Old 03-25-2018, 12:23 PM   #197
BTXP.XD
Drives: 14' FRS
Hey Guys,
I tried this tune for about 100km and a CEL popped up, read it, OFT says its p0420.
Have 2013 FRS with catless headers and OEM FP using stg 2 + tune right now. I am using the A01D file. Anyone else having this issue?
NBeyond
https://www.instagram.com/nbeyond__/
Support us for daily cars + upcoming clothing line.
BTXP.XD is offline   Reply With Quote
Old 03-25-2018, 12:42 PM   #198
churchx
churchx's Avatar
Drives: 2014 GT86
Weird. It shouldn't affect anything usability wise (except disabling cruise control), but it is cat efficiency check, that should be disabled in tune (you mentioned stg 2+ after all) that is made for catless headers.
Old 03-25-2018, 01:14 PM   #199
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by BTXP.XD View Post
Hey Guys,
I just opened up that file in rom raider and P0420 is not defined in the DTC list. I would email Shiv and let him know.
Edit: It is not in the regular stg 2 tune either.
https://www.dropbox.com/s/e1ttb2kd42...%20SS.JPG?dl=0
Old 03-25-2018, 02:04 PM   #200
elBarto
elBarto's Avatar
Drives: Toyota GT86
For all 2012 - 2016 AT owners, add this to your definition for the P0420 option:
On top:
Code:
<table name="(P0420) CAT EFFICIENCY BELOW THRESHOLD" storageaddress="11C224" />
(open the def with notepad++ search for P0390, paste below it)
Bottem:
Code:
<table type="Switch" name="(P0420) CAT EFFICIENCY BELOW THRESHOLD" category="Diagnostic Trouble Codes" sizey="1">
<description>CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD (BANK 1). To disable this DTC, make sure the box above is unchecked. Off-road use only.</description>
<state name="on" data="01" />
<state name="off" data="00" />
</table>
(again, search for P0390, paste underneath the </table>)
Does NOT work for 2017 AT
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
finch1750 (03-25-2018)
Old 03-25-2018, 06:32 PM   #201
steve99
Drives: FT86
Hey Guys,
Soimds like the oft guys missed disablimg P0420 cat efficiency code, should be able to disavle it eith correct def and romraider
Old 03-25-2018, 09:19 PM   #202
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
First off, many thanks for releasing new tunes for our cars and continuing support without upgrade fees or anything.
It's been at least a year since I last updated the tune on my car (stage 2 catted UEL, 91) to this version 4, everything feels good so far, butt dyno hasn't felt much difference, but it does seem smoother and quieter, which for me is a good thing.
Question: On the computer software side, I updated the manager and everything seems fine. However, I've noticed that it still shows the older HW and FW versions when I upload or connect the tablet to the computer. It does show the latest HW 1.35 and FW 1.50 on the tablet and upper right of the program. What gives? Did I not update it right? Or nothing to worry about?
pinetree is offline   Reply With Quote
Old 03-26-2018, 12:57 AM   #203
steve99
Drives: FT86
Those numbers show the hardware and software revisions of the oft tablet itself.
You will need to download the v4 tunes from pft downloads page and then upload to tablet with openflash manager software
See oft tips link below
Old 03-26-2018, 01:37 AM   #204
steve99
Drives: FT86
Added some corrected defs for V4 auto and manual tune 2012-2016 cars, the the first post in this thread
If you need to alter some tables not correctly defined the the OFT V4 2012-2016 tune see the attached definitions
Ignition timing idle in gear/neutral
or fix P0420 code not defined
maf after start tables
and a few others
You will need to open def in text editor for auto or manual as required and edit the calid string to your particular rom id like B01C or B01D as all V4 tunes are based on A01G or A01I roms now for 2012-2016 cars
DO NOT use these DEFS for 2017+ cars they are based on different rom base
The Following 2 Users Say Thank You to steve99 For This Useful Post:
D_Thissen (10-09-2018), Weigaldo (03-26-2018)
Old 03-26-2018, 11:51 AM   #205
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I think I already know the answer, but I wanted to confirm. The tune runs fine without these tables being in the definition right? They would only be needed if editing was desired?
Weigaldo is offline   Reply With Quote
Old 03-26-2018, 12:14 PM   #206
pinetree
pinetree's Avatar
Thanks steve99, I thought I did though? You can see the two pictures where the manager app on the upper right it shows the latest versions, and the tablet itself shows the latest version as well.
When I opened the manager app it updated itself, then I went to the oft website and downloaded the latest tunes. Connected the tablet, it went through what seems like an update, then I deleted the old tunes and uploaded new ones. Updated car and everything shows fine, when I connect tablet to car it shows it has V4 tune.
Did I miss a step? Or should I delete everything and start over?
Thanks
Old 03-26-2018, 03:25 PM   #207
timmydatooth
Drives: Scion Frs
So after driving around with the new V4 tunes on my 2013 Scion FRS AT I can say there are some noticeable differences. The loud cold start is pretty much gone now. The car shifts a little smoother overall. Don't really notice any difference in the torque dip but still glad that I updated to V4.
timmydatooth is offline   Reply With Quote
Old 03-26-2018, 07:19 PM   #208
steve99
Drives: FT86
Yes all tables are actually in all tunes.
The definition just allows you to see them and edit correctly
A def is just an index into thte tune file
Old 03-26-2018, 07:21 PM   #209
steve99
Drives: FT86
Thanks
Sounds correct to me
Old 03-26-2018, 07:44 PM   #210
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
anybody know if we can still modify timing like in the older tunes to support the Crawford PowerBlock?
my car is in storage right now so i can't test it, but i wonder if it could interfere with any new modification done to the V4 tune
Walla Walla is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
