Old 02-16-2018, 11:13 AM   #1
The owl Talon
Steering wheel modification with cruise control
Ok, so i've been thinking of replacing my steering wheel, but in doing so i'll be losing cruise control. This is my daily car and I'll be going off to college and taking long road trips to and from. I found a sparco steering wheel that has buttons for a horn, but I was wondering if anyone knew if it was possible to wire the cruise control to have the off/on to the left button and the speed set on the right one. Anything is appreciated!
The steering wheel - https://www.sparcousa.com/product/l999
The owl Talon is offline   Reply With Quote
Old 02-16-2018, 11:20 AM   #2
It would require a pile of work with a whole new harness and clock spring pickups. May be possible but not something I would tackle lightly.
Old 02-16-2018, 11:25 AM   #3
I suggest you re-think that plan and focus on your studies ......
Plenty of time for complex mods once you've completed your education.
What are you going to study in college ...??
Old 02-16-2018, 11:55 AM   #4
The owl Talon
I'm studying kinesiology, then going to med school to become a flight surgeon in the USAF. Should be fun.
Old 02-16-2018, 12:04 PM   #5
hichamaziz
Drives: subaru brz
hi thank you for your help
hichamaziz is offline   Reply With Quote
Old 02-16-2018, 12:28 PM   #6
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Bet you could find yourself an avionics tech at your first duty station that could hook you right up for a case of beer.
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Tcoat (02-16-2018)
Old 02-16-2018, 12:29 PM   #7
Sounds interesting. I had to look that up .....I thought I could figure out most of the "ologies" ...... but, not that one.
Is the USAF going to support your college expenses .......??
Old 02-16-2018, 12:32 PM   #8
Well studying kinesiology and plans to become a flight surgeon would lead me to believe that you understand the benefits of retaining your airbag in a street driven car. Especially if you are planning long trips.
Brayden_23 (02-16-2018), PeterFRS (02-16-2018), spike021 (02-16-2018)
Old 02-16-2018, 12:46 PM   #9
e1_griego
e1_griego's Avatar
Drives: Many
+1 not worrying about it while you're in school.
However, all you need to do to is make a plate to bolt the cruise stalk to and then just plug it in.
http://www.ft86club.com/forums/showthread.php?t=95873
e1_griego is offline   Reply With Quote
Old 02-16-2018, 12:51 PM   #10
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
as cool as aftermarket steering wheels are and considering its your daily i would just get one of those cooler oem wheels from various vendors. probably end up cheaper and would contain cruise control and an airbag
JustSomeGuy is offline   Reply With Quote
The Following User Says Thank You to JustSomeGuy For This Useful Post:
Tcoat (02-16-2018)
Old 02-16-2018, 12:58 PM   #11
extrashaky
Drives: 2014 BRZ Limited
You can keep your stalk and make a bracket.
http://www.ft86club.com/forums/showthread.php?t=78397
Other people have relocated their cruise functions to the dash somewhere. Personally, if I did it, I'd pull out the heated seat buttons in the center console and make a custom three button panel to replace it, then run the cruise control there.
But then again, I wouldn't put that fugly steering wheel in my car. I would use one of the many OEM-style options instead.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (02-16-2018)
Old 02-16-2018, 01:14 PM   #12
All this steering wheel talk reminds me of the time I bought my 16 year old son a POS starter car. As, with all the kids, I'd tune up the car, put new tires and brakes on them .....then they were on their own.
So, we pulled the POS into the garage and pulled the brakes off it. I sent my son up the automotive store to buy brake shoes for the front and rear. He came back with a "racing steering wheel" ...... and no brake parts, because they didn't have them in stock.
I promptly sent him back to return the steering wheel and go to another automotive store for the brake shoes ...... SMH
The Following 4 Users Say Thank You to humfrz For This Useful Post:
JustSomeGuy (02-16-2018), spike021 (02-16-2018), Spuds (02-16-2018), Tcoat (02-16-2018)
Old 02-16-2018, 01:36 PM   #13
PetrolioBenzina
Drives: 17 86
OP will spend much time in a flight suit, needs to ditch the wheel for a stick or yoke.
Old 02-16-2018, 01:46 PM   #14
Or never, ever even see the inside of an aircraft much less fly around in one.
"Flight" surgeon is more of a position title then a job description.
sparco, steering wheel
Cruise Control with Aftermarket Steering Wheel **SOLUTION** pleong Electronics | Audio | NAV | Infotainment 13 07-04-2023 07:31 PM
Cruise control bracket for aftermarket steering wheel rx3 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-08-2021 12:26 AM
How do you keep cruise control with aftermarket steering wheel??? kylefrs Cosmetic Modification (Interior/Exterior/Lighting) 32 04-06-2016 05:58 AM
Cruise Control with Aftermarket Steering Wheel **SOLUTION** pleong Cosmetic Modification (Interior/Exterior/Lighting) 7 10-06-2015 07:41 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 07:17 AM
