Old 04-25-2018, 11:53 AM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Race Car Maintenance
I'm looking for some advice and suggestions on race car maintenance, things to look out for and to inspect periodically.
I've been autocrossing and tracking my BRZ for over 2 years now, all while it being my daily driver for just over 45k miles. The car is STX prepped with the only mechanical stock component being the diff(Within STX Rules).
Luckily, the only failure so far is a driver side rear cv joint, which i took the opportunity to replace both, with a pair of salvaged axles that had about 14k miles(previous owner had stock suspension, he had a blown engine and totaled it). I've been routinely changing oil at 5000 miles with AMSoil (have not had a chance to send a sample to BSL, probably should...), and changed tranny and diff fluid at 15k and 30k(planning on leaving that alone till 60k now). Brake fluid has also been changed at 40k miles when i installed SS lines/rotor and pads.
Other than the above, i haven't really done all that much to keep her in shape. Just feel i could do more to keep her healthy as long as possible.
slyphen is offline   Reply With Quote
Old 04-25-2018, 12:28 PM   #2
Sounds like you are doing about all that is truly required. You may want to look at changing the brake fluid a bit more often if you are running them up in temperature on a regular basis. An oil test wouldn't hurt and give you some peace of mind if nothing else. Not a whole lot of other preventative stuff you can do really. Just keep some cash in reserve incase you break something.
slyphen (04-25-2018), Spuds (04-25-2018), Teseo (04-25-2018)
Old 04-25-2018, 01:00 PM   #3
slyphen
Drives: Man
Anything you think I should inspect periodically? previously i noticed some oil residue on the axle boots, which i was kinda expecting they would fail, and they did... do you know if there are any other component i can/should keep an eye on?
Old 04-25-2018, 01:16 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Clutch fluid should be treated the same as brake fluid, and changed at the same interval, which on a tracked DD vehicle should probably be yearly, and be sure to use a high quality DOT4 or 5.1. The only other maintenance item I didn't see was coolant, which I usually dump and refill every 3-5 years. Periodic checks of ball joints/bushings/tierod ends isn't a bad idea either.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 3 Users Say Thank You to venturaII For This Useful Post:
slyphen (04-25-2018), Spuds (04-25-2018), Tcoat (04-25-2018)
Old 04-25-2018, 01:17 PM   #5
All of them! Not being dramatic or joking. Check your suspension for leaks, loose parts. Check your belts and wire connections. Watch you clutch/tranny for slipping or odd behaivour. Keep an eye on your tires for odd wear. And so on and so on. About 98% of the things that you could wear will give you some sort of warning be it a smell, noise or feel well before they fail. The parts that will suddenly and catastrophically fail (i.e. inside the engine) are not something you can really inspect anyway.
Old 04-25-2018, 01:18 PM   #6
Oh I forgot coolant!
Old 04-25-2018, 01:27 PM   #7
Code Monkey
Drives: Subaru BRZ
In addition to all the above, wash your wheels often and check for cracks.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Spuds (04-25-2018)
Old 04-25-2018, 01:38 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Coolant doesn't need to be changed for 135k miles, then every 30 or 60k miles after that (I cant recall off the top of my head). But in 135k miles I almost dumped a whole other bottle into the overflow from it emptying/evaporationg/whatever.
And check your wheel bearings regularly too
Teseo (04-25-2018)
Old 04-25-2018, 01:42 PM   #9
slyphen
Drives: Man
yep, changed clutch fluid as well, same time i did the brakes. didn't know i should do it yearly though... good to know! and noted on the coolants and joints.
Old 04-25-2018, 01:47 PM   #10
venturaII
venturaII's Avatar
I typically hang on to vehicles for a long time, so whatever I can do to extend service life, I'll do, such as fluid/filter changes on 'sealed for life' transmissions, and changing other fluids a bit sooner than normal intervals. For the relatively low cost of a coolant dump/refill, I'll pay for the peace of mind of a few extra changes.
Old 04-25-2018, 02:15 PM   #11
finch1750
finch1750's Avatar
I figure since I dump so much fresh in that's like a change in itself lol. I probably dumped .9gal just refilling over time. Then the drain and fill only took like 1.2gal of the ~2gal capacity.
Granted I also avg 20-30k a year on the car so it only took me 5 years to hit the first change and will be 2-3 years to hit every one after this haha
Only thing I change early is ATF, but that's because heat kills it so any track time/canyon runs and it starts shifting rough after 30k miles (half the normal interval). Will likely change it more often since I track more now at like 25k to avoid any issues.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Teseo (04-25-2018), venturaII (04-25-2018)
TMG 86 Cup car to race at Pirelli World Challenge Utah race. Rampage Scion FR-S / Toyota 86 GT86 General Forum 16 08-12-2017 11:34 PM
86 to Race inaugural Moder Sports Car Race 000 Racing AUSTRALIA 4 05-23-2013 07:22 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 05:42 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 09:51 PM
