Old 03-14-2018, 03:53 PM   #1
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Buy Parts Online and Pick Them Up At the Dealer?
I've only had my FR-S for a few weeks, so I'm still trying to get "caught up" on everything. In the VW world that I'm coming from there is a website where I can buy genuine OEM parts online, then pick them up from the parts department at the local VW dealer. You can search by name/part number, they have parts diagrams, etc. Is there anything like this for Subaru/Toyota?
I'm planning to replace the engine, trans, and rear diff oils since I don't know when or if they've ever been changed, so I need the crush washers and a filter. In the past when I've helped my buddy change the fluids in his '15 WRX the crush washers were impossible to find locally and the oil filter they tried to sell us was way too small. Since my FR-S basically has the same motor without the turbo, I'm assuming that I'll have similar issues trying to find the correct parts...
Face_Plant is offline   Reply With Quote
Old 03-14-2018, 03:59 PM   #2
GrantedTaken
I just look up stuff here.
https://parts.subaru.com/Subaru__BRZ.html
Then I call the local dealer on the phone.
GrantedTaken is offline   Reply With Quote
Old 03-14-2018, 07:03 PM   #3
Nobody has ever seemed to have an issue finding these parts.
If you have a couple of dealers check prices at each. Check both Toyota and Subaru since prices can vary substantially depending on what you are after.
Old 03-14-2018, 09:47 PM   #4
dnieves
Drives: FR-S 10 Series
Case in point: twins' special blue antifreeze is a lot cheaper at Subaru than at Toyota.
dnieves is offline   Reply With Quote
Old 03-14-2018, 09:56 PM   #5
Face_Plant
Face_Plant's Avatar
That seems like a good enough alternative. Thanks for the link.
I live in a small red neck town, so if you aren't driving a Ford or Chevy truck, then there's a good chance that the parts store won't have anything in stock for it.
Thanks, that's good to know for when it's time to replace the coolant.
Old 03-15-2018, 12:20 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I get WIX filters from the local NAPA autoparts store.
They can get crush washers too, but I replaced the plug with a FUMOTO valve.
They also carry Eneos oil.
Old 03-15-2018, 09:12 PM   #7
Slonie
Slonie's Avatar
Drives: Only ridiculous cars
Hell, I've heard a wiring harness is $1800 at Toyota and $360 at Subaru. Now I'm going to have to always check both..
Slonie is offline   Reply With Quote
Old 03-15-2018, 10:24 PM   #8
dnieves
Somebody should start a thread listing which dealership (Toyota/Subaru) has a particular part cheaper with both part numbers (apples to apples comparison).
Here's the first entry:
Antifreeze: Toyota Super Blue #00272-GTBC1 $27.29-$28.43/Subaru Blue Super Coolant #SOA868V9270 $21.78-$25.20
Old 03-16-2018, 01:43 AM   #9
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Op's stated car is 2015 FRS blue with 49,000 miles, bought used.
Opinion: Screw German cars, Japanese built are the worlds best at the moment, so enjoy your purchase.
Personal >>opinion<<, choice:
I drive a 2015 FRS blue with manual trans and currently 54,000 miles on it. Bought new.
I use Mobil One full synthetic 0W20 from Walmart...whichever Mobil One they have in stock. Comes in 5 quart container, not enough as car takes 5 1/2 quarts. So cheapest in the long term is to buy two 5 gallon containers, as buying a one quart container is expensive. Save remainder of container for next oil change. Always change oil at 7500 mile intervals.
Former auto tech here. The crush washers come in copper or aluminum. Guess what, one crush washer works for numerous oil changes.
I buy oil filter at Subaru Dealership if available, if it's a Sunday, oh well, get Fram's absolute best (Ultra ?) at Walmart.
I plan never to change oil in trans or diff as there's just no combustion in those areas.
I ain't gonna have the car like forever.
I may change the spark plugs somewhat after the 60,000 mile interval suggested. I think/hope I can do it myself with the exact, proper tools, leaning over the fenders and not jacking up the engine...we'll see.
Coolant change maybe after like five/ten ? years, and I'll use Prestone extended life concentrate 100%. (Buying the 50/50 mixtures is a total ripoff). Don't need blue color, screw that b.s. Green Prestone works just fine. Note: I've already added Prestone several times as this car eats coolant, mysteriously.
ToySub1946 is offline   Reply With Quote
Old 03-16-2018, 02:20 AM   #10
extrashaky
Drives: 2014 BRZ Limited
It's not a bad idea to go ahead and buy a jug to keep on hand. With other vehicles, if you need coolant on a Sunday you can just pop into Auto Zone and pick up a jug of yellow. You can't do that with our vehicles. If you need to top off, you have to find a dealer to get blue coolant.
Fram filters should only be used in vehicles that you hate and are trying to kill. The media has a reputation for collapsing and causing oil starvation, and the anti-drain back valves have been known to fail. It's like hating your children, so you buy the toothpaste at the dollar store with Chinese script on the label hoping you get the kind sweetened with antifreeze.
Old 03-16-2018, 10:17 AM   #11
Face_Plant
Face_Plant's Avatar
The oil filter we tried to get from NAPA for my buddy's '15 WRX with the 2.0 was incorrect. We tried looking it up by application, interchanging the part number from the Subaru filter, looking it up in paper catalogs, etc, but every time the filter was way too small. I'd go this route if I could since I used to work at my local NAPA and they still give me a discount on stuff, but since my FR-S basically has the same motor without the turbo/related bits, I'm assuming that the filter they try to sell me will be wrong too.
So far it hasn't been a bad decision. I definitely miss the noises and power my VR6 turbo made, but the FR-S seems like a much higher quality and more reliable car.
I'm used to that from the VW world, so that's nothing new to me and won't be hard to get used to. VW's take special everything and it was only available online or at the dealer. Special coolant, special bolts, etc...
Old 03-17-2018, 02:43 AM   #12
extrashaky
It's not the same filter, and you're making this more complicated than it should be. For the FR-S and BRZ, you can look up the filter number yourself on the Wix website. I just did it, and it said to use filter 57830. Here's a thread where someone installed a 57830 and took pics:
http://www.ft86club.com/forums/showthread.php?t=17321
Looks right to me.
Wix filters are sold at Napa under the brand "Napa Gold." They just drop the first digit off the filter number. So a Wix 57830 is the same as a Napa Gold 7830.
You don't have to buy them from Napa, however. Rock Auto sells the Wix 57830 for $3.72 each (plus shipping). O'Reilly also carries them, but they're $9 each as opposed to less than $6 for the Napa Gold branded version.
Old 03-20-2018, 05:49 PM   #13
SuperSub7
Drives: Awesome
I order genuine OEM Subaru parts and accessories from https://www.subarupartsdeal.com/ and have them shipped quickly and conveniently to my door. This web page offers giant savings on the everything OEM Subaru and they are the first place I go to for Subaru parts. Hope this helps.
SuperSub7 is offline   Reply With Quote
Good OEM Subaru parts dealer online FRSHunter Hawaii 4 03-05-2014 01:17 AM
Dealer requests before BRZ pick up Maps316 BRZ First-Gen (2012+) — General Topics 24 09-22-2012 08:00 PM
2 BRZ Limiteds for $500 over Dealer Invoice - Pick your Color subaruofkeene Dealer Cars 2 09-16-2012 05:15 PM
Any BRZ/FRS online parts look up... Scott BRZ First-Gen (2012+) — General Topics 1 09-09-2012 07:09 AM
