Old 04-10-2018, 10:36 PM   #309
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
well looks like my 2017 v4.02 stage 2+ finally got the CEL for the rear o2 sensor. Looks like a v4.03 was just uploaded I hope this issue was addressed.
SuperTom is offline   Reply With Quote
Old 04-10-2018, 10:47 PM   #310
Jasonb
Drives: 17 Series Yellow BRZ
Your calid K00C? Let me know if the V4.03 is actually any different.
Edit: shiv says there will be no difference. Just added the K00D (2017 auto) calid.
Jasonb is offline   Reply With Quote
Old 04-10-2018, 11:12 PM   #311
SuperTom
SuperTom's Avatar
yes I'm K00C. It popped up while highway cruising, didn't affect drivability or anything
That sucks is he aware of the issue? It would be great if someone on here could turn it off in the file as its gonna take forever waiting on Shiv
Old 04-10-2018, 11:36 PM   #312
Jasonb
What code did you get? What issue do you think he needs to be aware of?
Old 04-10-2018, 11:49 PM   #313
SuperTom
SuperTom's Avatar
P2270. I though I read a few pages back someone else had one popup
Old 04-11-2018, 12:00 AM   #314
Jasonb
https://www.yourmechanic.com/article...by-jay-safford
Says lean. It's not the cat efficiency code.
Old 04-11-2018, 09:31 AM   #315
SuperTom
SuperTom's Avatar
from that page
"Code P2270 is an indication that the O2 sensor does not detect the catalyst efficiency and can cause the vehicle to fail an emission test."
I cleared it for now I will see if it pops back up again
Old 04-11-2018, 10:29 AM   #316
Jasonb
from that page
P0420 is the typical cat efficiency code. That's the one that is normally disabled in a tune.
Old 04-11-2018, 10:34 AM   #317
bababooey
Drives: BRZ SWP Limited -6MT
My guess is because of the cold start delete.
cold start adjusted the initial timing and lowered the rev per temperature
bababooey is offline   Reply With Quote
Old 04-11-2018, 11:11 AM   #318
Jasonb
I remember people toying with removing the cold start and getting camshaft and crank sensor codes. The timing adjusted is cam timing.
The Following User Says Thank You to Jasonb For This Useful Post:
finch1750 (04-11-2018)
Old 04-11-2018, 12:42 PM   #319
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Anybody gotten a P0016 code on the v2.076 E85 tune? I used that tune a long time and only started getting it about a month ago. Even after clearing the code with the OFT it always comes back pretty soon after. I recently flashed to the v4.01 tune which made the P0016 go away completely. So, now I'm wondering if there's something actually wrong with my camshaft or if it was just tune related? My car runs great and I haven't noticed anything weird while driving, so I'm hoping it's just something with the older tune.
smg1138 is offline   Reply With Quote
Old 04-11-2018, 01:21 PM   #320
stlgrym3
Not sure if it’s related but since I flashed v4.03 Stage2+ I noticed tech goes up to 2k and the car shooks a little like rough idling for one split second after I shift into gear after warmed up the car. After that split second all comes back down to normal. I always warm up the car in the morning for a good minute or two until tech goes down to around or below 1k before shift into gear.
stlgrym3 is offline   Reply With Quote
Old 04-11-2018, 01:39 PM   #321
tomm.brz
Drives: brz 2017 hksv2
car has a little "dip" of idle when it finishes the cold start and switch the ignition timing from 0 (set by v4 tunes) to the normal timing of about 10
there is also a dip when the VVT activates, not something to worry about
Old 04-11-2018, 01:42 PM   #322
stlgrym3
It wasn’t really a “dip”, the car was idling around 1k rpm after I finished warming up the car, but when I shift into gear the tech would spike up to 2k rpm for a split second while the car shooks a little then all go back down to normal after that quick split second.
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
