Old 02-17-2018, 05:44 PM   #183
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Sounds to me like you should just stick to the hair dresser mobile.
Old 02-17-2018, 06:51 PM   #184
skeeler
skeeler's Avatar
Drives: Miatas of Various Kinds
If the standard means of gaining adjustability is camber bolts in the front and LCAs in the rear, what features should I look for in each? It doesn't seem like the camber bolts vary much from one manufacturer to another; they are just bolts, so there's not that much to them. There seem to be quite a variety of LCAs, though.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
skeeler is offline   Reply With Quote
Old 02-17-2018, 07:24 PM   #185
jamal
jamal's Avatar
Drives: Legacy GT
Impressive that the miata allows that much adjustment stock. That is really not common.
Also, if you really are concerned with getting the alignment ride for track use you need a tire temp probe.
The bolts all look the same because only like one manufacturer actually makes them all (SPC I think), and then they're repackaged by eibach, whiteline, ingalls, parts stores, etc.
Same goes for some of the rear LCAs. Take a look at SPC's arms, and then superpro and whiteline. The color is different and that's about it.
So anyway, for an inexpensive set of arms go with spc, whiteline, or superpro.
Then for a fancy arm with turnbuckle style adjustment and an inner rod end the cusco and velox/verus arms are both pretty nice. Cheaper versions with a budget exposed rod end are not a good idea IMO.
jamal is offline   Reply With Quote
Old 02-18-2018, 11:44 AM   #186
ZDan
ZDan's Avatar
Drives: '23 BRZ
If your car offers enough range of adjustment, then you don't have to max it out.
On the other hand, if I can get as much as I want/need, I don't care if I have any adjustability beyond that.
My NC is at -2.4° front and -2.1° rear, and I've been at least 0.2° more than that. On that car, you want to run less static camber in the rear, due to the steeper camber curve of the 5-link setup, so if I were stuck at the max camber in the rear--I don't even know what that is, because I've never needed it--I'd have less drive on the straights. Adjustability is imperative.
Not if you can get the camber settings reasonably close without it... But generally unadjustable cars are not going to have *excess* rear camber, and often once lowered it's about where you'd want it anyway, around -2.
For me, for street and track, if I can get -2 all around on the BRZ I'll be OK with that. Would like to get -2.5 front, but not going to coilovers on it any time soon... Will see what I can get with camber bolts and bringing it down 1". For me, street/track/time trials, I dont think adjustability beyond that is imperative, and I'll just run it maxed out all the time. And tune balance with sway bars if necessary.
Old 04-12-2018, 02:11 AM   #187
gpvecchi
gpvecchi's Avatar
It seems that best angles for this car for Street use are: camber 1.5 degrees for front and rear and 0 toe for front. But which toe for rear? Thanks!
Old 04-12-2018, 11:38 AM   #188
Vital
Drives: 2015 BRZ
That should be fine, but ideally you want more camber in front and a little less in the back. You want 1/16 toe-in rear.
The Following User Says Thank You to Vital For This Useful Post:
gpvecchi (04-12-2018)
Old 04-12-2018, 11:56 AM   #189
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Just throwing it out there...there are adjustable lower rear arms available that are stamped steel, like OEM, and they won't break the bank like the fancier aluminum aftermarket ones, plus they use OEM-style rubber bushings instead of spherical rod ends so they should be far more durable if you live in an area with poor weather.
https://www.rockauto.com/en/moreinfo...504006&jsn=317
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
new2subaru (04-12-2018)
Old 04-17-2018, 07:00 PM   #190
IndyBRZed
Drives: 2017 BRZ Limited Auto
This past weekend I did the Swift Sport Springs (BRZ) and SPC lower 14mm camber bolts and swapped the upper 16mm with the lower 14mm. We were using a Harbor Freight angle gauge to guess with.
Have appointment with alignment shop to do -2.0 front, -1.5 or whatever fixed stock is, as per this thread 0 toe front and rear.
Unaligned it feels really good on the blizzack snows, yep still snows here in Indiana in late april, Uhg.
When it stops snowing and they start fixing some of these craters in the road. I can swap on my New 17x8.25 XXR with 245/40/17 hankook V2.
Going to be a real fun DD
IndyBRZed is offline   Reply With Quote
Old 04-17-2018, 07:14 PM   #191
churchx
churchx's Avatar
Drives: 2014 GT86
IndyBRZed: If snow performance matters and alignment is mentioned, then better not go to camber more then -1.5 or even -1. With very limited grip available on snow/ice, grip/traction is lost way before there is lot of sidewall flex that might be needed to compensate with static camber to restore contact patch & grip, so lesser camber angles will provide flatter/better contact/grip on snow/ice. -2 and higher .. sounds more for performance alignment on dry tarmac. (stock alignment btw is 0 camber front, -1.2 rear)
Old 06-14-2018, 01:16 PM   #192
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Just read all of this. many thank yous to all who posted!
This is my 3rd year tracking my '14 BRZ. I've maxed out the stock suspension and my tires are pleading for an upgrade!! (alignment w/ camber bolts: camber: -1.25° front, -1.5° rear, toe: front 1/32" out, each, rear 1/32" in, each) I'm reading through all I can to decide. A well known BRZ/FRS racer has suggested Tein Flex A's for track and street. I intend to do rear LCA's. I will lower no more than 1". Will I need to replace rear toe links at 1" lower?
snuff58 is offline   Reply With Quote
Old 06-14-2018, 09:25 PM   #193
Racecomp Engineering
You will not need to replace rear toe links at a 1 inch drop. That said, I really don't like the stock toe links.
Alignment specs will depend on spring rates and tire choice. You will want more camber than that if you track your car.
- Andrew
Old 06-14-2018, 11:32 PM   #194
ZDan
ZDan's Avatar
Drives: '23 BRZ
Rear LCAs, why does everybody think they need these? You don't. Front camber plates would be a good move though.
Old 06-15-2018, 01:42 AM   #195
churchx
churchx's Avatar
Drives: 2014 GT86
Because Rear LCAs is cheapest way to add camber adjustment in rear with sufficient range (i don't count "unofficial" H&R camberbolt usage in rear as much of an option, as due small range they can do only for evening out. Nor do i count as "cheaper" eccentric whiteline bushings, as installing them and/or adjusting with them is PITA and savings on a bit smaller price go down the drain paid on alignment tech time/work)?
Or you wanted arguing that getting alignment in rear or upping camber in rear aswell for track use is not needed? Sure not needed, if one doesn't want to get max grip and even tire wear.
finch1750 (06-15-2018)
Old 06-15-2018, 12:57 PM   #196
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Beyond what Church said about rear LCAs (which is spot on), I would also point out that camber plates are required.
I can easily achieve -3 front with camber bolts and a slotted strut on my set-up (and never had slippage in 100k+ miles between slotted and non-slotted struts). And I don't have to worry about bearings or whatever else up top needing to be serviced while enjoying a softer ride with my OEM top hats.
But camber plates may be best for some people. Suspension is a very individually defined set-up based on goals and driver preference to get the adjustability needed for the intended purpose while keeping/sacrificing comfort level.
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-10-2012 12:36 AM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 01:29 AM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 12:41 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
