Old 03-23-2018, 03:47 PM   #1
FryinBerries
FryinBerries's Avatar
How can I make these fit?
I bought some wheels that are 17x8 +30 after searching for a while and I thought they were a different style but the same specs as the wheels I was looking at immediately prior. (Which were 17x8 +35) I really like these wheels and want to make them fit but don’t want to have them mounted if they’re not going to work.
How low would I have to go to make them work? Can I use springs?
Can I just add some camber without lowering? (Minimal amount of camber, not really a fan of that look)
They will be paired with Federal 595ss 215/45r17
(They run a little wide so it’s closer to a 225)
Yeah yeah I know they’re reps but that’s besides the point. I’m on a budget.
TIA
FryinBerries is offline   Reply With Quote
Old 03-23-2018, 03:58 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The wheels will fit just fine. Flush in the back, slight poke in the front. I am not a fan of those tires, but they will work too. I like higher tread wear tires for the street, because they last longer. I'm running 300 UTQG MPSS.
You will be able to lower your car with springs no problem. Get camber bolts.
I have 18x8 +35 front with a 225/40. -1.5 front camber. There is enough room for a +30 offset 8" wheel with a 225 tire.
I LIKE TIRES!
Old 03-23-2018, 04:02 PM   #3
FryinBerries
So no problems with stock suspension? The dealer was saying it might have an issue with the fender but if not that’s great. I’m keeping my stocks for winter so they won’t be on year round to make them last a little longer. Thanks a lot!
Old 03-23-2018, 04:11 PM   #4
FryinBerries
I don’t want to lower/add camber but I will if I NEED to
Old 03-23-2018, 04:12 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No problems with stock suspension. The wheel will fit flush in the rear. The front will fit without rubbing at stock height. If (when) you lower your car, get a set of camber bolts for the front. They are inexpensive ($15-$25 depending on brand) and fairly easy to install. I installed mine in a few minutes.
I am pretty sure that the pics in the first post for the front wheel will show the approx. amount of poke. (or flushness) The front is a 18x8 +30 with 225 tire.
http://www.ft86club.com/forums/showthread.php?t=26178
I LIKE TIRES!
Old 03-23-2018, 04:29 PM   #6
FryinBerries
Awesome thanks everyone. Looks like I’m getting them mounted tomorrow and will have them up w/ pics as soon as this snow is gone. “Spring” in NJ :eyeroll:
Old 03-23-2018, 04:35 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I had to look up what you wrote... LOL! So I made a meme!
via Imgflip Meme Generator
I LIKE TIRES!
Old 03-23-2018, 04:36 PM   #8
FryinBerries
Lol trying to fit in with the forum lingo thanks again
The Following User Says Thank You to FryinBerries For This Useful Post:
Leonardo (03-23-2018)
Old 03-23-2018, 05:19 PM   #9
FryinBerries
Will I also need to order hubcentric rings?
Old 03-23-2018, 05:25 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I use them. They are inexpensive. They center the wheel on the hub. Otherwise you rely on the lug nuts to center the wheel.
I LIKE TIRES!
Old 03-24-2018, 02:39 PM   #11
FryinBerries
No fitment issues, I love them. Thanks for all the help.
Leonardo (03-24-2018)
Old 03-24-2018, 03:23 PM   #12
FryinBerries
I also realized when I was putting them on that they’re 32 offset. The seller mislabeled them
Old 03-26-2018, 11:30 AM   #13
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
looks nice, now needs a drop lol. can you post up a picture from the front/back looking head on to see fitment and poke?
JustSomeGuy is offline   Reply With Quote
Old 03-30-2018, 11:12 AM   #14
FryinBerries
Drop will come in due time.
Rear
Front
Wheels may be slightly turned but they poke out about 1/4 inch
Might just be me,just want to make sure Grimm0ne Issues | Warranty | Recalls / TSB 6 04-30-2015 09:18 PM
They Don't Make 'Em Like They Used To Tcoat Other Vehicles & General Automotive Discussions 30 01-25-2015 09:06 PM
You can't make this up meeskee2 BRZ First-Gen (2012+) — General Topics 5 03-18-2014 11:14 AM
Just want to make sure Moonbase Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-16-2013 04:02 PM
