go_a_way1
Old 05-08-2018, 02:31 PM   #4495
stlgrym3
How much weight difference between C30 and C38?
stlgrym3 is offline   Reply With Quote
Old 05-10-2018, 04:52 PM   #4496
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
It's aliveeeee. Finally all set-up, tuned, etc.
Anderzz is offline   Reply With Quote
The Following 3 Users Say Thank You to Anderzz For This Useful Post:
Irace86.2.0 (05-10-2018), Jmonty (05-12-2018), PikachuBRZ (01-24-2023)
Old 05-10-2018, 05:56 PM   #4497
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Nice engine bay
Old 05-10-2018, 06:30 PM   #4498
CSG Mike
CSG Mike's Avatar
2 lbs
Old 05-10-2018, 07:25 PM   #4499
CSG Mike
CSG Mike's Avatar
What is this!?
Old 05-10-2018, 07:26 PM   #4500
mybruiserproject
What is this!?
Looks like windshield washer fluid
mybruiserproject is offline   Reply With Quote
Old 05-10-2018, 08:39 PM   #4501
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
You forgot the words “high” and “performance” in there
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
Old 05-10-2018, 08:59 PM   #4502
milanojess
milanojess's Avatar
Drives: 2013 FRS
What is this!?
Corner weight adjuster
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 05-12-2018, 05:16 PM   #4503
Anderzz
Anderzz's Avatar
Interesting dilemma presenting itself.
Car is making an odd intermittent chirping sound (not crickets). Mostly audible at low RPM, frequency of the chirp increases with RPM but not in a reliably linear way, and doesn't occur at idle.
Sounds like it's coming from the driver side of the bay.
I'm running a C38, with a Forge Motorsports Recirc Valve, car is at ~70k miles.
Any thoughts on a potential culprit?
Old 05-12-2018, 05:21 PM   #4504
idkwhatimdoing
For me, I believe it was due to a worn belt. Sprayed it with a can and a half of belt conditioner and marine-duty dry silicon lube and it went away. The issue with that is the fact I had to have my unit replaced due to an unbearably high-pitched intake whistle that appeared shortly after that same chirping noise presented itself to me... be careful.
________
~refer to username~
The Following User Says Thank You to idkwhatimdoing For This Useful Post:
rns294 (05-14-2018)
Old 05-12-2018, 05:46 PM   #4505
Anderzz
Anderzz's Avatar
I would be pretty aggravated if that was the case belt was new when installed has less than 2k miles.
________
~refer to username~
Sent from my XT1650 using Tapatalk
Old 05-12-2018, 05:49 PM   #4506
idkwhatimdoing
Double check your oil cooler lines. Then check again.
________
~refer to username~
Old 05-13-2018, 03:05 AM   #4507
CSG Mike
CSG Mike's Avatar
Dirty belt/pulley.
rns294 (05-14-2018)
Old 05-13-2018, 02:29 PM   #4508
Anderzz
Anderzz's Avatar
Is a toothbrush and reconditioner the best fix here or do you have a better solution?
Dirty belt/pulley.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
