#15 |
Drives: Q5 + BRZ + M796
So I don't need a check valve or need to do the WRX PCV swap? And I could run the catch can in series between the manifold and PCV without modifications or issues?
#16 |
Drives: UK GT86
Correct
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Irace86.2.0 (05-01-2018) |
#17 |
Drives: Brz
I run a centrifugal supercharger with a check valve and wrx pcv valve. I run the racerx catch cans and everything’s been in check
so far.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG Old: Kraftwerks Supercharged Subaru Brz Last edited by JoeeStacks; 05-10-2018 at 02:51 AM. Reason: Wrx pcv valve not sti |
#18 |
Drives: Brz
Where did you read this from? I was under the impression that you cannot modify the pcv system.
Track: 707 WHP Turbo Honda Civic EG Old: Kraftwerks Supercharged Subaru Brz |
#19 | |
Drives: 2017 BRZ w/ Performance Package
So adding a catch can is fine, removing the PCV valve or venting to atmos is not.
2004 Mazda RX-8 (deceased) - custom GReddy turbo kit, Powertrix Coilovers, Mazdaspeed Wheels
1987 Porsche 944 Turbo (forever project) 2017 Subaru BRZ w/ Performance Package |
| The Following 2 Users Say Thank You to Vizard424 For This Useful Post: | Irace86.2.0 (05-09-2018), JoeeStacks (05-10-2018) |
#20 | |
Essentially you can’t eliminate anything. You can only put a can in series that is a closed system. Here is a list of everything that is exempt or that requires an EO. https://www.bar.ca.gov/pdf/APPENDIX%...%2012-2009.pdf |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | JoeeStacks (05-10-2018) |
#21 |
Sarcastic SOB
In fact the Cisco horizontal style catch can instructions specify connect to intake before manifold. I thought it was an error and attached to manifold inlet. Just added an STI PCV last week but probably not essential.
#22 |
WRX PCV you mean, right? The STI PCV, I thought, didn’t fit the threads because it is from the EJ motor. The FA20DIT from the WRX has the right threads for a PCV swap.
#23 | |
Sarcastic SOB
So, for the record, I replaced the PCV with a WRX unit. Might not have been a different spec from the stock part though. Didn't check the numbers. The stock part holds pressure when I blow into the inlet, so who knows whether the ability to withstand boost is actually greater.
| The Following User Says Thank You to wbradley For This Useful Post: | Irace86.2.0 (05-09-2018) |
#24 | |
#25 | |
Drives: Brz
#26 |
Drives: brz 2017 hksv2
Does a centrifugal supercharger like HKS v2/v3 need a check valve addition , from PCV valve to intake manifold?
#27 |
Pretty positive yes.
#28 |
i ask my self why vortech and jackson racing put it in their SC kit but hks doesn t.. what can happeb if crankcase pressurize?
| The what will Squadrogue make a thread about next... thread | Phantobe | Off-Topic Lounge [WARNING: NO POLITICS] | 600 | 02-18-2020 11:17 PM |
| Mishimoto Compact Baffled Oil Catch Can Build Thread! | Mishimoto | Engine, Exhaust, Transmission | 81 | 08-21-2019 09:05 PM |
| Mishimoto Build Thread: BRZ/FR-S Direct Fit Baffled Catch Can Kit! | Mishimoto | Engine, Exhaust, Transmission | 185 | 02-26-2019 11:53 PM |
| tow hook thread pitch/thread | 7thgear | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-17-2014 11:58 AM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 01:24 PM |
