| Software Tuning Discuss all software tuning topics. |
Drives: FT86
OFT Openflash V4 tunes released for 2017+ with Launch/FFS
WARNING : USE THE V4 DEFINITIONS THAT COME IN V4 TUNE PACK, DO NOT USE OLD DEFINITIONS, CLEAR THEM OUT OF ROMRAIDER. note this only applies if your editing tunes you can ignore this if your just flashing the tunes directly If you need to alter some tables not correctly defined the the OFT V4 2012-2016 tune see the attached definitions Ignition timing idle in gear/neutral or fix P0420 code not defined maf after start tables and a few others You will need to open def in text editor for auto or manual as required and edit the calid string to your particular rom id like B01C or B01D as all V4 tunes are based on A01G or A01I roms now for 2012-2016 cars DO NOT use these DEFS for 2017+ cars they are based on different rom base Quote from Shiv " New v4.01 Beta tunes now available for all USDM GT86s (including 2017+ which now have Launch Control/Flat-Foot-Shift). These tunes have all sorts of update include cold start delete, remapped throttle tables, revised engine load limits, fully supported data logging channels and a default advance multiplier of 0.70 instead of the usual 1.0. This allows for learning ability based upon octane. Make sure you use a PREMIUM grade fuel because these tunes are aggressive and run strong! New OpenFlash Manager (v1.31) is also available for download as well "Petrol tunes suit both 91/93 but best performance on 93 stage 1 stock header Stage 2 aftermarket catted header Stage 2 + aftermarket catless header E85 for E85 fuel only Stage 2 + E85 for stock/catted or catless header http://www.openflashtablet.com/downloads/ OPENFLASH Support page http://support.openflashtablet.com/support/home https://www.facebook.com/groups/1861...4919683837216/ Last edited by steve99; 04-30-2018 at 11:51 PM. |
| The Following 20 Users Say Thank You to steve99 For This Useful Post: | BWilky (04-09-2018), CkOne (07-08-2020), DAEMANO (06-02-2018), EffaressNOOB (03-19-2018), H1C (03-19-2018), irxproductions (03-26-2018), jRuN (08-28-2018), mizzta21 (03-19-2018), NicFromTheNorth (09-07-2021), N_AL_spyder (04-05-2018), phrosty (02-14-2019), pinetree (03-25-2018), smg1138 (03-19-2018), Spuds (03-27-2018), supercommode (03-29-2018), SuperTom (03-19-2018), Teseo (03-19-2018), tomm.brz (03-19-2018), Tristor (03-19-2018), trvth (05-15-2018) |
#2 |
Drives: '15 BRZ RA
So the v3 beta tunes never went to official release and now we have v4 beta? What is the difference between the two?
#4 |
Drives: FR-S Whiteout
is it just me or are there 100 new tables???
Intent > Content
cowardice is the mother of cruelty. |
#5 |
Drives: FT86
#6 |
Drives: FT86
As always make sure you use definitons from the V4 tune pack to edit these V4 roms. They are based on Euro roms , not usa
#8 |
Badass Member
Drives: 2014 SWP BRZ Limited
#9 |
Drives: frs
Early models would see benefits of new tunes?
#10 |
Does the v4 tunes come with the new version 2 tablets? Or we have to download it separately?
#11 |
Huge E85 fan!
Drives: 2016 Scion FRS
Is the E85 tune good to go? I had read that the early versions had some issues.
#12 |
Huge E85 fan!
I updated OFM and using the latest template file, I edited the E85 2+ tune for idle RPM, FFS and LC. I got a slightly different but familiar checksum error in ROM Raider. Just like in the past, I hit OK and saved the tune and no probs.
Is that normal? |
#13 |
Drives: 2014 brz
@steve99 An AT v4 tune is based on an ZA1J___I calid correct? I was previously using overrun to create an afterfire in the v2 tune. I see that it is defined in the defs included with the v4 tune but is marked as debug. Do you think it is safe to modify these debug tables? Or should i try to find a wayno def for the calid v4 is based off.
Other question, romraider has a way to diff two roms and see the changes in the tables, but I've only been able to do it if they use the same definition. Is there an easy way to do this when they don't use the same definition. Since I'm using a B01D definition and these are using A01I definitions. I hope i'm making sense. |
#14 |
Drives: 2013 Raven FR-S
So, these are ok to use on my 2013 FRS? That's the way I'm reading it, but just want to be sure. I figured the 2017+ tunes would be totally different. I always run the B01C files on my car.
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 08:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 05:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 03:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 07:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 04:35 PM |
