Old 03-11-2018, 09:39 PM   #1
Cal3000
Drives: Panda FR-S
ECUTek Cable not reading OBDII Anymore
So all of a sudden my software wont connect. "No CAN Vehicle Interface Found"
When I plug the BUS into the car, the green light on the BUS lights up. Windows indicates that it finds a connection but wont find the ecu. My Windows updated recently. I updated the ECUTek software after the Windows update and it still wouldn't find the ECU.
Has anyone come across this issue?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-11-2018, 10:33 PM   #2
acro
Drives: GT-86
The OBD2 port can be a bit frail. I had that with my car as well and the dealer kindlysorted it out for me. U have to be very carefull when using it
acro is offline   Reply With Quote
Old 03-12-2018, 09:31 AM   #3
steve99
Drives: FT86
If ecutek software see dongle key it will run and get to state your in with RED indication in OBD and K line connection.
As soon as you plug in ecutek obd cable into pc (without car connection) those RED indicators should go green. If they don't cable has gone faulty or the drivers/software needs reinstall.
Try removing then reinstalling ecutek software (don't do this if you have a licience that has not been transferred to ecu) if still no go contact ecutek support
Old 03-12-2018, 04:25 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
You don't need the cable connected to the car. As said, when the cable is connected it should show the 2 status lights as green.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-15-2018, 02:31 AM   #5
Cal3000
Drives: Panda FR-S
I'll try to reinstall the software. I've been using ECUTek on this car since 2013 and this is the first time it decides not to work.
Old 03-15-2018, 02:51 AM   #6
acro
Drives: GT-86
Remember to check your OBD 2 port the fault may be there
Old 03-15-2018, 08:11 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
As I said before, whether connected to the OBD port or not, if the cable is connected to the laptop/computer then the two red lights in the screenshot below should go green
Try different ports or different computer if that doesn't work.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-15-2018, 05:14 PM   #8
woomis
Drives: 2016 FRS Release Series 2.0
Three Ideas:
- FTDI polling could be going on elsewhere and more aggressively in the background. Close everything or restart PC.
- Try a different USB port?
- Finally, run the setup.exe or setup-x64.exe found in c:\ecutek\VehicleInterfaceDrivers\ to reinstall the FTDI drivers for the vehicle interface. Re-seat the usb cable.
NOTE: You don't have to have the OBD-II side of the cable plugged into a car for those red indicators to turn green.
woomis is offline   Reply With Quote
The Following User Says Thank You to woomis For This Useful Post:
steve99 (03-16-2018)
Old 03-15-2018, 06:30 PM   #9
Tor
Tor's Avatar
Drives: Toyota GT86
Tor is offline   Reply With Quote
Old 05-20-2018, 05:55 PM   #10
FastWhite
Drives: Subaru BRZ Limited M/T
So, what was the issue with the Can bus?
I ask as i'm having the exact same issue.
FastWhite is offline   Reply With Quote
Old 02-18-2019, 11:42 AM   #11
sittok
Drives: White GT86
Did you able to solve this issue? Same problem here.
Ok. Just an update here. I have purchased a new obd2 scanner from OTC brand. It is OTC encore scan tool https://bestobd2scanners.com/otc-encore-review/. It came with all the necessary kits. Yesterday, I set-up everything, and it's working fine.
sittok is offline   Reply With Quote
Old 02-18-2019, 04:11 PM   #12
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I had the same issue and I ended up having to bend the ECUTek OBD2 pins in towards the center very slightly to get a solid connection. It could possibly be seeing the power pins but not the comm pins. Mine connects solid every time now.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
sroby (08-15-2019)
Old 02-18-2019, 05:43 PM   #13
steve99
Drives: FT86
As in earlier posts
1. If the ecutek software actually stsrts up and runs your dongle key is ok
2. If you get the two RED boxes in ghe ecutek window after the ecutek sotware stars with the ecutek obd cable pligged into computer only then its likely the ecutek cavle has failed. It doesnt need to be plugged into​ a car to go vreen, Green indicates ecutek software can see the ecutek cable
Old 08-11-2019, 01:01 AM   #14
Bert_BRZ
Drives: BRZ 2015 Edelbrock Supercharged
Just ran into this
Hit "Help" -> "EcuTek Update"
Run all the updates. I think all you need is the "Update Drivers & Help" but I just ran them all.
Bert_BRZ is offline   Reply With Quote
ECUTEK Cable w/Dongle OBDII no license MooKz Engine, Exhaust, Bolt-Ons 3 01-26-2017 06:01 PM
ECUTEK Cable w/ Dongle OBDII no license MooKz NY / NJ / CT / PA 0 01-18-2017 11:07 AM
FS: EcuTek OBDII Dongle mitim3 Audio/Visual, Electronics, Infotainment, NAV 10 12-01-2016 01:31 PM
*SOLD* Mini VCI OBDII cable for Toyota Techstream [NorCal] chas3wba0 Audio/Visual, Electronics, Infotainment, NAV 1 09-03-2014 03:54 PM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 08:17 PM
