go_a_way1
Old 05-24-2018, 05:54 PM   #4551
CSG Mike
CSG Mike's Avatar
Originally Posted by 86_Life View Post
Got a question for California tuners with this kit who also have the Factory Tuned version for CARB reasons. Is it possible to add an E85 tune to the kit and also keep it CARB legal?
It is not. E85 tune, and CARB tune, are mutually exclusive.
Old 05-24-2018, 08:10 PM   #4552
mrg666
pessimistic skeptic
mrg666's Avatar
And this is for a good reason ...
Old 05-25-2018, 07:38 PM   #4553
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Here’s a question:
Logs have been showing .33 adv mult.
I hear my throwout bearing talking to me... not really its more just a definite knock.
Question time! Can the Knock sensor recognize this unholy romping as knock?? I for sure know what knock sounds like, and I am not getting knock:/
Also, what kind of mass air flow rates (g/s) are normal? I’m getting around 211 g/s (28 lb/min) which really doesnt add up considering the max for the C38 is around 1032 CFM, about 77 lb/min...
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
Old 05-25-2018, 07:59 PM   #4554
CSG Mike
CSG Mike's Avatar
Originally Posted by idkwhatimdoing View Post
Here’s a question:
________
~refer to username~
Please go get your car professionally checked out and tuned.
Old 05-30-2018, 02:32 PM   #4555
stlgrym3
How much of babying and monitoring do people DD their JRSC? Is this kit reliable to the point you don’t have to pay extra attention to every details under the hood each time you drive?
stlgrym3 is offline   Reply With Quote
Old 05-30-2018, 05:48 PM   #4556
mrg666
pessimistic skeptic
mrg666's Avatar
Well, you have to monitor and take care of your car a little differently than the stock car. The dealer will not take care of everything for you anymore. I just got a P1072 the other week, for example. I didn't take it to service or post here. MAF had to be cleaned, cleaned it and the CEL is fixed. MAF needs to be cleaned more frequently than stock car. I listen the engine every day if recirculation valve is working when the car is idle or when I release the throttle after boost. The compressor can get damaged without that valve working properly. I monitor the sound of supercharger every time. Keep an eye on traction fluid, regularly clean and oil the air filter. Empty the catch can, if you install one. Just such little extra care which is fun actually.
Old 05-30-2018, 06:08 PM   #4557
rns294
Drives: 13 BRZ
I don't monitor anything with the JRSC more than I monitor any other car. Check the oil in the system occasionally, follow the maintenance guide, if you hear/feel something wrong, address it. The only problem I've had since getting the JRSC, 15-20k miles ago, is a dirty belt.
rns294 is offline   Reply With Quote
Old 05-30-2018, 06:19 PM   #4558
stlgrym3
Wow, that is a lot of work not to mention I don’t understand half of the terms you just mentioned lol.
Old 05-30-2018, 07:11 PM   #4559
gtengr
Drives: 2017 BRZ
Originally Posted by mrg666 View Post
MAF needs to be cleaned more frequently than stock car...
I bet that's related.
gtengr is offline   Reply With Quote
Old 05-30-2018, 07:19 PM   #4560
mrg666
pessimistic skeptic
mrg666's Avatar
Agreed. There is traction fluid going through the supercharger too. I think it is also mixed with the compressed air in tiny amounts.
Old 05-31-2018, 05:07 PM   #4561
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
Installed mine at 23k miles and aside from the defective blower unit(<5k miles) that was covered and replaced, it's been just standard car maintenance. I'm currently at 78k and the only thing I've done for the JRSC was replacement of the traction fluid just last week. I have a spare belt in the trunk just in case but the current one looks fine. Oil changes are done at 6-8k intervals using 0w-30 castrol and air filter is cleaned during every oil change. For the amount of added power and fun you get, it's worth the extra care.
As for driving, I just warm up for a couple minutes every morning and keep the revs low until the engine it up to operating temperature. You can get decent oil temp readings from the Torque App and a OBD2 scan tool. There's a thread with the formula and sensor setting for torque to get the oil temps somewhere in the forums. The only other thing I monitor is engine oil pressure which I have a gauge with a sensor installed in place of the oil gallery plug. Mainly for my own peace of mind but I don't think it's necessary.
Hope this helps.
Xiao Li is offline   Reply With Quote
The Following 3 Users Say Thank You to Xiao Li For This Useful Post:
CSG Mike (05-31-2018), lantsalot (08-13-2018), weederr33 (05-31-2018)
Old 05-31-2018, 07:13 PM   #4562
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Assuming it's installed correctly, no more than any other FI kit.
Check the rotrex fluid and empty your catch can (if applicable) whenever you do an oil change.
Clean and oil the intake filter every 15k/20k
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
The Following 2 Users Say Thank You to Anderzz For This Useful Post:
Old 06-01-2018, 05:59 PM   #4563
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Install and drive!
Yes, there a few new maintenance items over stock, but nothing on a more frequent basis than stock.
Sleepless is offline   Reply With Quote
Old 06-01-2018, 07:05 PM   #4564
stlgrym3
Who has JRSC with aftermarket header? Anyone pairing it up with Tomei EL? What’s your review?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
