Old 04-29-2018, 03:47 PM   #1
Enrique_13
Drives: 2013 Subaru BRZ
Opinions on the Ft86 Catted UEL headers
Hey guys I’m new here, I just had a quick question. I purchased a used BRZ about 2 months ago, and I got a check engine light that read P0420 Catalyst System Efficiency below threshold (Bank 1). I was told this was the catalytic converter by the header going bad. So I was thinking of buying the FT86 Catted UEL header since it has the cat with it. Does anyone know if this would help ? Also does anyone know where I could find a video of this part on the BRZ with everything else stock on the car? Thank you guys 🙏
Enrique_13 is offline   Reply With Quote
Old 04-29-2018, 04:24 PM   #2
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
I put a used FT86SF catted header on my car recently. It took about 3 days before the CEL came on. Luckily, I was on my way to get the car tuned when it happened.
I have heard some people have no problems, but some do. YMMV. I don't think the CEL will go away on its own either way. It will probably need reset regardless.
Edit: I do LOVE the difference it made in the torque dip, even before the tune!
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 04-29-2018, 06:30 PM   #3
Enrique_13
Thank you for the insight ���� How about the sound? Did you notice any better rumble ? After putting on the header?
Old 04-29-2018, 07:33 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just because you have a catted header does not mean it will not throw a CEL.
You can try to add an o2 sensor spacer but it is not guaranteed to work.
http://www.ft86speedfactory.com/o2-s...B#.WuZH6-jwbrc
Tune would be sure fix.
Old 04-29-2018, 07:54 PM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
if you wan a catted header that wont throw code ever...... Your choices is limited down to $$$$$
https://apexi-usa.com/exhaust/exhaus...-20-subaru-brz
I drove my car 30k miles before getting it tuned, tracked/auto corssed. no CEL ever.
Old 04-29-2018, 07:54 PM   #6
coryandy
coryandy's Avatar
It has a slightly more noticeable rumble, but not much. I already had the V1 catback as well, though.
Old 04-29-2018, 10:04 PM   #7
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Why catted? The hp and torque gains are significantly less than catless. If you’re going catted to keep the sound down, a catless header and stock exhaust will give you more gains and still be pretty quiet. For reference, I ran the catted JDL with an OFT, custom tune, and briefly on the stock tune. A catted header without a tune is half assing what is already a compromise.
TofuJoe is offline   Reply With Quote
Old 04-29-2018, 10:13 PM   #8
Enrique_13
Going catted because I wouldn’t pass emissions here in TX, at least that’s what I’ve been told. I was thinking of getting a Tomei Catless UEL header until I heard about emissions. I want a subie rumble , but I don’t want my car to sound obnoxious either you know ?
Old 04-29-2018, 11:29 PM   #9
TofuJoe
Ohne Titel
TofuJoe's Avatar
Not sure how emissions laws work in TX. In CA, any modification to the exhaust will make you fail the visual. So putting the stock header back on would be needed whether you have a catted or catless header.
Old 04-30-2018, 12:45 AM   #10
extrashaky
Drives: 2014 BRZ Limited
Maybe someone who is more familiar with our catalytic converters can clarify, but on some other vehicles you can get a catalyst inefficiency code from a failing O2 sensor that is reading the emissions incorrectly but isn't yet throwing a code for sensor failure. Personally I'd investigate further before shelling out the money for a new header.
(Unless you just WANT a new header, and you're using this as an excuse. In which case, grow some balls and just say you want a header.)
Correct. The "safety" inspection required in every county includes a visual inspection of the exhaust and emissions control equipment to make sure the exhaust is in good shape and you haven't removed the cats. You can replace cats with higher flowing cats, but you can't remove them altogether.
There's a separate emissions test required in 17 counties that includes OBDII testing. They hook up to your car to make sure you don't have any trouble codes stored and that your emissions readiness monitors show ready. For our cars, you're allowed one "Not ready" to still pass. Before you rely on a tune to correct a CEL for a catalytic converter, you might want to make sure it won't be detectable in the readiness monitors.
Catted Headers Exrald Northern California 24 09-14-2017 04:42 AM
WTB UEL Catted Headers LastRep Canada Classifieds 0 08-08-2016 12:51 PM
WTB catted uel headers Legionsk88 Want-To-Buy Requests 0 04-21-2016 08:48 PM
WTS: FT86 catted UEL SexyBack Canada Classifieds 2 04-14-2016 10:15 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
