| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Mixing Fuels With Different Octane
Recently came from Florida were 93 octane is practically everywhere, aaaaaaand now I'm in Colorado where I believe there isn't a single 93 pump. The premium gas here is 91 octane.
The power loss is extremely noticeable, and I can't take it anymore. Maybe elevation has a factor in to with the feeling. I've been referred to add a little e15 to the tank. However this to me sounds sketchy. I have also been referred to add a little 100 octane to the tank. I just want to at least match 93 octane again, nothing less. Whats the best way to go about this? How would this work with tuning, considering every mix will be different.
Instagram: Gabe.it.the.ole.college.try |
#2 |
The Dictater
Drives: '13 Red Scion FRS
Most pump gas nowadays is e5-e10 anyway. The only losses to octane would be pulled timing due to knock. You have a logging device to check timing?
The power loss is 80%+ due to altitude. Higher altitude, less air density, less oxygen, less boom. That's the drawback of NA for ya. FI or deal with it. Edit, just saw mod list lol I'm dumb. Uhhh idk what's up then. Altitude still probably plays a part. Add octane booster? Turn up the boost? |
#3 | |
Indulgent Tormenter
#4 |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
Add a little Blendzall 485 Racing Castor, it will slow the burn and give you a cool, racy smell.
#5 | |
![]() (or am I misreading it ..??) humfrz |
#6 |
The Dictater
#7 |
#8 | |
The Dictater
So I'm not too familiar with how your blow off valve works, but if it's regulated by a spring, it's likely based on pressure differential to ambient. Ambient pressure at 5000 feet is about 2-3psi less than sea level under the same conditions. As far as your initial driving, pressure changes with weather so maybe that had an effect. |
#9 | |
ZWEI KOLBEN
I think he is saying that of the power loss he feels he is missing - 80% of THAT LOSS is coming from the altitude. I think..... Not 80% of the overall power. |
#10 |
I would think that a car reduced to 34 WHP would be deemed more than "noticeable".
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#11 | |
Indulgent Tormenter
I don't quite get your statement about psi and elevation. I am set to 5 psi spring, which usually goes to a maximum of 8 psi. You're saying that I'm actually getting 2-3 less of what my boost gauge reads?????
#12 | |
The Dictater
#13 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Spuds (05-11-2018) |
#14 |
Indulgent Tormenter
It says it blends with premium gas. So you use this mainly as a safe factor or for driving feeling
| Premium vs regular fuels | emishor86 | Scion FR-S / Toyota 86 GT86 General Forum | 156 | 05-12-2016 01:45 AM |
| OFT Maps suitable for UK fuels | Gringosteve | Software Tuning | 14 | 03-31-2016 06:40 AM |
| Shell URT Advanced / / Sonoco 260GTX // Race Fuels | BC-Boy | Engine, Exhaust, Transmission | 2 | 03-11-2014 10:12 AM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 01:23 AM |
