Old 04-18-2018, 01:14 AM   #42701
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Step 1: Learn to scale maf
Step 2: Install TuRD box
Step 3: Go fast
I'm sure you can find the TRD MAF table online somewhere.
Step, what are we on... 5? Step 5: Realize that the ECU is actually Pandora's box. You will never sleep soundly again knowing that your maf scale is still not perfect, or that there is still that annoying dip in your afr you just can't seem to chase down...
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (04-18-2018)
Old 04-18-2018, 01:15 AM   #42702
Spuds
The Dictater
Spuds's Avatar
Haha... Wear a suit to a wedding, or play with cool toys? Tough choice.
Southwest Boeing 737 frags a compressor hours after we take one home. For the first time ever, I looked up and made a mental note of the serial number as we boarded. Creepy.
Wait, so the same plane you took home, or a different one?
Spuds is offline
Old 04-18-2018, 04:03 AM   #42703
I am going to fly up and slap wookiee.
Step one. PUT IN FUCKING CAR.
Step two: tell wife i said hi.
She says "Helloooo... Thanks for the candy."
Originally Posted by Teseo View Post
Step 4: profit
Enjoy it man. What you bough for ECU flash?
Tactrix. I'm a masochist.
You and S-ho make a good point. Not my comfort zone but probably more reasonable. I've never regretted blazing my own trail. Takes longer but knowledge is power.
I'm truly conflicted. :|
Not the same one but same model, same carrier. For a few years in the Navy, my life was just a string of close calls. Looking at that serial number the day before an actual incident just brought it all back in a flood.
Ultramaroon is offline
Old 04-18-2018, 08:55 AM   #42704
Yay! Candy!
COOL! Now your intake will be louder than your exhaust.
Tcoat is offline
Sapphireho (04-18-2018), Ultramaroon (04-18-2018)
Old 04-18-2018, 10:14 AM   #42705
Spuds
The Dictater
Spuds's Avatar
Well, first step of MAF scaling is to put the intake in the car and drive it. Might run a bit weird at first but it should work ok? So Ho is right in that regard, PUT IN CAR. You need to let your fuel trims get to consistent values which takes some driving. I would avoid pushing it into OL until MAF is scaled, which is going to be torture.
Alternatively, you can get your scale close enough by copying in the predefined table, do a quick check out to make sure there isn't anything wonky, then let 'er rip. You can (and should) rescale later, but your starting point is closer.
Southwest only flys 737s last I saw. They really like them some 737. And winglets. And winglets on winglets. And swept tips on winglets on swept-tipped winglets. ... what were we talking about again?
Spuds is offline
Old 04-18-2018, 10:36 AM   #42706
HunterGreene
Hail Magnet
HunterGreene's Avatar
First with the 60 minutes piece on Allegiant, now the SW engine grenading, I think I will just pay for premium service whereever I go.
Oh, hey, was I gone?
It has priests in it?
HunterGreene is offline
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
p1l0t (04-18-2018), Tcoat (04-18-2018)
Old 04-18-2018, 11:16 AM   #42707
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Just look at this explosive logo. KABOOM!!
krayzie is offline
The Following 3 Users Say Thank You to krayzie For This Useful Post:
p1l0t (04-18-2018), Spuds (04-18-2018), Ultramaroon (04-18-2018)
Old 04-18-2018, 12:25 PM   #42708
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Hey @Tcoat, you guys make black brake rotors? I bought some rotors and I guess I didn't read all the way down the page. They have a "black GEOMET" coating. I assume it will wear off where pads will contact, since I'm pretty sure metal still only comes in one color. I just have never seen black rotors.
Sapphireho is offline
Old 04-18-2018, 12:32 PM   #42709
We do. We even use Geomet. It will last about 1/2 an hour on all contact points if you stick to light braking. Most of the OEM companies had us stop applying it to the braking surfaces since it was just a waste of time and money. However... It will last the life of the rotor or longer on any non contact points. It is really good stuff and even heat won't hurt it. I plan to use it on my new rotors when I eventually have to change them.
Edit:
Are those chips and scratches on the wheel mount face in the pic? I didn't notice them until I posted the response. There is no way it should be down to bare metal if properly applied. Once cured you can hit the bloody things with a hammer and it will just leave a scuff mark. If it can come off that easy it wasn't prepped or cured properly.
Tcoat is offline
Dadhawk (04-18-2018), Teseo (04-18-2018), Ultramaroon (04-18-2018)
Old 04-18-2018, 12:44 PM   #42710
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Edit:
Cool. I figured it would be good for rust prevention in nooks and crannies. I'll take a closer look at them when I get home.
Old 04-18-2018, 01:53 PM   #42711
krayzie
Drive From Home
krayzie's Avatar
China rotors?
krayzie is offline
Old 04-18-2018, 02:05 PM   #42712
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by krayzie View Post
China rotors?
Nope, UK.
krayzie (04-18-2018)
Old 04-18-2018, 02:10 PM   #42713
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Lol, the guy is 750 miles from Laguna Seca, but he's ready.
Old 04-18-2018, 02:10 PM   #42714
Nope, UK.
EBC?
Tcoat is offline
