Old 05-01-2018, 12:50 AM   #1205
christoc
christoc's Avatar
Drives: None
Originally Posted by Briankbot View Post
Care to share your alignment specs also?
http://specfrs.com/Blog/aid/7
Alignment Specs
Front Camber: -3 degrees
Front Caster: 5.4 degrees
Front Toe: 0 inches
Rear Camber: –2.25 degrees
Rear Toe: 1/8” toe in
'16 FR-S SpecFRS.com
christoc is offline   Reply With Quote
The Following 2 Users Say Thank You to christoc For This Useful Post:
Briankbot (05-01-2018), steverife (05-01-2018)
Old 05-01-2018, 12:52 AM   #1206
christoc
christoc's Avatar
Drives: None
Originally Posted by Open Loop View Post
How does the Blytheville surface compare to Lincoln?
Similar, but different? Doesn't seem to pick up as much rubber, but also doesn't see the traffic that Lincoln does.
I consider it older concrete, it's an old airbase, but I really have no idea the history of Lincoln's surface.
Similar to the way Forbes Field used to be.
We don't plan on changing anything for Lincoln other than:
1) rotate tires front to back
2) replace OEM brake pads
The Following User Says Thank You to christoc For This Useful Post:
Open Loop (05-01-2018)
Old 05-10-2018, 12:04 PM   #1207
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
It looks like I may have to bow out of the Finger Lakes tour.
Work is not allowing me to drive my personal vehicle on a work trip. I have work the week before in Mechanicsburg PA and was going to drive up Friday afternoon from there.
If I drive, I have to take a rental. If I fly, I won't have my car and won't be back until late Friday night (RI). :unamused:
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 05-10-2018, 12:05 PM   #1208
christoc
christoc's Avatar
Drives: None
Take a rental towing a trailer.....
Old 05-10-2018, 01:32 PM   #1209
Imp
Bring out your dead
Can't. Mandatory use of a compact. Because contracts and stuff.
--kC
Old 05-10-2018, 05:32 PM   #1210
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
--kC
Rent the compact. Don't drive it.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-12-2018, 09:06 AM   #1211
Open Loop
2013 FR-S Whiteout / SSC
--kC
Form an entity, with a vague name like "Essential SSC Consultants LLC." Lease your car to the LLC. Then lease your car back from the LLC. Problem solved. Lawyers do this stuff all the time.
Open Loop is offline   Reply With Quote
Old 05-12-2018, 07:01 PM   #1212
Imp
Bring out your dead
Lol. That doesn't work either as it's not available from.pur corporate travel system.
Old 05-12-2018, 07:40 PM   #1213
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Why not bum a ride? Spec class so not being in your own car shouldn't be a big deal right? With the Falkens consumable cost should be less than a local event entry fee, last I did the math it was a bit less than $50 in consumables for STX with Bridgestones iirc, good learning opportunity for a data comparison in the exact same car for someone newer who dived in. Or maybe con someone local to you into driving your car out? IDK seems like the best solution is to hook up with another autoxer.
ineedyourdiddly
Old 05-12-2018, 08:13 PM   #1214
Imp
Bring out your dead
Because I have to go.back to Rhode island Friday night after a day of work and then leave from there....
The Following User Says Thank You to Imp For This Useful Post:
strat61caster (05-13-2018)
Old 05-13-2018, 04:55 AM   #1215
strat61caster
Quit?
lol
Are you really going to get punished for 'missing your flight'?
tort laws man
ineedyourdiddly
Old 05-14-2018, 09:48 AM   #1216
Imp
Bring out your dead
It's not a matter of tort laws. It's contracting to a certain "non-corporate" entity. While I've been here for 19 years as a contractor, I'm also a little on the older side to just "up and move" into something new, so I get a little more protective of things, like my a) job and b) reputation (with my customer).
--kC
Old 05-14-2018, 08:23 PM   #1217
imhereforthecar
Drives: FRS
Question, I have installed the camber bolts, and put the oem crash bolts from the bottom into the top, yet my alignment guy cannot get camber past ~2.25. Any ideas why? It's a place that does performance alignments all the time but they just can't get it to 3 degrees.
imhereforthecar is offline   Reply With Quote
Old 05-14-2018, 10:13 PM   #1218
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
What’s the offset of your wheels?
JakeRogue is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
