Old 06-18-2018, 07:58 PM   #1
Antonovich
Drives: '13 BRZ, 04 rust bucket Suburban
Advice on wheel repair then Plasti Dip
I have a set of black Enkei TS10's. I have curb rash on one of the rims, and small but noticeable gouges on 2 other rims (shitty NYC roads). Sorry no pics, but the damage is not bad. The wheels are not bent. What I'm thinking of doing is cleaning the wheels properly, sanding the gouges, using bondo filler on the curb rash and gouges, sanding it again, cleaning all the wheels again, and lastly Plasti Dipping them 4 coats of standard black + 4 coats of turquoise silver (I'm bored of the black wheels).
I've seen posts where people had stock rims and used a primer after the bondo / sanding, but I don't even know where to start with a primer. Which one? Would it really make a difference when I'm gonna PlastiDip the wheels anyway?
So, any advice?
Antonovich is offline   Reply With Quote
Old 06-18-2018, 08:44 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
So, any advice?
You can just keep applying plastidip until it fills the gap if it’s not too bad.
N1rve
Old 06-18-2018, 08:55 PM   #3
Teseo
Drives: frs
Or you can try epoxy, sand then plasti dip
Old 06-18-2018, 10:15 PM   #4
Antonovich
I think bondo would be better for what I'm trying to do. Never worked with either but it seems that bondo would be easier to work with. At least easier to shape.
That might work on the curb rash but the gouges are a bit deeper.
Old 06-18-2018, 10:48 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Make sure you get a primer close to the color you want that will adhere to metal. Do not get some primer+whatever, it's hogwash. Straight up primer. Do 2 thin THIN LAYERS. Then do 6-8 thin thin layers of plastidip. So thin it takes the first 6 layers to really do much. After you a nice base, make your last two coats pretty thick for the best plastidip finish you'll ever see.
Tristor (06-19-2018)
Old 06-18-2018, 11:07 PM   #6
Antonovich
As I've said before, I don't even know where to start with a primer. Does it have to be the same color as the paint color? Do I even need it if I'm gonna plastidip the wheels anyway?
Old 06-18-2018, 11:12 PM   #7
DarkPira7e
DarkPira7e's Avatar
It can be any color, you're going to completely cover it. It's purpose, literally, is to give the paint something to stick to. Like velcro on a microscopic level. If you're painting a dark color, keep the primer darker. Doesn't need to be black, a dark Grey is a great choice. With any paint, plastidip or not, a couple primer layers are a low cost, low effort investment that ensures better results
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Antonovich (06-19-2018), Tristor (06-19-2018)
Old 06-19-2018, 05:23 PM   #8
wparsons
wparsons's Avatar
I'd get proper filler for metal, not bondo, on wheels. Sure bondo is easier to shape, but if the metal was gouged previously the bondo will be damaged way more easily.
flickr
Alignment Repair Advice Target70 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 01-09-2018 06:37 PM
Quoted $750 for a paint chip repair - Need advice James Russels Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 08-24-2017 11:40 PM
Dealer damages car during warranty repair, need advice. rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 01-07-2014 01:04 AM
All in 1 Day - Plasti Dip Emblem & Wheel + Caliper Paint (First timer) Lverasky Cosmetic Modification (Interior/Exterior/Lighting) 26 10-22-2013 04:52 PM
FRS OEM Wheel Mods (Plasti-Dip)? FRSTRM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-18-2013 03:42 AM
