Old 04-17-2018, 06:37 PM   #1
frs_caskey
frs_caskey's Avatar
Drives: 2013 FRS DGM.
CEL p0456 on 2013 n/a help!
I have a 2013 FRS manual n/a with 50k miles. Stock except for gruppe s cattless header, mxp comp rs exhaust, and oft stage 2 tune(mods have been on for a year with no problem till now)
Just had the p0456 cel pop up for evap system. Tried doing some research and people say the gas cap but mine is tight. I cleared the code to see if it will come back on but as I've been driving it doesn't seem quite as quick as usual, has hesitation when first pushing gas pedal, and runs rough in reverse slow speed.
Any help or tips would be great, I tried looking for loose vacuum lines but can't find where evap system is.
frs_caskey is offline   Reply With Quote
Old 04-20-2018, 08:26 AM   #2
frs_caskey
frs_caskey's Avatar
Update: been 2 days since I cleared it and it now came back on. Does anyone have any experience with this issue, or any advice they can give me? Thanks
Old 04-20-2018, 12:38 PM   #3
steve99
Drives: FT86
check evap canister hoses
check evap hoses under intake manifold have not popped off or cracked loose
check evap purge solenoid connection
use oft to check ltft at idle (over 10% or so) if its high you likely have leak
check idle manifold vacuum should be about -9 psi
https://www.engine-codes.com/p0456_subaru.html
The Following 2 Users Say Thank You to steve99 For This Useful Post:
frs_caskey (04-20-2018), guybo (04-20-2018)
Old 04-20-2018, 02:37 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You need techstream to test whether the evap solenoid valves are closing. Sometimes they build up crud and can't seat properly or just shit the bed. I was going to say to go into RomRaider and just disable the CEL since it is just the Evap system.... but P0456 isn't turn-offable.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
P0455/P0456 - Will go into limp mode Kojiro Issues | Warranty | Recalls / TSB 23 02-22-2018 11:58 AM
CEL P0456 Carwhisperer Issues | Warranty | Recalls / TSB 48 04-23-2017 05:46 PM
CEL p0456 code, jerking when braking RedNWhite Issues | Warranty | Recalls / TSB 7 06-03-2016 07:35 PM
Cricket-Fest 2013!! Calling All FT86s! Pure's Last Meet and Dyno Day of 2013! Pure Automotive Mid-Atlantic 274 10-15-2013 11:48 AM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 09:03 PM
