Old 05-01-2018, 01:59 PM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by xwd View Post
What he was getting at is the Harrop connects to the stock PCV on the vacuum side of the supercharger (throttle body most likely), so there is no difference from stock and you don't need a check valve.
So I don't need a check valve or need to do the WRX PCV swap? And I could run the catch can in series between the manifold and PCV without modifications or issues?
Old 05-01-2018, 02:20 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Correct
.: Stealth 86 :.
Kodename 47 DJ:
Irace86.2.0 (05-01-2018)
Old 05-09-2018, 04:14 AM   #17
JoeeStacks
Drives: Brz
I run a centrifugal supercharger with a check valve and wrx pcv valve. I run the racerx catch cans and everything’s been in check so far.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 05-09-2018, 04:22 AM   #18
JoeeStacks
Drives: Brz
CARB allows for catch can/s to be installed, but the can/s can't modify the emission equipment more than routing a few new hoses, and the can/s need to be a closed system.
Where did you read this from? I was under the impression that you cannot modify the pcv system.
Old 05-09-2018, 10:51 AM   #19
Vizard424
Drives: 2017 BRZ w/ Performance Package
I believe the rules are that you cannot remove or otherwise defeat the PCV system. And as Irace86.2.0 mentioned, it must be a closed system.
So adding a catch can is fine, removing the PCV valve or venting to atmos is not.
2004 Mazda RX-8 (deceased) - custom GReddy turbo kit, Powertrix Coilovers, Mazdaspeed Wheels
1987 Porsche 944 Turbo (forever project)
2017 Subaru BRZ w/ Performance Package
Vizard424 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vizard424 For This Useful Post:
Irace86.2.0 (05-09-2018), JoeeStacks (05-10-2018)
Old 05-09-2018, 12:43 PM   #20
Irace86.2.0
What he said ^^^
Essentially you can’t eliminate anything. You can only put a can in series that is a closed system. Here is a list of everything that is exempt or that requires an EO.
https://www.bar.ca.gov/pdf/APPENDIX%...%2012-2009.pdf
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 05-09-2018, 01:08 PM   #21
wbradley
Sarcastic SOB
wbradley's Avatar
In fact the Cisco horizontal style catch can instructions specify connect to intake before manifold. I thought it was an error and attached to manifold inlet. Just added an STI PCV last week but probably not essential.
Old 05-09-2018, 01:17 PM   #22
Irace86.2.0
WRX PCV you mean, right? The STI PCV, I thought, didn’t fit the threads because it is from the EJ motor. The FA20DIT from the WRX has the right threads for a PCV swap.
Old 05-09-2018, 01:47 PM   #23
wbradley
Sarcastic SOB
wbradley's Avatar
Correct, I think. I thought the parts guy said they were the same.
So, for the record, I replaced the PCV with a WRX unit.
Might not have been a different spec from the stock part though. Didn't check the numbers. The stock part holds pressure when I blow into the inlet, so who knows whether the ability to withstand boost is actually greater.
The Following User Says Thank You to wbradley For This Useful Post:
Old 05-09-2018, 02:30 PM   #24
Irace86.2.0
I will be replacing the valve like you and putting in a check valve. Overkill but I don’t think there is any harm in doing both.
Old 05-10-2018, 02:50 AM   #25
JoeeStacks
Drives: Brz
What he said ^^^
That’s awesome thanks! Just printed a copy for the car
Old 03-10-2019, 08:56 AM   #26
tomm.brz
Drives: brz 2017 hksv2
Does a centrifugal supercharger like HKS v2/v3 need a check valve addition , from PCV valve to intake manifold?
Old 03-10-2019, 11:23 PM   #27
Irace86.2.0
Pretty positive yes.
Old 03-11-2019, 03:51 AM   #28
tomm.brz
i ask my self why vortech and jackson racing put it in their SC kit but hks doesn t.. what can happeb if crankcase pressurize?
The what will Squadrogue make a thread about next... thread Phantobe Off-Topic Lounge [WARNING: NO POLITICS] 600 02-18-2020 11:17 PM
Mishimoto Compact Baffled Oil Catch Can Build Thread! Mishimoto Engine, Exhaust, Transmission 81 08-21-2019 09:05 PM
Mishimoto Build Thread: BRZ/FR-S Direct Fit Baffled Catch Can Kit! Mishimoto Engine, Exhaust, Transmission 185 02-26-2019 11:53 PM
tow hook thread pitch/thread 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 1 07-17-2014 11:58 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
