Old 03-27-2018, 11:39 AM   #225
timmydatooth
Drives: Scion Frs
Originally Posted by John27 View Post
I am running v4 tunes no cel has came up
mine popped up after driving about 50 or so miles. Steve was saying something about they forget to disable the p0420 CEL code in the tune...just waiting on an answer to see if this has or will be fixed or not...I am still currently driving on the v4 tune but just hate that the CEL comes on
timmydatooth is offline   Reply With Quote
Old 03-27-2018, 12:21 PM   #226
ricebox
Drives: AE86 & GT86
@timmydatooth It is because you're running a catless header tune and the OFT guys forgot to add the def to disable the P0420 code. Just add the missing def that @elBarto mentioned on page 12.
BTW what calid are you running?
ricebox is offline   Reply With Quote
The Following User Says Thank You to ricebox For This Useful Post:
elBarto (03-27-2018)
Old 03-27-2018, 12:27 PM   #227
John27
Drives: scion fr-s
I drove my car 80 mile no cel code yet when you download tune from what file did get from oft v4.01 xmls or za1j_d roms us6at
John27 is offline   Reply With Quote
Old 03-27-2018, 12:30 PM   #228
John27
Drives: scion fr-s
I am running stag 2 cause I have uel catted header
Old 03-27-2018, 12:44 PM   #229
timmydatooth
Drives: Scion Frs
here is my cal id <ZA1JA01D.ori> is it hard to add the missing def? I really don't know about messing with and tweaking tunes. I might just wait for shiv to correct this before I attempt to do it myself.
Old 03-27-2018, 03:38 PM   #230
ricebox
Drives: AE86 & GT86
@timmydatooth I pm'ed you the file with the correct def already added with the calid A01D.
timmydatooth (03-27-2018)
Old 03-27-2018, 05:45 PM   #231
elBarto
elBarto's Avatar
Drives: Toyota GT86
I've created these for some guys on the facebook group, since I didn't get any angry PM's, I suspect they work :
OFT V4 D00D def
OFT V4 A01D def
Also 'made' this how-to:
It's not that difficult to make these actually, It's just a A01I def file which is modified to the corresponding calid
For anyone els with a 2012-2016 AT, use the above D00D def, open it, Change ZA1JD00D (2 times) to your corresponding Calid (ex: ZA1JA01D), save it with a obvious name (ex: V4-A01D.xml) and remove the old one in RomRaider.
Same applies for the MT files, use a A01G def file (Steve99, Kodename47 or Wayno's) and edit to your correct calid.
=> Does NOT work for the 2017 <=
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-27-2018, 06:22 PM   #232
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've gone 200+ miles on the Stage 2+ E85 (B01C) tune and haven't gotten a CEL yet. Am I good or do I need to make any edits?
smg1138 is offline   Reply With Quote
Old 03-27-2018, 07:03 PM   #233
Teseo
Drives: frs
Most problem arise at -100miles, i have same cal id as you but im using regular stage2+ and everything is good so far. The car is damn good now, is like driving a new car
The Following User Says Thank You to Teseo For This Useful Post:
smg1138 (03-27-2018)
Old 03-27-2018, 07:25 PM   #234
steve99
Drives: FT86
Originally Posted by timmydatooth View Post
Sorry but I really don't know about defs and tunes too well. I just put them on my OFT and write them to my car. Is shiv and the OFT guys fixing this for the v4 tunes? Is it better for me to just switch back to the v2.076 tunes just so that I do not get that CEL to come on anymore? Just don't want to leave the v4 tune on if it is hurting my car...
P0420 wont hurt car, its just annoying and will mask other real issues that may occurr
Old 03-27-2018, 08:38 PM   #235
Xbk47
Drives: 2016 BRZ
Is there a new template file and if so where would I find it? I have FRS Template 8.2.
Xbk47 is offline   Reply With Quote
Old 03-27-2018, 08:43 PM   #236
irxproductions
irxproductions's Avatar
Drives: 2013 FR-S, 2015 Speed Triple
Does anyone know the ECU code for toggling the Daytime Running Lights on/off?
irxproductions is offline   Reply With Quote
Old 03-27-2018, 09:12 PM   #237
timmydatooth
Drives: Scion Frs
hey so I just noticed this driving on the way home that since I updated to the v4 tunes whenever I am slowing down to a complete stop and my car is shifting down (I have an automatic by the way) I notice that my car will jerk a little bit while slowing down before I stop all the way. Never had this issue when I was using the v2.076 tune so can this be because of the v4 tune? could it be throwing the shifting off? Accelerating it shifts smoothly it only has that slight jerk when I am slowing down to stop...anyone else experiencing this with the new tunes? I have a 2013 Scion FRS automatic using the stage2+ tune.
Old 03-27-2018, 09:35 PM   #238
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by Kodename47 View Post
Just so the info is here as well.
The Stage 1 MT has 10 changed tables:
2x MAF Correction After Start (Cold Start Adjust)
5x Idle Speed Changes (Cold Start Adjust)
Target Throttle Plate Angle (Only changed above 6400)
Ignition Timing Post Start (Cold Start Adjust)
P0420 Code is disabled
The Stage 2 has, in addition:
Open Loop Fueling (Richer at high load low RPM, Leaner at high load high RPM)
LTFT Limits (Reduced to +/-2%)
Base Timing B (Less Timing at high load high RPM)
Knock Correction Advance (More Timing at high load high RPM)
Timing Comps Per Cylinder A & B (Now all 0)
FBKC Range (Enabled now set above 3k RPM)
Intake and Exhaust AVCS Changes
The AT is pretty much the same as the above, just no P420 defined and P0700 code is disabled.
Confused as to what makes an aftermarket catted header different than stock header. By stage 2, do you mean stage2+? Could one theoretically run stage2 on stock header? Maybe with the avcs tables from stage 1 since it's optimized for stock header?
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
