#995 |
Drives: None
Much better link thanks!
#996 |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
As mentioned during the SSC Town Hall meeting, TR has created a central web page for SSC related topics that has just gone live:
https://www.tirerack.com/content/tir...s/SCCASSC.html Direct link to suspension install instructions: https://www.tirerack.com/tires/tiret...jsp?techid=338 Baseline Set-up Recommendations: https://www.tirerack.com/tires/tiret...jsp?techid=339
K. Casey | NER SCCA | SSC - '14BRZ For Sale
#997 | |
Drives: 2014 Monogram FR-S
Thanks! I had a shop install my set up and only knew about the roll bar settings. I did not know the shocks were adjustable. Can anyone explain that to me in more detail? I am nOOb Sent from my iPhone using Tapatalk |
#998 | |
2013 FR-S Whiteout / SSC
https://www.koni.com/en-US/Cars/Tech...stment-Guides/ The shocks have an adjustable rebound. Compression is not affected by adjustment. Make sure you got at least one of the adjustment tools back from the shop where you had the install done. |
| The Following User Says Thank You to Open Loop For This Useful Post: | JakeRogue (03-09-2018) |
#999 | |
Drives: 2014 FR-S
-Mike
#24 CS/CSR |
| The Following User Says Thank You to TrqlessWonder For This Useful Post: | JakeRogue (03-09-2018) |
#1000 | |
I found the adjusters. But I wonder was this black thing is: ![]() Sent from my iPhone using Tapatalk |
#1001 |
Drives: DS FRS
The black thing is just a protective adjustment knob condom for packaging. Not needed when installed.
-Max H.
| The Following 2 Users Say Thank You to blkwrxwag For This Useful Post: | JakeRogue (03-09-2018), TrqlessWonder (03-12-2018) |
#1002 | |
I am interested in whether anyone has observations regarding the baseline alignment recommendations. Does anyone recommend any different settings based on their own initial experience? Thank you. Edit: I am looking for the best baseline settings for autocross on a smooth asphalt course, and not concerned about additional tire wear or darty steering on highway. Last edited by Open Loop; 03-09-2018 at 08:25 PM. |
#1003 |
Another question for y'all. Per the installation instructions at the Tire Rack website:
After the alignment is completed. The steering angle must be re-calibrated for the OEM stability control to operate normally. If this is not done, the stability control may interfere with performance driving scenarios. For this particular vehicle, the steering angle was -3.2 degrees off until re-calibrated. How is this re-calibration performed? Thank you. |
#1004 | |
Drives: None
https://demos.starbase7.net/t3Portal..._rm_index.html 1. ROTATION ANGLE SENSOR INITIALIZATION AND TORQUE SENSOR ZERO POINT CALIBRATION NOTICE: Initialize the rotation angle sensor and calibrate the torque sensor zero point if any of the following conditions occur: The power steering ECU is replaced. The steering column assembly is replaced. Steering effort differs between turning left and right. HINT: When rotation angle sensor initialization and torque sensor zero point calibration are performed, the rotation angle sensor value initialization and the torque sensor zero point calibration are performed at the same time. (a) Inspection before calibration (1) Turn the ignition switch off. (2) Connect the Techstream to the DLC3. (3) Turn the ignition switch to ON. (4) Turn the Techstream on. (5) Enter the following menus: Chassis / EMPS / Data List. (6) Check the values by referring to the table below.
'16 FR-S SpecFRS.com
#1005 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My second set of wheels won't be here in time for Dixie and my current set of Falkens are well into the wear bars after more than 100 runs. In the dry, they are *still* well-behaved, serviceable tires, but on the wear bars, they were pretty much useless in the wet.
I'll mount the new tires for Dixie, but I want to keep these old ones, mount them on the new wheels, and do some back-to-back testing once I get the new ones to 50-ish runs, just to try and quantify how resilient these tires are. I think the Falkens were a great choice for a spec tire. |
#1006 |
Drives: '15 STX
Mine are done and maybe have 10 runs left in them. They're slicks, basically. Any I got about 120-130 runs out of them, which was about the same as the RE71R/Rivals. A little disappointed given their performance. At least they're cheaper.
#1007 | |
Drives: 2013 FRS White w/ cone marks
Other than that.... looks good. I'm currently running zero rear toe, but I think their suggestion of 1/8" total toe in is probably more drivable for most people.... but... I like a loose car.
#1008 | |
Bring out your dead
--kC
| The Following User Says Thank You to Imp For This Useful Post: | Shark_Bait88 (03-12-2018) |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 02:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 10:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 12:20 PM |
