fall at least close to the factory numbers without any alignment tools?
#2 |
Only happy when it rains.
Drives: series.blue
which wheels, which tires, how did you lower the car?
#3 |
Volk TE37SL on mechelin pss tires. Lowered on Apexi coilovers
#4 |
Drives: 2013 Subaru BRZ Premium
Talking completely off the top of my head but I'm around 80% sure you'll have issues in the front with rubbing. If you don't it will be by a hair's breadth.
Sent from my XT1650 using Tapatalk |
#6 |
Country Boy 4 Life
If this is what you want, then you can make them fit. And, depending on alignment and drop you may need a few other suspension parts like LCA, adjustable toe, end links etc. But, with your wheel and tire choices, Budget is probably not a serious issue.
I LIKE TIRES! |
#7 |
It wouldn't fit on stock diameter springs, but I think it'll clear on coilovers. Might rub at full lock on either the LCA or inner fender liner up front though.
#8 |
Drives: 2017 series yellow BRZ
i dont think he will rub im running 255/35 and 18x9.5 +38 no rubbing issues and im dropped quite a bit.
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
#9 | |
#10 |
Drives: Crapcan
I rub the fender liner with 245/40/17 on 17X9 +38. Also looks it touches the sway bar at full lock a little. I am almost -1.75 dropped over stock with -3 camber.
#11 | |
The potential places it'll rub are inside the wheel well, either the LCA, sway bar or inner fender liner. Your wheels are 7mm further outboard because of the lower offset.
#12 |
Drives: 2014 Scion FRS (Asphalt)
Rear camber will be off without lcas.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#13 |
your also running a 9 inch wheel so a 38 offset on a 9 inch is not the same as a 9.5 +38
My BRZ Build Thread
#14 |
correct but a 245/35 is a very conservative option and i know plenty of people running 45 offset with 245/35 no issues at all. I was originally getting wheels that was 9.5 +45 but wouldnt fit over my brakes. I dont think he will run into any rubbing issues and i would hit the fender liner before him but sway could be in question. if has adjustable swaybar endlinks he can manipulate the sway bar some in his favor.
My BRZ Build Thread
| quick question 18x9.5+38 fitment/tire size | BlaqkHavok | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 06-18-2018 09:41 AM |
| Fitment questions before I pull the trigger | Jonnyfkncoolguy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 02-15-2018 08:22 PM |
| Enkei T6S wheel and tire fitment question | chenshuo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-30-2014 09:25 PM |
| Help about to pull the trigger.... | JerryMichaels7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-25-2014 06:12 PM |
| About to pull the trigger on Perrin.... | FRSFirestorm | Engine, Exhaust, Transmission | 143 | 05-04-2013 01:25 AM |
