Old 04-27-2018, 01:07 PM   #57
Oliverklozov
Drives: 2014 Subaru Impreza WRX Hatchback
Originally Posted by ncted View Post
Why would the tuner not work? FM in Australia is 87.5-108 MHz. FM in US is 88-108 MHz. Things like HD Radio and tags might not work, but the stations should tune just fine.
Just something I've read in my research so far.
Oliverklozov is offline   Reply With Quote
Old 04-27-2018, 01:09 PM   #58
Oliverklozov
Originally Posted by el-guapin View Post
The viewable screen size is smaller in the new 918. BUT it is HD. There are new settings, icons and better sound processor. My main reason to upgrade was the ability to control the optional Whetron Cameras for 360 viewing. Im still waiting for those to become available.
Can you do me a solid and measure the face of the HU? My cars opening is 8" wide by 4" tall.
Old 04-27-2018, 01:19 PM   #59
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Standard double DIN is 7"x4" so your 8" wide opening (~200mm) should fit this radio
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 04-27-2018, 01:20 PM   #60
Oliverklozov
These are a few pictures of the wiring of my stock HU.
Old 04-27-2018, 01:21 PM   #61
Oliverklozov
Thanks!
Old 04-27-2018, 05:20 PM   #62
gpvecchi
gpvecchi's Avatar
Well, if you compare specs, sound processor looks exactly the same...
Old 05-06-2018, 09:54 PM   #63
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Got this unit in over the in the last week. It's running with an OEM Audio Reference CF System. Also put on the Kenwood CMOS-130 reverse cam that came with the HU.
Love how integrated and sleek the unit looks.
It's great having Android Auto and getting the voice prompts warning me about speed cameras. The EQ and balance tuning is also superb. Has anyone tried Viper4Android with this unit? I might have a playaround this week.
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
ncted (05-07-2018)
Old 05-21-2018, 07:54 PM   #64
curtdragon
Drives: Acura TSX
I had the 917 and now the 918. Everything works on my 86 except dvd as it is region locked.
Where did you get the new one from? Same wiring works as the 917?
curtdragon is offline   Reply With Quote
Old 05-23-2018, 12:02 PM   #65
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Got it from New Zealand. Wiring harness is exactly the same.
el-guapin is offline   Reply With Quote
Old 05-23-2018, 03:00 PM   #66
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I want to make android auto users aware that android 8.0 caused the software to completely break for me.
I have an LG G6, and on android 8.0 it was impossible to establish a connection to my car regardless of the cables I used (original or "certified" cables). I have since had to downgrade and recover my phone to a 7.X android OS and everything is working fine again.
During my research for a fix this seems to be fairly common on a number of phones that have gone to 8.0. This has been a known issue since December 2017 when 8.0 started rolling out but there wasn't a fix yet for my phone. Android 8.1 fixed the issues on some devices, but that update isn't available for phone yet. Lucky me the Canadian version of my phone is not able to be flashed with custom roms so my only option was to downgrade entirely.
Oddly enough, 8.0 is supposed to enable wireless android auto for compatible head units (not applicable to DDX917WS or DDX918WS to my knowledge).
Just a heads up to check before you update your phones!
wolffbite is offline   Reply With Quote
Old 06-15-2018, 04:27 PM   #67
Vanilla Bear
Drives: 2017 CWP BRZ
Installed the DDX918ws in my 2017 BRZ and everything works great except the backup camera. It works after like, 5 minutes of the car being on. The reverse interrupt works but it displays a black screen until the camera decides to work. After that it works fine any subsequent time. Anyone got any idea as to why?
Vanilla Bear is offline   Reply With Quote
Old 06-15-2018, 04:47 PM   #68
curtdragon
Drives: Acura TSX
I don't have an answer for you but can you fill me in on the extra parts you needed to make this work?
Old 06-17-2018, 03:00 AM   #69
Vanilla Bear
Honestly I ordered this: https://carboncarsystems.com.au/shop...17-subaru-brz/
It worked just fine with the backup camera with my other Kenwood unit before I swapped to the 918ws which makes me worried I blew a fuse.
If you don't want to order that cable then everything you need is included in the box except the cable you need to step the voltage of the camera down from 12v to 6v. The cable is linked previously in this thread somewhere.
Old 06-17-2018, 05:22 AM   #70
azonic
Drives: 17 BRZ
Vanilla, those cables are not 100%, I have gone through two - the second having the same problem as you described, the first not at all. A bit disappointing, but at least they make everything else really easy.
Grab a 12v-6v voltage dropper and hard wire it in, it's what I did and it works great now. Bonus being that I can then change the headset to reverse camera display at anytime.
This is the one I used; i'm sure you can find something similiar in Dublin https://www.jaycar.com.au/dc-to-dc-s...odule/p/AA0237
azonic is offline   Reply With Quote
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 11:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 04:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 07:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 06:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 01:07 PM
