#29 | |
The Dictater
Drives: '13 Red Scion FRS
Not going to try and guess gains, especially since it's 1:45 am here and waaaaay past my bedtime lol. I'll get you real math-like numbers later. |
#30 | |
Drives: Crapcan
![]() You should try a salt slab instead. |
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Sapphireho (06-05-2018) |
#31 |
Famous Potatoes
Drives: '15 ultramarine
#32 |
Drives: Crapcan
#33 |
Because compromise ฎ
Drives: Red Herring
Don't forget the oil.
#34 |
Drives: UK GT86
Has the crank pulley not changed for the MY17? If so, does Fluidampr have one for the facelift cars?
.: Stealth 86 :.
#35 |
Drives: 2014 GT86
Haven't heard of crank pulley being among changes. 99% sure that old pulley will still fit. ATIs one seems more interesting to me though, as it's also underdriving/smaller diameter. So less power spent on turning accessories, yet more dampening then solid lightweight alu ones.
#36 |
Drives: '15 BRZ RA
For underdriving the peripherals (e.g., alternator, water pump) you need larger diameter pulleys, not smaller ones.
#37 |
Drives: 2017 86 860 Special Edition
Inb4 math and physics can’t accurately model real life.
#38 |
Drives: frs
This is incorrect. The crank pulley being smaller means the other components spin at lesser RPM compared to engine rpm.
| The Following 3 Users Say Thank You to twag4 For This Useful Post: |
#39 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following User Says Thank You to weederr33 For This Useful Post: | chaoskaze (06-06-2018) |
#40 |
I consider the fluidampr to be a preventivive mod, like oil cooler, baffle plate, fuel door etc.
#41 |
Drives: '15 BRZ RA
This is not how you do it. You keep the crank pulley same size and change the size of the other pulleys. You want different underdrive ratios per component. You might also need to not underdrive certain components. For example, I underdrive the alternator and not the water/coolant pump. You also need larger pulleys and not smaller. Let's not misinform people.
#42 |
| Tags |
| carbon fiber, driveshaft, dss, fluidampr, pulley |
| Fluidampr Damper Pulley 571101 Sale!! | Mike@CZP | Engine, Exhaust, Bolt-Ons | 156 | 06-01-2018 01:24 PM |
| Lightweight crank pulley vs OEM vs Fluidampr by MotoIQ | CSG Mike | Engine, Exhaust, Transmission | 49 | 11-20-2015 12:35 AM |
| Fluidampr Crank Pulley + NonStopTuning Accessory Pulleys | Group Buy Offer | NonStopTuning | Groupbuys | 6 | 11-07-2015 08:51 PM |
