Drives: 2013 WRB BRZ 6MT
Driver side window/switch issue
Just to start things off, this has nothing to do with cold temperatures/ice/etc. I am aware of the switch reset process, the problem is that the drivers side switches go into fault mode (flashing, no control of passenger side, loss of one touch function on drivers side) just about every time the drivers side window moves, including the movement from opening/closing the door.
The biggest problem this is causing is that when I go to get out the window either goes all the way down (open) when it is supposed to move that little bit, or when it moves that little bit back up when I close the door it closes all the way and then proceeds to open all the way. My door was off when it was recently repaired, so I thought maybe the harness isn't plugged in properly, or the switch assembly was somehow damaged, but it resets normally so I am thinking it might be something inside the door (I reset my ECU last night, no change). Are there sensors or anything in there that might have gotten out of line when they had it apart? |
#2 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | MRCA1ST (03-01-2018) |
#3 | |
Drives: 2013 BRZ Sport-tech WRB
MCRA1ST, if you roll the window halfway down and open/close, can you get the window switch to go into fault mode, or only when it is trying the tiny window trim clearance maneuver? |
#4 | |
Yeah, it goes into fault mode with just about any movement. It actually got worse over the weekend, the switch for the drivers side is basically non-responsive, unless I push it in conjunction with the passenger switch, then it can get the window moving - but I haven't been able to get it to reset. It is going to the shop that did the repair tomorrow, hopefully they can figure it out. |
#5 |
Shop pulled the panel, didn't see anything out of line, put it back together and now everything is working fine. It has been tested throughout the day and is not faulting. They said if it comes back they will order a new switch but they don't know what else it could be.
| Driver Side Window Issue | kevinchavarria | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-27-2016 12:28 PM |
| Driver side window/lock switch issue | xoBethxo | Electronics | Audio | NAV | Infotainment | 3 | 04-01-2016 01:09 AM |
| wtb:Window visors, shark fin, fog lights, switch backs, clear side markers | Vincenttam | Want-To-Buy Requests | 13 | 06-28-2014 05:02 PM |
| There is a new window switch available to fix the passenger auto up/down issue | Subie | Issues | Warranty | Recalls / TSB | 51 | 04-13-2014 03:34 PM |
| Driver window issue? Off track? | s14sleepyeyez | Issues | Warranty | Recalls / TSB | 7 | 06-07-2013 09:19 PM |
