Drives: 2015 Scion FR-S
Buy Parts Online and Pick Them Up At the Dealer?
I've only had my FR-S for a few weeks, so I'm still trying to get "caught up" on everything. In the VW world that I'm coming from there is a website where I can buy genuine OEM parts online, then pick them up from the parts department at the local VW dealer. You can search by name/part number, they have parts diagrams, etc. Is there anything like this for Subaru/Toyota?
I'm planning to replace the engine, trans, and rear diff oils since I don't know when or if they've ever been changed, so I need the crush washers and a filter. In the past when I've helped my buddy change the fluids in his '15 WRX the crush washers were impossible to find locally and the oil filter they tried to sell us was way too small. Since my FR-S basically has the same motor without the turbo, I'm assuming that I'll have similar issues trying to find the correct parts... |
#2 |
I just look up stuff here.
https://parts.subaru.com/Subaru__BRZ.html Then I call the local dealer on the phone. |
| The Following User Says Thank You to GrantedTaken For This Useful Post: | Face_Plant (03-14-2018) |
#3 |
Nobody has ever seemed to have an issue finding these parts.
If you have a couple of dealers check prices at each. Check both Toyota and Subaru since prices can vary substantially depending on what you are after.
#4 | |
Drives: FR-S 10 Series
Case in point: twins' special blue antifreeze is a lot cheaper at Subaru than at Toyota. |
| The Following User Says Thank You to dnieves For This Useful Post: | Face_Plant (03-14-2018) |
#5 | |
I live in a small red neck town, so if you aren't driving a Ford or Chevy truck, then there's a good chance that the parts store won't have anything in stock for it. Thanks, that's good to know for when it's time to replace the coolant. |
| The Following User Says Thank You to Face_Plant For This Useful Post: | Tcoat (03-15-2018) |
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I get WIX filters from the local NAPA autoparts store.
They can get crush washers too, but I replaced the plug with a FUMOTO valve. They also carry Eneos oil.
"I gotta rock." -- Charley Brown |
#7 |
Drives: Only ridiculous cars
#8 |
Somebody should start a thread listing which dealership (Toyota/Subaru) has a particular part cheaper with both part numbers (apples to apples comparison).
Here's the first entry: Antifreeze: Toyota Super Blue #00272-GTBC1 $27.29-$28.43/Subaru Blue Super Coolant #SOA868V9270 $21.78-$25.20 |
#9 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Op's stated car is 2015 FRS blue with 49,000 miles, bought used.
Opinion: Screw German cars, Japanese built are the worlds best at the moment, so enjoy your purchase. Personal >>opinion<<, choice: I drive a 2015 FRS blue with manual trans and currently 54,000 miles on it. Bought new. I use Mobil One full synthetic 0W20 from Walmart...whichever Mobil One they have in stock. Comes in 5 quart container, not enough as car takes 5 1/2 quarts. So cheapest in the long term is to buy two 5 gallon containers, as buying a one quart container is expensive. Save remainder of container for next oil change. Always change oil at 7500 mile intervals. Former auto tech here. The crush washers come in copper or aluminum. Guess what, one crush washer works for numerous oil changes. I buy oil filter at Subaru Dealership if available, if it's a Sunday, oh well, get Fram's absolute best (Ultra ?) at Walmart. I plan never to change oil in trans or diff as there's just no combustion in those areas. I ain't gonna have the car like forever. I may change the spark plugs somewhat after the 60,000 mile interval suggested. I think/hope I can do it myself with the exact, proper tools, leaning over the fenders and not jacking up the engine...we'll see. Coolant change maybe after like five/ten ? years, and I'll use Prestone extended life concentrate 100%. (Buying the 50/50 mixtures is a total ripoff). Don't need blue color, screw that b.s. Green Prestone works just fine. Note: I've already added Prestone several times as this car eats coolant, mysteriously. Last edited by ToySub1946; 03-16-2018 at 03:34 AM. |
#10 | ||
Drives: 2014 BRZ Limited
It's not a bad idea to go ahead and buy a jug to keep on hand. With other vehicles, if you need coolant on a Sunday you can just pop into Auto Zone and pick up a jug of yellow. You can't do that with our vehicles. If you need to top off, you have to find a dealer to get blue coolant. Quote:
Fram filters should only be used in vehicles that you hate and are trying to kill. The media has a reputation for collapsing and causing oil starvation, and the anti-drain back valves have been known to fail. It's like hating your children, so you buy the toothpaste at the dollar store with Chinese script on the label hoping you get the kind sweetened with antifreeze. |
#11 | ||
The oil filter we tried to get from NAPA for my buddy's '15 WRX with the 2.0 was incorrect. We tried looking it up by application, interchanging the part number from the Subaru filter, looking it up in paper catalogs, etc, but every time the filter was way too small. I'd go this route if I could since I used to work at my local NAPA and they still give me a discount on stuff, but since my FR-S basically has the same motor without the turbo/related bits, I'm assuming that the filter they try to sell me will be wrong too.
#12 | |
http://www.ft86club.com/forums/showthread.php?t=17321 Looks right to me. ![]() Wix filters are sold at Napa under the brand "Napa Gold." They just drop the first digit off the filter number. So a Wix 57830 is the same as a Napa Gold 7830. You don't have to buy them from Napa, however. Rock Auto sells the Wix 57830 for $3.72 each (plus shipping). O'Reilly also carries them, but they're $9 each as opposed to less than $6 for the Napa Gold branded version. |
#13 |
Drives: Awesome
I order genuine OEM Subaru parts and accessories from https://www.subarupartsdeal.com/ and have them shipped quickly and conveniently to my door. This web page offers giant savings on the everything OEM Subaru and they are the first place I go to for Subaru parts. Hope this helps.
| The Following User Says Thank You to SuperSub7 For This Useful Post: | Face_Plant (03-20-2018) |
| Good OEM Subaru parts dealer online | FRSHunter | Hawaii | 4 | 03-05-2014 02:17 AM |
| Dealer requests before BRZ pick up | Maps316 | BRZ First-Gen (2012+) — General Topics | 24 | 09-22-2012 09:00 PM |
| 2 BRZ Limiteds for $500 over Dealer Invoice - Pick your Color | subaruofkeene | Dealer Cars | 2 | 09-16-2012 06:15 PM |
| Any BRZ/FRS online parts look up... | Scott | BRZ First-Gen (2012+) — General Topics | 1 | 09-09-2012 08:09 AM |
