Old 03-26-2018, 09:30 PM   #1
Skurj
Drives: SOLD...
Exhaust... lightweight and not stupid loud...
Likely been asked a ton of times...
Aiming to go from header back (EL with cat) looking for the lightest i can get, don't care single exit is fine, that won't be stupid loud as some tracks in the area have db limits...
Plan to use car for autox and time attack duty as finances permit...
At the same time, while i don't mind spending 1-2k on the header, I don't wish to spend another 2k+ on the rest made of Ti...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 03-26-2018, 09:49 PM   #2
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
CSG Touring86 exhaust. It'll handle all of your flow requirements while acting as a mild diffuser, mature exhaust note (won't bother neighbors, makes cold start very tame), and won't break the bank.
It's one of your best options for track db limits while maintaining flow.
ajcarson11 is offline   Reply With Quote
Old 03-26-2018, 10:35 PM   #3
Skurj
Drives: SOLD...
well that's a new one I have never heard of...
Paid for Mar 2018
Old 03-26-2018, 10:42 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
36 lbs.....
Old 03-26-2018, 10:48 PM   #5
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I have a Blitz Nür Spec R stainless steel exhaust that I think may fit your requirements - it’s reasonably quiet, sounds great with my ACE 4-2-1 Type-A 350 equal length header, and is a lighter than most exhausts. Overall, it’s exceeded my expectations and I’m a pretty tough customer. Check out post numbers 8 and 9 in the following thread to read a little more about it and to see photos on and off my car:
http://www.ft86club.com/forums/showthread.php?p=3042298
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
Skurj (03-27-2018), TofuJoe (03-27-2018)
Old 03-26-2018, 11:17 PM   #6
ajcarson11
Originally Posted by Summerwolf View Post
36 lbs.....
That's lighter than stock -- keeping the noise down isn't going to be light. People get so caught up in saving 2 or 3 lbs... No way its going to matter. And if it really does, then you better have a lot more cash to burn.
Old 03-27-2018, 07:15 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Sure, but there are lighter options that are reasonably priced and still keep the DB levels reasonable. Lighter does not neccesarilly mean loud or exotic materials.
Old 03-27-2018, 09:14 AM   #8
Skurj
Drives: SOLD...
That one was already on my shortlist, thanks
Paid for Mar 2018
Old 03-27-2018, 12:49 PM   #9
Submarinesonce
Drives: Frs
tanabe concept G is light and reasonably quiet if you keep a cat or 2...
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
The Following User Says Thank You to Submarinesonce For This Useful Post:
yberther (10-19-2018)
Old 03-27-2018, 01:22 PM   #10
stlgrym3
I recommended CSG touring as well. I’ve heard it in person and it sounded so subdue at idle with slight hinting of deep tone. I would’ve gotten that if I hadn’t installed the greddy sp supreme already.
stlgrym3 is offline   Reply With Quote
Old 03-27-2018, 02:03 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Feel free to start suggesting them then...
Far as I can tell, <30 lbs for a catback and a catless header is a recipe for blowing sound at most venues.
ineedyourdiddly
Old 03-27-2018, 02:15 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You need 2, or possibly if 1 it has to be in the header. Catless header with catted front pipe is still loud AF
NoHaveMSG (03-27-2018)
Old 03-27-2018, 02:16 PM   #13
RJasonKlein
Great - it’s a really good piece and worthy of consideration. One thing that should be noted (but is probably not a big deal for you as an autocrosser) is that without a diffuser to cover up the vacancy from removing the factory exhaust, aerodynamics at the rear are somewhat adversely affected. It’s not huge, but it is noticeable. In my opinion, particularly on a track car that sees high speed, that’s an area where the @CounterSpace Garage Spec MXP Touring86 has a real advantage over the Blitz Nür Spec R.
Last edited by RJasonKlein; 03-27-2018 at 08:49 PM. Reason: Corrected the typo graphical error.
Old 03-27-2018, 03:12 PM   #14
CSG Mike
CSG Mike's Avatar
Such as?
I'm all ears if there's another option that will pass a 90/96 dB test catless, other than the Laguna 90.
The Touring86 is already proven to support a 500hp level of flow. It's certainly not the lightest, but there's no way to reduce noise without weight.
It's kind of like having to add weight to add more braking thermal capacity.
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
What is an loud exhaust Harvir Engine, Exhaust, Transmission 36 10-04-2017 03:12 AM
Exhaust Advice. I want a loud exhaust system please help Rambo2469 Engine, Exhaust, Transmission 28 04-21-2017 02:41 PM
How loud is the n1 exhaust? ( in db) jon2 Scion FR-S / Toyota 86 GT86 General Forum 7 02-22-2015 03:04 AM
My exhaust is loud mike2100 Mid-Atlantic 1 08-25-2013 09:13 PM
