Old 03-03-2018, 12:39 PM   #15
Jasonb
Drives: 17 Series Yellow BRZ
It’s not exactly a quiet car
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
why? (08-11-2019)
Old 03-03-2018, 02:01 PM   #16
MyGT86Yas
Drives: 2017 WRB BRZ
People here say it’s the throttle body and it’s normal.
MyGT86Yas is offline   Reply With Quote
Old 03-03-2018, 03:35 PM   #17
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by evoto86 View Post
metalic noise when say you're cruising in 3rd or 4ths below 3krpm you let off the gas for a second, give it a tap to pick up speed but as soon as you do you hear a noise which sounds like two metal rods making contact.
I've notice the exact same thing (2017 BRZ). But it doesn't make it all the time. I thing it's pretty rare actually.
It seems to come from the back of the car. I tought maybe it's a thing call differential backlash, where you have a little "play" in the differential gears (something normal), and that going from compression to acceleration the gear make that noise. But it could also be from the muffler. Even tough it's a mettalic sound, I feel like it could be some kind of rapid pressure change in the muffler.
nico_rsx is offline   Reply With Quote
Old 03-04-2018, 04:22 AM   #18
number_Un0
Drives: 2013 FRS 10 series #0001
OP, I'm pretty sure my car makes the same sound your talking about. Mine's been doing it for 20K+ miles and no issues so far.
Don't let noises and rattles scare you. I'd be more worried if my car didn't make any weird noises.
number_Un0 is offline   Reply With Quote
The Following User Says Thank You to number_Un0 For This Useful Post:
alone1i (09-03-2020)
Old 03-10-2018, 04:22 AM   #19
evoto86
Drives: manual Toyota 86
from reading the comments i feel better about it, its probably nothing. If something breaks in the next 3 years i got warranty so will see.
evoto86 is offline   Reply With Quote
Old 03-10-2018, 03:20 PM   #20
next time it's doing it, try rolling on the throttle slowly. Does that help?
tip-in knock.
Pretty hot these days?
Spuds (03-10-2018)
Old 08-09-2019, 01:45 PM   #21
Tek
Drives: 2017 BRZ with Performance Package
Sorry to revive an old thread but I’m having a similar issue. I also hear a squeaking sound as I’m applying throttle after shifting but it sounds more of a rubbery squeak. Here is my video of a metallic scratching sound as I jab the accelerator.
Tek is offline   Reply With Quote
Old 08-09-2019, 03:36 PM   #22
That sounds like tip-in knock. Bad mojo. What kind of engine mods do you have?
Old 08-09-2019, 04:13 PM   #23
Decep
Drives: 2013 FR-S Series 10
Guess my hearing sucks, cant hear anything in that video.
The Following 2 Users Say Thank You to Decep For This Useful Post:
humfrz (08-09-2019), why? (08-11-2019)
Old 08-09-2019, 05:14 PM   #24
OwlDance
Drives: Halo 86, '19
What RPM are you cruising at when you're jabbing the throttle and giving it the beans? I notice it pretty much doesn't happen above 3k at least on my car. Sub 2.5K I can cause the tachometer to waver on demand if I jab the throttle and you can feel the car slightly buck; not good. Engine hates getting anything more than light throttle under 2.5k. Pretty sure it's tip in knock.
OwlDance is offline   Reply With Quote
Old 08-09-2019, 05:42 PM   #25
Tek
I think I was cruising around 2500+ rpm.
As for engine mods, I have a Perrin inlet hose and a blitz air filter. I’m a also running a cat-less front pipe with GReddy Supreme SP catback. Other than that, it’s stock.
Old 08-09-2019, 07:14 PM   #26
MilkyWitness
Drives: fdsgh
asdf
MilkyWitness is offline   Reply With Quote
Old 08-09-2019, 07:50 PM   #27
My stock engine has tip-in knock under certain conditions. I haven't yet caught it on logs but hope to on my next highway trip. It only happens during a long cruise when I apply throttle too quickly after a long period of mode-4 (fuel cut) operation, for instance, like leveling out after a long downhill.
It's really disturbing so I've learned to apply throttle slowly in those cases. Sometimes I forget. The sound is soul-crushing.
alone1i (10-02-2020)
Old 08-09-2019, 08:17 PM   #28
Tek
Soul-crushing sums it up perfectly.
The Following User Says Thank You to Tek For This Useful Post:
Ultramaroon (08-10-2019)
Weird sound over 60mph FRiSson Issues | Warranty | Recalls / TSB 23 03-05-2018 12:47 PM
Brief Scratching/squeal sound. Accelerating/change gears. resli Issues | Warranty | Recalls / TSB 13 03-02-2016 01:56 AM
metallic sound coming from engine when accelerating! jaorocks1 Issues | Warranty | Recalls / TSB 4 05-02-2015 11:32 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 04:37 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 07:06 AM
