#15 |
#16 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
#17 | |
Drives: 2017 Ice Silver BRZ Limited
For example, is the it tapered (doesn't look like it)? How smooth is the transition between the runners and the silicone connectors? Are there smooth entries to the runners inside the plenums of both brands? Did they tell the truth about the TB diameter? Did they both measure in the same spot (at the TB butterfly)? How's the finish inside the runners? Does the shape change from the 45/48mm round TB to the oval-ish intake port result in an increase or decrease in cross-sectional area? By how much? The more data, the better AFAIC. So, win/win for measuring. |
#18 |
Can't wait for the data as this is a huge part of my planned build.
| The Following User Says Thank You to 86_IT For This Useful Post: | Trust86 (06-27-2018) |
#19 | |
Drives: RX-7 / BRZ
Not necessarily available but, the WELD FR-S had been running custom ITB's for a while. I'm posting as it may be useful in some way even if a bit light on specifications. I do believe it was removed as it was never correctly running.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | CSG Mike (02-05-2018) |
#21 |
Drives: ADM Toyota 86 GT
Any update on this? Super keen to see the results.
| The Following User Says Thank You to Snake For This Useful Post: | why? (03-01-2018) |
#22 |
real R&D (and progress) is slow.
It'll be months before any concrete results are published. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#23 |
I'll be waiting here anxiously!
#24 |
Drives: '15 BRZ RA
Subscribed.
#25 |
Only happy when it rains.
Drives: series.blue
it will be interesting to see what they offer. The sard one is being advertised for 3k on 86 worx. Can it really be worth that much money?
As cool as the idea is and as hopeful as I would be they would increase response, is this what the other kits are going to cost as well? |
#26 |
Drives: 2017 Toyota 86
If these ITB's can get me to ~220 wheel hp with the Ace a350 and e85 I think it would be worth it for me and my car and I would certainly order it. I think that's going to be more power than can be had out of these but I also have unreasonably high hopes.
| The Following User Says Thank You to Grimnor For This Useful Post: | SuperTom (02-05-2020) |
#27 |
Drives: 2017 BRZ
Agreed, I could see myself going ITB's in the future if this is the case
#28 |
It'll cost as much as a SC with that type of setup, but the throttle response will absolutely be superior...
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 683 | 06-07-2020 07:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 05:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 01:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 02:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
