#4593 | |
Drives: 2014 FR-S MT
I have MCS 1-ways and also sometimes hear a clunk from the rear in street driving when entering briskly into bumpy or inclined 90 degree turns. On my car it sounds like it's coming from the inside rear on such turns. To me, it sounds like something is moving inside the shock body. I could have sworn that I read somewhere on here a while back that the clunk in the rear was due to the internal construction of the MCS rear shocks, and that it was normal and harmless. But I can't find the post(s) regarding this issue. Maybe other MCS owners can chime in. In my case, the clunk isn't frequent or annoying enough (yet) to get me to contact MCS and ask them about it. But I imagine they'd be the best ones to ask. I've emailed them in the past about other stuff and they've always replied promptly. |
#4594 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
I feel the same clunk at high speed bumps like the shock is bottoming out but the clunk is related to the RSM had the same issue with E36s. Cheers Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
#4595 | |
Drives: 2016 White Pearl BRZ Premium
I'm running the Vorshlag rear shock mounts with the bearing perches to eliminate binding. I heard the clunk a handful of times -coming from the outside rear, when the right side of the car was loaded up in a left hand turn which serves as the transition from downhill to uphill. If I was off line a little, there is a bump approaching / at the apex and if I would hit it - clunk. So basically the totally wrong time to hit the bump - loaded right side, headed uphill, rolling on throttle transferring weight to the rear. This led me to believe that the spring and damper were just overwhelmed as all the load was all going to that right rear corner... Something is making contact under these conditions, and it sounded harsh a few times. |
#4596 | ||
At first I thought it might be the rear springs twisting slightly under compression, but that noise is distinct, and also one that I get over speed bumps. I can clearly hear the rubber isolator squeaking then. Do you think that maybe the no-torque-value 'cinching' instructions from MCS could be a factor: Quote:
Good luck finding a solution to your noise! |
#4597 | |
Drives: 2013 Scion FR-S 10 Series
I have the spherical rear shock mounts and mine have been quiet as a mouse. When I first read your post, my initial thought was that your rear shock mounts were likely the standard mount and the bearing was binding - now, I’m stumped. After talking directly with Lex Carson at MCS, my understanding is that the MCS dampers have an internal bump stop and should never be used with a traditional external bump stop on the shaft. Good luck sorting out these minor issues, and I’d recommend that you call Vorshlag Motorsports (Terry or Jon) and MCS (Lex has retired, but their support is excellent) and have them help you out. Last edited by RJasonKlein; 04-29-2018 at 01:10 AM. Reason: Corrected a typographical error. |
#4598 | |
Hey mate yeah I have he same setup with the bearing plate (as yours). I let it be as is knowing the clunk will be a standard issue. Go over through the car one more time to ensure everything is solid and tight. Car is at the shop but I believe we ended up with helper spring which helped a fair bit. Cheers!
#4599 | |
So I was out of travel externally, not internally I assume. There is no play that I can discern in the bearing on the spring perch or the spherical in the strut mount but I'm sure the shock load wasn't good for them... And measured the distance from the top of the lower spring perch to bottom of the were on the damper housing - just under 4.2" . When I emailed hyperco, they said the usable stroke for these springs, 650# 7" length was like 4.4xx" - so by the numbers and lack of powered coat scuffs, coil bind was not occurring here. So my plan is to put in the helper springs/collars which won't increase usable spring stroke or damper travel, but they WILL separate the bottom of the spring perch and top of damper by another .893" at this ride heigth. Other than that all i can think to do is add ride heigth. I'll call MCS and vorshalg on Monday and pick their brains if i get a chance at work. A HUGE THANKS to everyone for their info and discussion here! Joe V |
#4600 | |
But if you could reduce stack height by going that route, there are thin spring isolators available like these: https://eibach.com/us/i-1414-spring-isolator.html Maybe not as good as radial bearings at preventing binding, but probably better than nothing. Good luck getting everything sorted! |
#4601 |
Drives: 2017 ISM PP BRZ
@CSGmike & anyone else-
I've been pretty happy with the performance and even wear of my G-Loc R16 front pads. They have 4 days on track from my '15 STI and 9 days in the '17 PP BRZ. All 4 fronts measure 5/16s each. The rears are Carbotech at 4/16s, older than the fronts and recommended for the STI, possibly XP-12s. They have a few more STI days on them than the G-Locs. Question is, I have a 3 day HPDE 2 weekends from now at Mid-Ohio with lots of track time, just 2 groups of advanced drivers running back and forth all day long. I imagine I will wear out before my pads do! But...I'm wondering if the smart thing would be to bring my next set of pads with me, and if so, just stay with G-Locs? Other track pads preferred over G-Locs for HPDEs by anyone else...Mike? Thanks, all!
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
#4602 | |
#4603 | |
Pads are not a one size fits all,a nd you have enough experience that it's time to try using different pads to figure out your personal preferences. |
#4604 | |
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
I.G. @mytoy86
#4605 |
Drives: Halo 2016 Scion FR-S, 6MT
First time tracking this Wednesday and it's supposed to rain..... YAY or NAY??? RRR is offering a BOGO here in Savannah, GA, USA if anybody wants that information. $150 for 2 drivers!
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI Open Flash Unequal Length Header Invidia N1 CatBack InstaGram: 49RJ |
#4606 |
Tracking in the rain is awesome.
You can't go as fast so in some way's it's less "dangerous" and it really gives you feedback on if you're driving the right line and smooth on your inputs. So, YAY. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
