#44297 |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (05-16-2018) |
#44298 |
I have recorded data from two pulls on one pill each that says there is a 6% increase in performance. You need to post your test results that prove 4 pills are required.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Sapphireho (05-16-2018), Spuds (05-16-2018) |
#44299 |
Drive From Home
Drives: BRZ STI Performance
So has anyone changed the throwout bearing yet? My mechanic told me mine is probably going due to the weird noises (the clutch pedal hasn't start pulsating yet which is good).
Apparently there's a new part number from Subaru. I know @Tcoat probably hasn't even changed the gear oil yet.
#44300 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#44301 | |
Drive From Home
Should I buy a new clutch and pressure plate too just in case? Dam so much money just to change a 60 bucks part. :@ |
#44302 |
New clutch (was chewed to pieces when the TOB totally blew)
Flywheel resurfaced (was just enough left to save it) The slider on the transmission case. (that thing has about 40 names) New fork (it twisted a bit) Don't mess around with it. If you do it when you first hear noise everything else will be fine. Wait to long it destroys everything related to the clutch.
| The Following User Says Thank You to Tcoat For This Useful Post: | krayzie (05-16-2018) |
#44303 | |
Drive From Home
I start noticing a slight swoosh sound when I step on the clutch. There's been a squeaky sound with the clutch pedal for years but it comes and goes (noticeable only when the car is turned off). I switched to a grabbier clutch and pressure plate with a new TOB a year after I got the car (probably 30k ago). You waited like 200k? |
#44304 |
Wayward Member
Drives: Hot Lava 86
This might seem a little weird, but I don't like the idea of every piece in the exhaust being from a different company. It kind of bothers me, even if it doesn't make sense. So when I think about what parts to get I try to get at least two or three things that match. Right now I want the Perrin catback, the 1320 front pipe, and the Revworks header. I do not see a Revworks overpipe, so...
http://1320performancestore.com/frs%...%20over%20pipe But the description bothers me. "Only for the 1320 header"? |
#44305 | |
Hail Magnet
#44306 | |
The TOB starts as a woosh, then progresses to a light squeal and then get's worse until it sounds like a banshee screaming. Mine only did it on cold starts and it would be fine once warmed up. Even on cold start I could make it come and go by pushing the clutch in. At it's worse I could even play a little song. Then it stopped making noise at all. That was not a good sign.
#44307 |
[ame]https://www.youtube.com/watch?v=PrFPPoI-yeg[/ame]
| The Following User Says Thank You to Tcoat For This Useful Post: | HunterGreene (05-16-2018) |
#44308 | |
........ welcome back to the forum ........ ![]() ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | krayzie (05-16-2018) |
#44309 |
Country Boy 4 Life
Just ordered some parts for my Kick start TRX450R! Excited to go riding soon!!!!!
I have ridden it over 5000 miles! This is what I drift!!!! via Imgflip Meme Generator
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Ultramaroon (05-16-2018) |
#44310 | |
Drive From Home
![]() Anyway I bought a new TOB today for $50 bucks and indeed it's a new part number. The WRB BRZ tS is still there gathering dust on the showroom floor. But not like I can afford it.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
