#15 | |
Drives: FT86
I noticed some weird setting the the maf offset after start tables neutral and in gear on the V4 auto tunes that likely your issue and easy fix also log commanded afr and afr and fuel trims, some simple maf scaling may solve those issues sme cars are a little different. |
#16 |
Drives: 2015 BRZ 6MT
I’ve got the Tomei UEL and Delicious Flex Fuel kit (and tune).
It is really great. After I installed it, they had me take logs, and then continued to send me tune revisions and have me take more logs until everything looked good. It’s quite an improvement over stock
| The Following User Says Thank You to speedybrz For This Useful Post: | SuperTom (06-12-2018) |
#17 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Are you running the correct tune?
With the OFT there are different types depending on the header. Most people run UEL headers so when most people talk about the Stage 2 tune for the OFT they specifically mean for that type of header. You mentioned you are running the EL headers. Last i used OFT there was a specific tune for the EL headers and the UEL headers as they both treat air flow differently. Make sure you arent running the UEL tune by accident.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#18 | |
for OFT tunes there's only difference for cat and catless header tunes (stage 2 for catted headers, stage 2+ for catless headers). if i'm not mistaken there aren't different tunes for UEL and EL. at least not for the off the shelve tunes. |
#19 |
Drives: '13 FRS - STX
OFT V2 tunes had seperate EL/UEL tunes, V4 does not
There's some speculation that V4 is based on UEL and you may be losing out vs. V2 tunes on an EL header. |
#20 |
#21 |
#22 |
#23 |
#25 |
Time to shut down this thread. I just ordered the best NA package available: CSG’s ACE 350 header, flex fuel kit with Delicious stage 2 tune. Now the waiting starts.
#26 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
As long as your expectations are realistic, you should really enjoy that combo. So congratulations, glad you made a decision and in my opinion the correct one. Zach and DT are easy to work with on revisions, and as your car adjust to the new tune, lil tid bits of power will keep being added. Once you have the latest revision from DT running for a few weeks. Go try and drive a stock BRZ again on a test drive or a friends car, or whatever. Then get back in your ACE/DTFF car, and truly appreciate the new power, and throttle response you have added. Good luck to you.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
| The Following User Says Thank You to brzaapi For This Useful Post: | stlgrym3 (06-13-2018) |
#27 | |
Lowly Cartuber
I would agree with the above statment. Make sure your expectations are realistic. Dont expect all of a sudden turbo power. The car WILL be more powerful and deliver power a lot more linear. But it WONT kick you back into your seat when you mash the throttle like a turbo will.
#28 | |
| Change of Plans Sale, All New, unused. JDL Header, FP, OP/Moto-East Flex Fuel/PLX | Rosaki | Engine, Exhaust, Bolt-Ons | 16 | 03-15-2017 12:46 AM |
| My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune | tomaszjanczak | Engine, Exhaust, Transmission | 15 | 09-25-2016 11:06 PM |
| tomei UEL header BERK catted front pipe greddy intake tuned on ECUTEK | mokinbird87 | Software Tuning | 11 | 01-16-2015 05:21 PM |
| FA20CLUB Tuned Flex Fuel Kit N/A FR-S 204whp 156tq | Andy@FA20Club | Engine, Exhaust, Transmission | 31 | 10-16-2013 09:42 AM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
