Old 03-20-2018, 12:14 AM   #43
steve99
Drives: FT86
Originally Posted by stlgrym3 View Post
I read you posted earlier that Shiv should have a Fox by tomorrow. How do I apply the new fix to my tablet, I assume download from OFT website?
when the fix comes just download the new v4 version.
you could use the V3 K00D if you can get them
Old 03-20-2018, 12:24 AM   #44
stlgrym3
If that’s the case then I hope my tablet was shipped with the older stock ROM then lol
stlgrym3 is offline   Reply With Quote
Old 03-20-2018, 04:24 AM   #45
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
Would Shiv release the V4 for Asia/Australia calid ?
pym19109 is offline   Reply With Quote
Old 03-20-2018, 05:18 AM   #46
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
For those with a 2017 AT...
Originally Posted by Shiv Pathak, From Facebook
I removed K00D file from the download folder due to a bug that is currently getting fixed. This only pertains to K00D (2017 6at) so of that applies to you, pls go back to the previous OTS version of the tune. Should have a fix for it later this week ��
And a couple people on FB are having issues installing the update and getting the new tunes. https://www.facebook.com/photo.php?f...&theater&ifg=1
Originally Posted by Shiv PathakShiv, From FB
is an administrator in this group. Your anti virus is preventing a full installation. Delete the entire OpenFlash Folder on your C drive, disable your anti virus and then re-install. That should solve your issue.
guybo is offline   Reply With Quote
Old 03-20-2018, 06:41 AM   #47
g0lds
Drives: 14 BRZ Limited
Always use defs that come with tune pack, remove your old defs
This fixed it, thanks
g0lds is offline   Reply With Quote
Old 03-20-2018, 09:53 AM   #48
jslack
Drives: 2017 Red subaru BRZ Limited
I just ordered the tablet, header and overpipe from OFT for 2017 MT. Since I have no previous experience with tuning. I hope I should just be able to install everything and run the tablet to the stage 2+ and be good?? Or would the tablet come with the old tunes on it? Sorry for my newbness. THanks group.
jslack is offline   Reply With Quote
Old 03-20-2018, 10:10 AM   #49
Jasonb
Drives: 17 Series Yellow BRZ
Idk if it'll come with any tunes already loaded on it. They are easy to load onto the OFT though.
Jasonb is offline   Reply With Quote
Old 03-20-2018, 11:57 AM   #50
keenmachine
Drives: '14 WRB BRZ
Are these E85 tunes still safe for ethanol content between E60-E90? Around here E70 is pretty much the best we have.
keenmachine is offline   Reply With Quote
Old 03-20-2018, 12:36 PM   #51
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
a default advance multiplier of 0.70 instead of the usual 1.0. This allows for learning ability based upon octane. Make sure you use a PREMIUM grade fuel because these tunes are aggressive and run strong!
Just so I understand, will this just start out at .70 after initial flash, or will it be .70 every time you start the car?
Weigaldo is offline   Reply With Quote
Old 03-20-2018, 01:16 PM   #52
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
From what I've read it's every time you start your car. Maybe just cold start? Essentially it's a safety precaution and should be up to 1.00 or close to it by time your car is fully warm (if running 93). I'll be trying out the V4 on my FRS tonight so I can verify but this is my understanding so far.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
Weigaldo (03-22-2018)
Old 03-20-2018, 01:22 PM   #53
guybo
Huge E85 fan!
guybo's Avatar
I did some data logging today. Just one highway log with some redline pulls and some WOT pulls at highway speeds. FLORIDA highway speeds ;-)
https://datazap.me/u/guybo/log-wot-p...-6-7-8-9-11-12
I did this last week too. This is from the same tank of E85 as last week, so this should be a great direct comparison even if some data channels weren't working
https://datazap.me/u/guybo/highway-p...-6-7-8-9-11-12
Old 03-20-2018, 01:32 PM   #54
Lantanafrs2
Drives: 2013 frs red
I just loaded v4 e85 tune. Put 20 miles on it. Idle and throttle response starting to come around. Lol
Lantanafrs2 is offline   Reply With Quote
Old 03-20-2018, 01:40 PM   #55
stlgrym3
Newbie question on E85. Are there abundant E85 stations around SoCal? Can I go back and forth bwtween petro and E85? If so how easy is it
Old 03-20-2018, 02:02 PM   #56
guybo
Huge E85 fan!
guybo's Avatar
Originally Posted by Open Flash Performance
stage 1 stock header
I'm confused. The Stg 2+ E85 tune is supposed to be safe for the stock header with the cat intact.... so why isn't it labelled Stg 1 E85?
The Following User Says Thank You to guybo For This Useful Post:
smg1138 (03-21-2018)
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
