Old 05-20-2018, 04:59 PM   #1
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Stock 86 and E98....
My local E85 dealer is considering carrying E98 instead. Currently running E85 and the V4 OFT E85 tune on my stock 17 86.
As far as I know and can determine, E98 SHOULD be OK on the OTS tune.
Correct?
Thanks, smarterer dudes!
PetrolioBenzina is offline   Reply With Quote
Old 05-21-2018, 06:04 AM   #2
steve99
Drives: FT86
Its going to run high fuel trims unless you tweak fueling.
E98 is not going to start in cold temps
You might just want to mix in 10-15% petrol into it
PetrolioBenzina (05-21-2018)
Old 05-21-2018, 07:18 PM   #3
PetrolioBenzina
Drives: 17 86
Thanks. We do get cold enough here for trouble starting with E85, and DIY blending sounds like PITA without my own garage space.
Might be fun to mix up a five gallon can, though.
Old 05-22-2018, 06:14 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's not a perfect science, the tune can handle from 60-90% ethanol. You don't have to blend in a can, just stop at the pump, put in (from E) 2 gals of 93 then fill up on the E98. It'll be close enough to be perfect.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
PetrolioBenzina (05-22-2018)
Old 05-22-2018, 12:01 PM   #5
PetrolioBenzina
Drives: 17 86
Sounds easy. Highest we have here is 92, though. Still might try the can, as that would give me just five gallons to check with, rather than a full tank. At 18 mpg of E85, I could empty that in no time at all.
Need to stop buy and see if this is moving forward.
Thanks!
Old 05-22-2018, 02:59 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
I get about 19 mpg and with a 13.5 gal tank and a 45 Mike round trip commute.... My tank feels awfully small! The OFT tune is good from E60 to E90, there's no performance benefit from anything more than 60% ethanol. There's a lot of info on this forum about it. My car feels so much better on corn juice too. You can use a wide range of ethanol % because E85 is much more tolerant of a wider ranger of AFR, unlike gas that only makes power in a very narrow AFR range.
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 01:24 PM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 12:03 PM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 10:22 PM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
