Old 03-19-2018, 11:08 PM   #113
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Evening All,
Just received/installed this catback and the exhaust itself looks great and was well packed. Install was easy until I finished up and noticed that the passenger's side tip was very mis-aligned. I took the entire exhaust back off the car twice, adding one piece back into the mix at a time and I'm still unable to get the passenger's side to sit properly. The tip is just a few millimetres from touching the plastic bumper cutout, while the driver's side sits perfectly in the middle of the cutout.
Here is the passenger side:
Even with all of the piping disconnected (and the muffler just sitting on hangers) i have to put a substantial amount of downward force on the front right hanger to get the exhaust to sit properly -- so it appears to be an issue with where the hangers were welded onto the muffler. I've messaged CSG on this.
I should note that i'm running a UEL catless header with stock front pipe and overpipe.
I wouldn't normally care too much about a misalignment of the tips, but for $869 I really want things to be right.
ajcarson11 is offline   Reply With Quote
Old 03-20-2018, 01:23 AM   #114
JoeeStacks
Drives: Brz
Originally Posted by ajcarson11 View Post
Evening All,
I should note that i'm running a UEL catless header with stock front pipe and midpipe.
I don’t have this exhaust, but it looks like there is a pipe that you could twist to make it align properly. A common alignment problem on the Perrin exhausts.
Originally Posted by CSG David View Post
Slip joints used to make the fitment dead on. Some cars have different bumpers and not all of them fit perfectly. This exhaust allows the adjustments at multiple points to make the exhaust fit "perfectly" given a specific vehicle.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 03-20-2018, 08:22 AM   #115
ajcarson11
Thanke Joe -- I've just read through the Perrin installation instructions, and all of the threads I can find on Perrin alignment. A common theme that I see with the perrin alignment is that folks can get things to line up when there is no pressure on the muffler (meaning that all clamps are loose).
Even with the muffler just hanging (with no other piping connected to it) I have to put a lot of force on the muffler (stretching the rubber hangers) to get the passenger side close to correct fitment. I'll play with it more today, but i'm not sure how the piping could even put enough pressure on the muffler to correct this (I have to put some muscle into pulling down on the muffler while laying under it to get it close to correct).
EDIT: I'm also going to try just removing the front right rubber hanger completely. That may help as it seems to be the one that needs the most stretching to make things fit properly.
Old 03-20-2018, 09:55 AM   #116
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
That's funny. I just got an MXP Comp RS exhaust a couple months ago and the passenger side was misaligned by a LOT. I mean it was almost touching the exhaust hole cutout in the bumper. Ordered it from 86speed .. had to bring it to a muffler shop because I don't have a torch. They heated it up and bent it back into place then reimbursed me the hour labor.
Edit: I know it's not the exact same exhaust, however, it was manufactured by the same company.
Jesse36m3 is offline   Reply With Quote
Old 03-20-2018, 09:57 AM   #117
ajcarson11
Thanks Jesse -- I don't know for sure yet, but I'm going to guess I may be in the same boat. The passenger side is just a millimeter or two from touching the exhaust hole cutout.
Old 03-20-2018, 10:21 AM   #118
Kordless
Drives: '13 BRZ Limited
Hi aj, I have this same exact exhaust and mine fits fine.
There are 14mm (I believe) bolts on top of each of the tips. You can loosen those and you can adjust the tips until they fit perfectly. Don't forget to torque to 30 ft/lb
If that isn't the problem, try adjusting the clamps on the right hand side of the exhaust.
But if it's truly an issue with the hanger, none of these will work.
2019 Mazda MX-5 RF
2013 Subaru BRZ - SOLD
Instagram - @uwuboiz
Kordless is offline   Reply With Quote
Old 03-20-2018, 11:09 AM   #119
ajcarson11
Thanks! I did try adjusting the tips.. not much improvement.
When you say 'clamps on the right hand side of the exhaust' what are you referring to? Did the kit come with hanger clamps (to allow extra positioning of the rubber hangers)?
Old 03-20-2018, 11:18 AM   #120
Kordless
It's been a while since I've installed mine, I meant this clamp here:
2019 Mazda MX-5 RF
Old 03-20-2018, 11:59 AM   #121
coxxoc
I also have this exhaust and have the same issue with the passenger side fitment as ajcarson11. I wrote it off as being a cheaper exhaust that sound great. It was only 70% of the price of the Apexi RS Evo Extreme it replaced and the quality of finish shows that. I wanted this exhaust to stop the bark at startup and rasp during WOT I experienced with the Apexi unit. Objective accomplished.
I'll have a muffler shop adjust the hanger position on the passenger side. It is a simple cut and weld fix. Minor adjustments/modifications are par for the course in automotive aftermarket. I'm very happy with the system overall.
coxxoc is offline   Reply With Quote
Old 03-20-2018, 01:23 PM   #122
ajcarson11
Here are some more photos of the situation. I took a look under the car again at it today -- All things considered I believe it to be a hanger misalignment. I removed one hanger and it didn't make any difference -- So i'd imagine at least 2 hangers have to move.
Old 03-20-2018, 02:33 PM   #123
CSG David
CSG David's Avatar
We worked with MXP on this and the muffler is developed completely different from all their other systems.
Send me some photos at david@counterspacegarage.com. I'm interested in collecting this information. Thank you!
Old 03-20-2018, 02:36 PM   #124
CSG David
CSG David's Avatar
Please send to my e-mail at david@counterspacegarage.com. I had a look on our messages and something is not right. Thank you for your patience and cooperation!
Old 03-20-2018, 03:46 PM   #125
ajcarson11
Sent. Thanks David.
Old 03-20-2018, 05:30 PM   #126
coxxoc
Done. Thanks for taking the time to provide ongoing support of the platform and your products.
OS Giken Grand Touring Mono Hard clutch review ofuts Forced Induction 10 10-04-2016 01:56 PM
RCE Tarmac 2 Review/Competition Log forwallblakmail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-20-2016 07:17 PM
Essex Designed AP Racing Competition Endurance Brake Kit - Review and Install R2RO Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-26-2016 05:38 AM
DIY-TANABE MEDALION TOURING CATBACK INSTALL kinryu DIY (Do-It-Yourself) Guides 10 07-28-2014 11:05 AM
86 Tanabe Medalion Touring GA catback - Fitment pictures JDMC AUSTRALIA 26 07-09-2012 08:15 PM
