Old 04-23-2018, 10:37 PM   #15
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by j3rf View Post
Continuing this discussion, Motul's product sheet says "Suitable for any type of seal and yellow material used in gearboxes design. "
Then use it. Maybe you'll get lucky.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-24-2018, 10:21 AM   #16
ajh88
Drives: 2013 Firestorm FR-S
Originally Posted by venturaII View Post
GL5 is used in the differential. GL3/4 is fine in the transmission.
The GL-5 that I bolded and quoted is specifically in the "Manual Transmission" section that discusses fluids. The Differential fluid is a different section.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 04-24-2018, 11:11 AM   #17
venturaII
venturaII's Avatar
I realize that, and unless Subaru/Toyota/Aisin did something different in the transmission starting that year, I'd be willing to bet it's an error. Even buffered GL5 extreme pressure additives won't protect the friction cone area of a syncro.
Old 05-06-2018, 06:39 PM   #18
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
parts.subaru.com lists every part for the 2016 and 2017 manual transmission as identical. I can find no difference between the transmissions.
Either the manual is in error and you shouldn't use GL5 in the transmission or you can use it in any model year. There is nothing special about the 2017 that makes it able to use GL5.
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
venturaII (05-07-2018)
Old 05-07-2018, 12:05 PM   #19
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
From the Subaru manual:
"• Other gear oil that meets API GL-3 or
upper grade and SAE 75W-90 specifications"
If you ask Subaru for fluid, they will give you the same GL5 based fluid for the Trans and the diff for a MY13 car.
Lynxis is offline   Reply With Quote
Old 05-12-2018, 02:45 PM   #20
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Gear oils have seen declines in sulfur content since the 90s and many have been used in transmissions like ours without issue. Molybdenum disulfide is the high pressure additive used iirc. Sulfur is corrosive to brass.
Not all gl4 work great for brass synchro either. Best to find a gear oil specifically designed for high performance with brass. Too slippery and gears will grind. Shifts will be stiff. Too abrasive and you'll wear synchro prematurely.
Do people try using BMW mt fluid? Or porsche?
Coheed is offline   Reply With Quote
My trans oil 2nd gear problem - SOLVED! brzstiz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 10-23-2018 01:48 PM
Engine/Trans noise whie in gear Madmax516 Issues | Warranty | Recalls / TSB 2 08-02-2016 08:23 PM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 09:06 PM
Trans & Gear Oil Package in stock+ free ship Esoteric Mechanical Maintenance and Tools 10 05-02-2013 09:27 PM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 11:40 PM
