Old 01-14-2018, 09:41 PM   #43
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Having some trouble with my new ECU. I unplugged negative battery terminal, installed new ECU, hoole battery back up, did a 35 min security sync, and now I'm trying to flash B01C on this new ECU which is JA01C but ECUFlash won't even read. I get an error that tells me too look at the log but the log just shows "entering bootloader" then "interface close". Thoughts?
ApexEight is offline   Reply With Quote
Old 01-15-2018, 06:35 PM   #44
steve99
Drives: FT86
Check battery is good and volts above 12
If the tuning device will read the calid and vin number then conmection is ok and ecu responsive. Most likely cause is that ecu has been flashed with a tune sysyem that locks ecu ie brzedit or ecutek
ApexEight (01-15-2018)
Old 02-01-2018, 02:51 PM   #45
darthfrs
darthfrs's Avatar
Drives: 2016 Scion FRS
Using this procedure tonight, crossing my fingers.
Just did a full 6speed swap. The only thing untouched was the engine + engine harness. I had left the AT ECU in the car, hoping to flash a MT over it. No such luck.
Grabbed a MT ECU, installed it and tonight I'll be using the software listed and the proper cable to hopefully change the VIN and complete the 30min pin jump.
Doing this so I can then use my Ecutek software to recognize my original VIN with the new ECU and flash my new MT tune. Wish me luck!
darthfrs is offline   Reply With Quote
Old 02-02-2018, 07:48 AM   #46
steve99
Drives: FT86
Unless the ecu was locked you should be able to flash any rom you like to it, done many of these now no issues auto to man or other wsy round usa to austrslian no issues
Tcoat (02-07-2018)
Old 02-07-2018, 12:16 PM   #47
darthfrs
darthfrs's Avatar
VIN change went great, no issues. Problems came into play with my Ecutek license. Had to get my license transferred to my new MT ECU and remove the license from my AT ECU. PIA
Old 02-10-2018, 02:51 AM   #48
Pouria
Drives: Toyota 86
hi guys
i have a question
can we downgrade the software of ECU?(maybe with Ecutek?! or something like that)
for example , ECU got an update, and i dont want that.can i downgrade the ecu and get rid of that update?(SST update)
thanks
Pouria is offline   Reply With Quote
Old 02-10-2018, 09:58 AM   #49
steve99
Drives: FT86
Originally Posted by Pouria View Post
hi guys
i have a question
thanks
no earlier software in not compatable wit 2017 cars due security updates.
you just need to turn off hill start assist its in owners manual
Old 02-10-2018, 10:40 AM   #50
Pouria
Drives: Toyota 86
thanks for your answer
i'll go and test that
in fact my car produced in the 08/2016
ECU part number : 22765AK030 (112800-3831)
Old 03-10-2018, 01:26 PM   #51
saikat.saha
Drives: Toyota Gt86 2012 orange
Hello all,
I have replaced my ecu with a used one which one i bought. After looping 3 and 14 pin of the obd port and pressing 2 times the start button, CEL loght start blinking. I have waited for 30 mins. Then tried to start the car but its not starting, its like self is trying but lack of ignition and fuel , car is not starting. What problem can be.
Thanks
Saikat
saikat.saha is offline   Reply With Quote
Old 03-11-2018, 05:21 AM   #52
saikat.saha
Hello all,
My 86 has Greddy T518z Turbo kit installed and tuned by Greddy. To tune again i have to install new ecu because previous ecu is locked by previous tuner.
I have replaced my ecu with a used one which one i bought. After looping 3 and 14 pin of the OBD port and pressed 2 times the start button. I have waited for 30 mins. Then tried to start the car but its not starting, its like ignition self is trying but throttle body is not starting. What problem can be. is my new bought ecu bricked or that does not have turbo map , thats why car is not starting.
Thanks
Old 03-11-2018, 09:43 AM   #53
steve99
Drives: FT86
Originally Posted by saikat.saha View Post
Hello all,
Thanks
If starter cranks on pushbutton start car ecu sync is good and ecu working.
may not start if map sensor or port injectors non standard on stock tune
or you have manual car with auto ecu calibration or other way round
Old 04-12-2018, 03:35 PM   #54
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
@steve99, I write here for better understanding to all.
It refers to ECU mgmt.
HKS Japan often said that HKS reflash for S/C outside Japan is not possible on non Japan ECU.
I know that HKS Flasher for S/C writer operates only for Japanese car and it needs:
#1. ECU FW with a genuine .pak file of JDM;
#2. HKS flasher chechs if VIN and ROM are JDM;
#3. If a rewrite is almost done on a genuine ECU, HKS will not reflash.
#4. No reflash is done on an override ECU with other tune.
I know that EDM and USDM later grade maight not be fully interchangeable thus is there a different management of Baro and MAF due to US emissions rules.
My question is:
#A - If I get SSMIII (and J2534) updated which contents include all Subaru's .pak file (JDM, EK, AE and so on), can I flash an EDM ECU with a JDM pak file (you need to change VIN with a Japanese one)?
#B - after that, the JDM reflash grants me the choice to use HKS flasher to tune my S/C;
#C - JMD ECU management might be adverse in NBC or other modules?
Trap63 is offline   Reply With Quote
Old 04-12-2018, 05:17 PM   #55
steve99
Drives: FT86
My question is:
As far as I know all ecu hardware is same just the ecu calibration (tune) is different for each country and the VIN changes with each car.
I have had people put A01G roms in Japanese cars ie A00A for example and it works fine, just did another one couple of days ago ,was Japanese import t Australia.
So you will be able to flash a say A01A Japanese rom to your A01G car and it will most likely work fine unless their is some external changes like emissons . as long as the hks editior will allow you to disable codes it should be ok. however their tune is likely locked ??
you could also change the VIN this does not effect ability to start car only effect licienced tools like ecutek hks and brzedit OFT.
I would thik you would loose your ecutek licience if you overwrite with hks editor tool.
the safest option might be to purchase an ecu and test on the second ecu. and keep your original ecu to swap back in in case of problems.
Trap63 (04-13-2018)
Old 04-13-2018, 08:43 AM   #56
Trap63
Trap63's Avatar
I agree...
Bricked ECU? FirestormFlex Software Tuning 8 03-14-2016 10:20 AM
My OFT is basically bricked austin_ellas Software Tuning 19 03-08-2016 07:59 PM
Who has Bricked an ECU Toyota John Software Tuning 5 03-02-2015 11:10 PM
Need Bricked BRZ 86 ECU steve99 Software Tuning 0 10-25-2014 07:09 PM
I think I bricked my ECU with EcuTek help iketiak Engine, Exhaust, Transmission 4 07-04-2013 12:19 AM
