Old 06-04-2018, 12:28 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, what might be cause for some slight gear grinding sound somewhere from transmission direction whenever car hops/is shaken going over bad roads/bumps? (no matter if in gear or not and what state clutch)? Mounts? Or some gearbox bearings?
Old 06-04-2018, 12:30 AM   #16
Originally Posted by jfarkas View Post
Definitely fair to say I hoon it on the weekends, rarely on launches that would get all wheel-hoppy but rowing between 3, 4 and 5 on backroads for sure. And yeah it definitely follows RPM. Tech I talked to agreed probably input shaft, but service advisor wasn't buying it for whatever reason that day.
How much did you end up paying for another transmission vs how much should I expect to pay for input or mid-shaft bearing replacement? I know the part is only about 100 dollars.
I'll have to refer you to @Ultramaroon for that question …….. he's the expert on tearing up ….. errrrr ….. I mean repairing transmissions in these cars......
I reckon if it were me, I would buy a new transmission, clutch, pressure plate and TOB and have those parts installed by a transmission shop.
Oh, Bubba just spoke up and said he would get another transmission, clutch & pressure plate out of a wrecking yard install them along with a new TOB …….
Old 06-04-2018, 01:30 AM   #17
Bah! I still haven't opened mine. I'll get there eventually. OP's video clip doesn't sound horrible but the real sign is in how much noise it makes under torque. I've been driving with my beater second transmission for about a year now and as bad as it immediately sounded to me, it hasn't gotten any worse.
I'll post a clip of mine for comparison this week. Driving home from NorCal tomorrow morning.
Old 06-04-2018, 01:58 AM   #18
jfarkas
Drives: 2014 FR-S
Whoops definitely meant to reply to @Ultramaroon, @humfrz lol, was rushing cuz work. But thank you both for the replies, will see what happens in the next couple weeks on my next dealer trip. Best case, warranty happens and stuff gets replaced. regardless which part's bad, probably gonna just shell out the dough to replace the other part while they have the tranny dropped. Preventative measures can't hurt if i'm gonna drive like its meant to be driven, plus power mods and tune in future.
jfarkas is offline   Reply With Quote
Old 06-04-2018, 02:10 AM   #19
Have a safe trip ……
Old 06-04-2018, 02:29 AM   #20
Well, jfarkas, I reckon you found out the MT in the twins is not a Muncie (M22) transmission that could be found in your father's racing cars.
However, my contention is that if you "treat er right", the MT in the twins will serve it's purpose.
Old 06-07-2018, 07:59 PM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
mine is year 13 with 23K mileage only and have same sound as OP. i heard our TOB is spinning even clutch is not engaged so i am not sure this is normal or not. hope others can test theirs and post here with year + mileage to see.
i am also thinking it is Input shaft spinning in the transmission as some others are saying though.
everything works perfectly so
if it is indeed TOB, then i will just upgrade my clutch with new TOB While it's there.
Old 06-07-2018, 11:43 PM   #22
jfarkas
Drives: 2014 FR-S
Check out my reply on this other post from earlier http://www.ft86club.com/forums/showt...=128124&page=3
TL;DR, went to dealership for HPFP replacement as well as similar noise. They concluded its just gear rollover/regular old tranny noise. 86's have little in the way of noise insulation so you hear more weird noises than in regular cars. Your experience may vary though, as i'm no expert; just relaying on what the Toyota tech relayed to me.
Old 06-08-2018, 03:12 AM   #23
My 2013 FR-S (MT) has about 20,000 miles on it.
I don't hear any gear rollover or TOB sounds or any other unusual sounds coming from the clutch/transmission.
Now, since I don't hear and transmission sounds, one or more of the following could be working here:
* since I'm half deaf, maybe I'm just not hearing any sounds.
* maybe the clutch and transmission in my car is just very quiet.
* maybe it's making sounds and I just figure that's the way it is supposed to be.
Old 06-08-2018, 05:31 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
humfrz: have you visited metal band concerts too much, when you were of middle age 30 years ago for hearing to go bad?
Hmm. Or it was Tcoat the twins patriarch?
Old 06-08-2018, 01:06 PM   #25
I think it was ol @Tcoat that was into heavy metal band concerts.
I was into "heavy metal" of a different kind ……. maybe even louder ……
Old 06-08-2018, 01:14 PM   #26
churchx
churchx's Avatar
Drives: 2014 GT86
Aye, that's [x] heavy metal & [x] even louder.
Hearing loss lets save lot of weight & bucks on now redundant exhaust
Old 06-08-2018, 01:17 PM   #27
Hum you need to stop with the weird dots that won't let me quote you!
I had the heavy metal trifecta:
Old 06-08-2018, 01:24 PM   #28
Well now, those should have "fixed" your hearing fer sure.
OK, no weird dots, see if you can quote this?
[EDIT: RESOLVED] Identify this washer from transmission? switchlanez Engine, Exhaust, Transmission 11 12-30-2015 04:56 PM
Transmission Grinding and fuel pump noises FRSChris13 Issues | Warranty | Recalls / TSB 14 09-15-2014 05:23 PM
Problem on making a decision (Poll Begin) impossible BRZ First-Gen (2012+) — General Topics 24 08-05-2014 08:37 AM
Transmission Problem! johnnylai Issues | Warranty | Recalls / TSB 6 02-07-2014 02:54 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
