Old 04-26-2018, 06:46 PM   #337
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
Originally Posted by Jasonb View Post
On 91, I'd leave it at .7.
I’m on 91, when I flashed the v4 tune my IAM was set to 1.0 and every time I start my car now my IAM is at .86. Should I change it back down to .7 or just leave it? Isn’t it better to start off with a higher IAM than having to wait til it increases? Thanks in advance.
mizzta21 is offline   Reply With Quote
Old 04-26-2018, 06:51 PM   #338
Jasonb
Drives: 17 Series Yellow BRZ
It's safer to have it start low and increase as the ecu sees no knock being detected.
If you have it start high then there is more of a chance of it knocking.
If your IAM ever gets below where you set the initial IAM the ECU remembers that and it will start back up wherever it left off.
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
mizzta21 (04-26-2018)
Old 04-26-2018, 07:50 PM   #339
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by SuperTom View Post
Is there anything I can do or check?? I will double check all connections pipewise and 02 wise
You have a MY17 correct? I see (in EcuTek mind) that the P2270 isn't defined on older ROMs but in ZA1JK00G/01I it is and enabled. It's showing as "O2 Sensor Signal Biased/Stuck Lean B1S2". Without a V3 to compare or know what it's based on I can't comment further. If it was B01C/D then I reckon that's why.
Originally Posted by Tuxedo Tony View Post
Also do I need to change any other table when changing just the initial IAM?
No
Why not set it to 0.8 then? Lower would be better to start than higher IMO. It doesn't take long to increase unless you're just cruising, in which case it's not going to make much difference anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Teseo (04-26-2018)
Old 04-26-2018, 09:23 PM   #340
steve99
Drives: FT86
@Kodename47
V3 tunes for usa 2017 was based on usa K00C rom
V4 on K00G
Its possible tgier is some issues with using K00G in K00C car but this is only issue thats come up with this P2270 code and a lot of guys in usa running the v4 tune on 2017. He seems to indicate he has moved the 02 sensor to differnt position.
One difference in v3 to V4 was ltft correction limits was 40% in v3 but 2% in v4 , but unlikely to cause cel just limit ltft correcrion in open loop how , seems likely its hardware issue or sensor placement install issue. Have that code before when guy put spacer in front o2 sensor got lean code and slow respose code.
Be interesting to see logs of his car might give a clue
Old 04-26-2018, 10:01 PM   #341
Lantanafrs2
Drives: 2013 frs red
I'm running v4e85 uel tune. Today started running like shit. Poor idle, hesitation throughout power and etc. Cleaned maf, tb and reconnected and tightened intake tube on both ends. Idle immediately improved and rest of powerband is starting to come back to normal. Who knows? I am very relieved however.
Lantanafrs2 is offline   Reply With Quote
Old 04-26-2018, 10:24 PM   #342
Tuxedo Tony
Drives: Frs
Okay. I'm going to leave it as is. Thanks for the quick responses and info @ kodename47 & @ Jasonb!
Tuxedo Tony is offline   Reply With Quote
Old 04-30-2018, 06:19 PM   #343
mizzta21
mizzta21's Avatar
anyone want to chime in on why my v4.03 drones like no other? ive had the same setup with the v2 tune with stock headers, catless front pipe and N1 catback but when I flash the v4 it just drones so much....
Old 04-30-2018, 06:51 PM   #344
NCFRS
Drives: White Out Scion FRS
I need of help
Has anyone had issues with the checksum not correcting itself on the ZA1JD00C tune files. I have tried all sorts of work arounds but when ever I go to load the tune into OFM I get the error code of checksum is wrong.
Any help would be awesome.
NCFRS is offline   Reply With Quote
Old 04-30-2018, 11:50 PM   #345
steve99
Drives: FT86
oft/ofm automaticly corrects checksum, will be fine
it wont fix corrupted rom or editing with bad or incorrect definition, but if your using rom direct from oft guys its kust a warning that oft/ofm is correcting checksum for you just load and flash will be fine
Old 05-01-2018, 11:02 AM   #346
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
I have mine set at .9 on startup and it's usually at 1.00 within 2-3 minutes of driving.
How would I go about changing this? Also, I wouldn't mind getting the loud start back too if anyone can explain how to do this. Thanks
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 05-01-2018, 11:32 AM   #347
tomm.brz
Drives: brz 2017 hksv2
on romraider open your map with the correct definition
change [ignition timing- knock control] Avance Multiplier (initial) from 0.7 to what you want
for cold start back:
[ignition timing - advance] ignition timing post start from 0,04 to -15 (that 's loud) or -19 (even more loud) or something less like -9 (a bit quieter)
idle speed on v4 is 1200 maximum so if you want louder cold start you should put those tables higher like 1400
but actually I think you would also change the MAF correction after start (idle)- (in gear) to offset more the maf during the cold start situations, but the Shiv's definitions on the v4 tunes have these not defined but well i think you can also not do that
FT86Z (05-01-2018)
Old 05-02-2018, 05:35 PM   #348
Hella Basa
Hella Basa's Avatar
Drives: 2014 Subaru Brz Limited
To get the loud cold start back I only need to change the ignition timing post start?
Hella Basa is offline   Reply With Quote
Old 05-02-2018, 05:43 PM   #349
tomm.brz
if you only change ignition timing post start, will be louder but not like stock
stock cold start is very loud also because has higher idle so if you want it loud rise it like at 1400 rpm minimum, on the "left" zones of the idle maps
v4 tunes has max of 1200rpm that s not much to get it loud
but yes, it s basically only that, try put -15 or -19 (this one is on my17+ stock rom) and hear it
but v4 has maf correction after start a lot reduced on cold start, you should put higher values on the first 2 rows in those 2 maps, but v4 oft definitions have them not defined, you need better definitions to modify them
Old 05-02-2018, 05:47 PM   #350
steve99
Drives: FT86
defs in fist post have those tables defined if you 2012-2016
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
