Old 03-19-2018, 03:45 PM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thumbs up
Patience is not my thing... so I went ahead and just put my faith in Shiv and loaded up the v4.01 E85 Stg 2+ tune.
The checksum error is just like in the old tune, no big deal- but the message is a little different this time. Just like before, I loaded up the new tune file and edited it (I updated the ECU Definition file in ROM Raider first) just like before. It all look identical to me, a non-tuner type of guy.
Opened up the new OFM after updating, it all looks identical to me. I hooked it up to my PC and (after the update) cleared up some old files and replaced with the new ones. Same as ever.
Hooked it up to the car and went through the same steps as before and loaded up the new tune file that I edited (changed FFS and LC and idle RPM). Same as before. The only thing that has really changed are that everything has to be updated and the tunes are new.
The new Stg 2+ E85 tune sounds great! No more cold start racket (my neighbors thank you, @shiv). The car has more pops and burbles than before (yess) FFS and LC worked fine. The car sounds different in general too. In the middle RPMs I hear some of that same sound I used to hear on the Stg 2 93 EL tune, with the more aggressive timing. Hopefully that means the erstwhile dip turns into a hill Everything sounds and feels great!
Thank You Open Flash Performance, @shiv as well as @steve99 and @Wayno (I know you guys were all involved in this!)
guybo is offline   Reply With Quote
The Following 7 Users Say Thank You to guybo For This Useful Post:
CxG (04-06-2018), DAEMANO (06-02-2018), Lantanafrs2 (03-19-2018), smg1138 (03-19-2018), Submarinesonce (03-19-2018), Teseo (03-19-2018), Tristor (03-19-2018)
Old 03-19-2018, 06:24 PM   #16
Submarinesonce
Drives: Frs
guess you've got to do a new dyno lol, thanks for being the canary. im going to load it on mine tonight.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 03-19-2018, 07:05 PM   #17
Teseo
Drives: frs
@guybo
Thanks for your report. Its posible you can do a dyno again but with new tunes?
Teseo is online now   Reply With Quote
Old 03-19-2018, 07:34 PM   #18
Firecruiser
Drives: 2014 brz
I'm looking at changes between the v2 b01d maps and the new v4 a01I based maps and it looks like some changes were made but others didn't make it into the AT maps. The rev limit was increased but the timing reduction in Base Timing B wasn't setup so it doesn't look like the AT maps have the soft rev limit setup but the rev limit was increased.
I'm wondering if its worth moving to the v4 tune and cherry picking changes from my v2 tune for some of the changes i've made previously or if i should just stick with my v2 tune that works.
Firecruiser is offline   Reply With Quote
Old 03-19-2018, 07:35 PM   #19
mrmamba
mrmamba's Avatar
Drives: GT 86 2017
Guys do U know if on this maps is included the soft rev limiter?
mrmamba is offline   Reply With Quote
The Following User Says Thank You to mrmamba For This Useful Post:
Old 03-19-2018, 07:37 PM   #20
Firecruiser
Drives: 2014 brz
On the manual map it is. On the auto it just looks like an increased rev limiter.
Old 03-19-2018, 07:44 PM   #21
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
@guybo How much of a difference to the cold start? I'm only running a high-flow cat in the whole line, so my cold starts are obnoxious. Is it completely gone?
Mad1723 is offline   Reply With Quote
Old 03-19-2018, 07:54 PM   #22
tomm.brz
Drives: brz 2017 hksv2
Since I see they put Ignition timing after start at 0 instead of the -19 we have in the original k00G tune in Europe, yes it is completely gone
0 of timing is very quiet start
Old 03-19-2018, 08:10 PM   #23
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Is there any downside to the cold start being disabled? From my understanding it was just to heat up the cats for emissions reasons, right?
smg1138 is offline   Reply With Quote
Old 03-19-2018, 08:16 PM   #24
tomm.brz
no downside at all
anyway 0 of timing is still a reduced timing setting, cause when the warm-up phase finishes, the normal timings are around 10
it's just not loud to hear, it has only a subtle drone a-like bark, you could modify and put -4/-9 (the more negative being louder) if you want to hear that sound a bit, but not too much.. or make it more negative untill say 20°C of coolant temperature and at >30° make it quiet
the high stock idle setting contributes also to the loudness, this tunes have it reduced
Old 03-19-2018, 09:19 PM   #25
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Bunch of people on Island are having problems with the push start button not working.
Old 03-19-2018, 10:05 PM   #26
steve99
Drives: FT86
Originally Posted by Firecruiser View Post
@steve99 An AT v4 tune is based on an ZA1J___I calid correct? I was previously using overrun to create an afterfire in the v2 tune. I see that it is defined in the defs included with the v4 tune but is marked as debug. Do you think it is safe to modify these debug tables? Or should i try to find a wayno def for the calid v4 is based off.
Other question, romraider has a way to diff two roms and see the changes in the tables, but I've only been able to do it if they use the same definition. Is there an easy way to do this when they don't use the same definition. Since I'm using a B01D definition and these are using A01I definitions.
I hope i'm making sense.
Yes auto tunes based on euro A01I roms
manuals based on A01G roms
this is for 2012-16 cars.
Some tables you will need to go to degbug level to alter.
you could use a wayno A10I def but you would need to alter it
when editing if you see weird values or table axis look weird stop def is wrong or mismatched
Old 03-19-2018, 10:06 PM   #27
steve99
Drives: FT86
Thier is problem with K00D auto rom dont use, shiv should fix it by tomorrow, was talking to him this morning about it
x808drifter (03-19-2018)
Old 03-19-2018, 10:07 PM   #28
steve99
Drives: FT86
yes soft limiter is enabled on manual, not sure on auto but its easy to add
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
