Old 04-13-2017, 04:32 AM   #15
Aboodilatif
Aboodilatif's Avatar
Drives: '14 Red Toyota GT86 RocketBunny
Originally Posted by steve99
You might be lucky and just be able to swap in 2017 dash using the factory procedure but its going to need someone to shell out the dollars to test it and be prepared to loose that money if it doesn't work
Should we start a Kickstarter?
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP
Aboodilatif is offline   Reply With Quote
The Following User Says Thank You to Aboodilatif For This Useful Post:
Cessblood (05-20-2017)
Old 04-12-2018, 01:07 PM   #16
misterfly
Drives: Toyota 86 2017
I got a new 2017 without the special cluster, i want to know if someone have try to swap this cluster to one wihout the g-force screen.
Thanks
misterfly is offline   Reply With Quote
Old 04-17-2018, 06:49 PM   #17
Sc629
Drives: 2017 86 Asphalt
https://www.facebook.com/groups/Kouk...3489870982513/
Interesting development!
Sc629 is offline   Reply With Quote
Old 04-17-2018, 08:33 PM   #18
Tjvghn
Drives: 2014 BRZ - 2001 HD dyna
http://www.ft86club.com/forums/showthread.php?t=126912
Tjvghn is offline   Reply With Quote
Old 06-14-2018, 12:48 AM   #19
kaferjca
Drives: 2017 Toyota 86
At least I know it worked on mine (Base ‘17). I bought the cluster and steering switches new from Toyota. Then recalibrated ecu with Techstream. Also was very $$$
kaferjca is offline   Reply With Quote
Old 06-14-2018, 02:24 AM   #20
Sc629
Could you get me the part # for the steering switches? And do you have techstream or did you have the dealer do it?
Old 06-22-2018, 08:42 PM   #21
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Did you have turn-key start or push-start?
el-guapin is offline   Reply With Quote
Old 09-08-2018, 12:55 AM   #22
kaferjca
P/N SU00307459 the only thing with these switches is that the bezel is black. You have to swap the one you have if you want to stay silver. Also if you have a pre facelift you will need the clockspring from a 17-on. Some Toyota dealers may make an annotation (mileage of the old cluster) on the service book for the cluster swap but you can marry the cluster yourself with techstream. I did it with just 100 miles on the clock.
Old 09-08-2018, 12:56 AM   #23
kaferjca
Turn-key
Old 10-22-2020, 11:42 AM   #24
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
It is working on my '17. Does anyone know if there is a way to get the power screen to actually see the power? I have installed a '17 manual red intake, Nameless header & exhaust, and ECUTEK tune by Zach and there has been no change to the torque dip it displays. The butt dyno says there has been a big change.
e30cabrio is offline   Reply With Quote
Old 10-22-2020, 02:29 PM   #25
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
That display is just a static graphic with an RPM indicator to show you what *should* be happening with a stock engine. You would need to create your own graphic for your particular engine and figure out how to replace the factory graphic. IMO that screen is fairly useless.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
e30cabrio (10-22-2020)
Old 10-22-2020, 07:38 PM   #26
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
It's funny, I was thinking of a sticker on a toy from the 80's of a missile system when I asked the question. Shame I was right.
Thanks
Old 10-22-2020, 08:32 PM   #27
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's definitely just a graph that is measuring nothing, but a display based on your RPM- it's no different than video, you're just progressing and reversing the progress bar using the gas pedal
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 04:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-15-2016 12:32 AM
Gauge cluster with Oil Temp Gauge Jetbill Interior Parts (Incl. Lighting) 1 10-06-2015 02:41 PM
OEM frs cluster gauge Baramzisyan Interior Parts (Incl. Lighting) 0 08-31-2014 03:39 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 03:54 PM
