#71 |
Drives: 2017 WR BLUE BRZ
Improved racing oil cooler thermostat/remote oil filter. Using a larger mobile 1 oil filter M-210A. Used an existing 12mm bolt hole to mount it.
| The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | DustinS (01-30-2018), Sportsguy83 (01-30-2018) |
#72 |
Update on the headers and exhaust
http://www.ft86club.com/forums/showp...4&postcount=11 Looks like I might get this thing built and runner sooner than expected! Some of the headers parts. Ultimate headers flanges ![]() Burns Stainless merge collectors 1 7/8” to 2 3/4”x3” transitions. ![]() ![]() ![]()
| The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | DustinS (02-05-2018), Sportsguy83 (02-08-2018) |
#73 |
Headers are coming together nicely.
| The Following 6 Users Say Thank You to ILLSMOQ For This Useful Post: | Draco_PR23 (02-23-2018), DustinS (02-07-2018), gtpvette (02-08-2018), mkivsoopra (02-08-2018), Sportsguy83 (02-08-2018), Zer0 (02-07-2018) |
#74 |
Drives: '13 Whiteout FR-S (M/T)
@ILLSMOQ is the hammering of the trans tunnel absolutely necessary for the Vorshlag kit? Having read their R&D posts on the kit, I don't recall reading that (while they made a big deal of how avoiding such measures were essential for a "production" kit).
Thanks for your documentation - I'm sure this will be very informative in the future!
#75 |
Drives: 2013 Ultramarine FR-S
Yes it is required in a few spots. You also have to cut a bit more out that they don't show.
#76 | |
#77 |
Drives: 14 BSP Edelbrock BRZ
Any concerns with cooking stuff in the steering linkage? (I don't know if there are bushings around there or not).
There is still room to get the keeper bolt out to remove the steering shaft? |
#78 | |
I Love custom Turbo kits
Drives: Limited BRZ
#79 | |
![]() As for the heat. I removed all the fuel lines from the factory location and even moved the two brake lines up as high as possible....covered them in heat shielding and my exhaust will be ceramic coated by swaintech. The steering joint...I don’t know how well it can handle the heat but I don’t have my header primaries wrapped too tightly around it and with the ceramic coating...I don’t think I will have any heat issues. ![]()
| The Following 4 Users Say Thank You to ILLSMOQ For This Useful Post: |
#80 |
Drives: 2014 BRZ
This build is fantastic. Love how clean and organized the bay is. Job well done. Excited to see it run.
#81 |
Thanks! Me too! Getting super close! I have to finish the headers, pie cut and weld up the rest of the exhaust...then I can ship them off to coating. During that wait I’ll finish up all the other lines and wiring.
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Sportsguy83 (02-24-2018) |
#82 |
Drives: 2013 FRS Whiteout
Looking great!
To comment on the trans tunnel topic, You haven't lived until you've made room for a TH400 lol |
| The Following 3 Users Say Thank You to Pure Automotive For This Useful Post: |
#83 |
Long story short. I wasn’t crazy about how the exhaust turned out. It was hung to low killing my ground clearance. I’m re-doing the exhaust...then I noticed some things on the headers I didn’t like....and I went on vacation.
Back at it, I took the headers apart to fix the things I didn’t like, slag and weld beads inside the tubes, primary tube ends not all the same length, which would have given me exhaust leaks for sure and one of my burns stainless merge collectors was modified in a way I didn’t like (I sent it back to Burns while I was on vacation to be repaired) Final trim on the headers to get all the tubes to seat into the collectors is done. Now I need to do the final weld on the collectors and head flanges...then finish the rest of the exhaust ![]() ![]() ![]()
#84 |
Drives: 2014 Subaru Forester
I'm sure that will sound just as nice as they look.
| The Following User Says Thank You to tehShirt For This Useful Post: | ILLSMOQ (03-04-2018) |
| Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 12:10 PM |
| Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 01:07 PM |
| Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 07:11 PM |
| Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 12:32 PM |
| Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 03:07 PM |
