Old 02-21-2018, 12:56 PM   #3515
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
10 kg/mm up front is too stiff. You don't need that much front spring IMO. And too much front spring bias.
It can feel fast, but a softer set up will be easier to drive, more consistent over different types of surfaces, have a better balance, and be more comfortable as a DD.
- andrew
Thanks Andrew! I tried to find out the TRD spring rates but the best I could find was 3.5/5.8
Should I Shoot for this ratio on the coilovers say 4.8/8 for example or am I comparing apples to oranges.
I would think that stiffer springs on the front would not help understeer tendencies on the FRS
My biggest fear is going backwards by upgrading to coil overs.!
rick s is offline   Reply With Quote
The Following 2 Users Say Thank You to rick s For This Useful Post:
Racecomp Engineering (02-21-2018), Shark_Bait88 (02-21-2018)
Old 02-21-2018, 01:57 PM   #3516
The same ratio at different overall levels of stiffness won't get you the same overall balance. Different tires or grip levels can change the balance too.
There is to some extent some driver preference but you'll have to spend some time dialing in all of the variables....ride height, alignment, shock settings, swaybars, and spring rates. The 7/7 or 7/8 are popular starting points for springs in STX, but there are plenty of other ways to go too.
- Andrew
Racecomp Engineering is online now   Reply With Quote
rick s (02-21-2018)
Old 02-21-2018, 02:01 PM   #3517
Originally Posted by 86league View Post
My '13 BRZ is mostly track use, but some street with ~300+ mile drives to some of the tracks so I want to keep it street friendly.
I'm on RCE yellows, stock shocks/sways - camber bolts and plates up front with SPC LCA's out back to get to -3.5F/-2.4R with 0F / 1/16in R toe. SX2 (200TW) tires, rest stock.
Tires are now wearing relatively uniformly across the tire with this camber setup (MPSS shoulder's absolutely got killed at very similar camber). No consistent reading on tire pyro after I drive off track and back to the pits (cools off a lot) - but nothing that looks bad either -- so I can mostly only go by wear for now...
Pictures from the track show a lot of roll ... e.g. http://www.hart-photography.com/phot...#image=4111227 -- inside front tire contact patch looks to be at 1/3 width or less in lots of the turns.
Will stiffer sway bars improve my cornering traction significantly, or just a little? I think the real answer would be stiffer springs, but that means shocks too so I'm into coilover money... not wanting to go there yet...
I like the car as is and am having fun and tire wear with the SX2's is good across the tire - getting ~10 track days out of a set with proper rotation... But, I kind of like to tinker, and if a (relatively) cheap set of sway bars would improve things a fair amount I am willing to try them...
Also - would stiffer sways mean I'd likely need to (get to) dial out some of the static camber?
Thanks !
If you like the way the car is handling now, I'd be hesitant to change anything! That body roll might not be holding you back all that much. Another season of building experience with a car that does what you want it to do and is reliable/consistent is valuable.
Buuuutt...I like to tinker too. Swaybars would reduce body roll and you may be able to reduce your negative camber slightly. Keep in mind most front + rear swaybar sets will increase front roll resistance more than rear due to the motion ratio of the swaybars. So you may have to fiddle with the alignment to get things just the way you want them.
- Andrew
Old 02-22-2018, 02:19 AM   #3518
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
This likely to be a stupid question, but when you set the front negative camber, is there any thought to compensating for the weight of the driver or whether you have to compensate for right or left hand turns. What I mean by that is, I think some people are more likely to take more speed into a left hand turn as a posed to a right hand turn while daily driving.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 02-22-2018, 03:38 AM   #3519
churchx
churchx's Avatar
Drives: 2014 GT86
FLYFISHR: if one is being very pedantic, then yes, very "ideal" alignment for specific use/location/track may take into account of there being or not passenger, of track being clockwise or counter-clockwise. Then there also is corner balancing/alignment if one has height adjustable coilovers. But imho these tweaks are into category of where one can spend 90% of time for 10% of gain, so unless it's for highly-competitive racing where every slight extra advantage counts, i wouldn't bother. If anything, you may ask to deal alignment while you are sitting in car.
FLYFISHR (02-22-2018)
Old 02-22-2018, 03:45 PM   #3520
Foxy Grandma
Drives: 2016 CWP BRZ
Would you guys recommend your Tarmac springs be paired with the Bilstein B6 or B8? I've seen reviews of people who have gone either way with good results.
Foxy Grandma is offline   Reply With Quote
Old 02-22-2018, 03:59 PM   #3521
You could go either way, but I would prefer the B6.
- Andrew
Old 02-22-2018, 04:43 PM   #3522
Pat
Pat's Avatar
Drives: 2023 BRZ
FWIW, I spoke with someone at Bilstein about this and they said B6 is preferable, but both would work fine.
The Following User Says Thank You to Pat For This Useful Post:
Racecomp Engineering (02-22-2018)
Old 02-23-2018, 11:56 PM   #3523
sato
sato's Avatar
Drives: Dodge Patitas
Any particular reason why B6 over B8, and why?
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 02-24-2018, 12:10 AM   #3524
Pat
Pat's Avatar
Drives: 2023 BRZ
I think there is just a longer shaft, which allows for more droop travel. Andrew would probably be able to confirm or deny this.
Old 02-24-2018, 12:51 AM   #3525
jamal
jamal's Avatar
Drives: Legacy GT
Yes, definitely. Firstly, it is better to corner balance and align a car as close to the way it will be driven as possible. So with the driver in the seat or an equivalent weight there, plus maybe 1/2 tank or less fuel, all the extra stuff out of the interior, race wheels and tires on, etc.
As far as changing the alignment from left to right, that depends on the specific track and driver. You usually figure this out by measuring tire temperatures, but if you were on, say, an oval track, obviously you would want more negative camber on the outside wheels.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
FLYFISHR (02-24-2018)
Old 02-24-2018, 01:21 AM   #3526
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
B6 is cheaper.
B8 offers less droop travel which can help short springs stay under pressure when the car is lifted off the ground but offer no other advantages.
With some google-fu you can find the specs someone posted on this forum.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (02-24-2018), sato (02-24-2018)
Old 02-24-2018, 04:27 PM   #3527
H1C
Drives: 2014 FR-S MT
Interesting. When I spoke with someone at Bilstein USA tech support about a year and a half ago about which shock to get for RCE Tarmac springs, he told me the exact opposite. I told him the RCE's spring rates and expected drop. In fact he was quite insistent that, for any spring that is shorter than OEM length, I should get the B8s. So that's what I did.
H1C is offline   Reply With Quote
Old 02-24-2018, 05:11 PM   #3528
new2subaru
Weight Weenie
Drives: 15 FR-S
Maybe they were out of B6's
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
