| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2017 BRZ
You're replacing the crush washer in the drain plug? If no, chance that's the cause. First see how much oil drains... But I'm in the camp of "it's low"
#16 |
If you weren't planning on changing the oil, just add a qt. and check again.
If same, repeat. |
#17 | |
Drives: 2015 BRZ Limited
#18 |
[insert cool phrase here]
Drives: BRZ Premium
Your low bro.
Or on an unlevel surface. That's only two (possible) reasons why you can't read your dipstick
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#19 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
..in my experience checking the oil level through the dipstick for the twins is pretty hit or miss, kinda just tells you whether there's oil or not.. if you know how much you put in on the last oil change and you know there isn't a leak then i wouldn't be too worried and take that dipstick reading as good.
#20 |
The SquadWhisperer
Rub dipstick with scotchbrite.
Run engine for 5 min. PARK ON LEVEL GROUND. Shut engine off, pull dipstick. Let sit for 3 minutes. Insert dipstick, pull out dipstick Read both sides, lowest side is right.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#21 | |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
My recommendation for you here is to get the Fumoto valve, and send a sample to Blackstone for analysis when you do change the oil.
| The Following User Says Thank You to mjanmohammad For This Useful Post: | BirdTRD (02-15-2018) |
#22 |
#23 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If you're really serious about ferrous metals in the oil,
get some neodymium magnets to put on the outside of the oil filter. It all gets stuck in the filter and you can re-use them on the next filter.
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | Cole (02-15-2018), SmaxxSmith (02-17-2018) |
#24 |
I installed one on every single car I owned and it makes oil changes a breeze, and way less messy. Pro tip for the BRZ though, get the one without the nipple, I believe its the "s" designation for short. The nipple sticks out below the metal cover and gets hit by debris.
#25 | |
#26 | |
#27 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#28 | ||||||
Drives: FR-S 10 Series
![]() Allright, here's the verdict. I swapped the oil out last night. There was still quite a bit in there, but I'm sure we'd all agree it's considered low for these cars. I had about ~4.8 qt drain out and it was pretty dark. There were no signs of leaks whatsoever. I took off the under panel and there wasn't single drop to be found. I guess these cars just eat oil? My driving habits: DD, no track use, daily stop-n-go commute both ways in LA traffic so I don't even get to open it up all that often, but I do drive "spiritedly" on the weekends when there's less traffic. I could count on one hand how many times I've taken it to redline. I WAS checking my oil often after my first change but will admit it's been a good 4-5 weeks since the last time I looked. I know, I know, shame on me. Life just got in the way. I guess considering how much oil was missing, I might cut my oil change intervals in half. I was going by the recommended 7500 mile interval, but it was 5k since my last change and it looks like it was overdue. Also going to add the Fumoto Drain Valve to my wishlist for the next change since I'll be doing them more often. I did like the Greddy Mag Plug while I used it, but seeing that there was no gunk on it this time, quicker swaps seem like the better deal. I also experimented with the dip stick a bit more since I knew it was full. I can get a proper reading now, but it's not consistent. I still get oil only showing on the edge sometimes, following the exact same steps. I'm going to look into reviews before buying FT86SF's dip stick. I usually shop from them the most, but that dip stick just seems way overpriced. Thanks for all the help everyone! I didn't want to seem like a total noob since this isn't my first oil change, but this flippin dip stick had me stumped.
| What can I stick this onto... | GhostRai | Other Vehicles & General Automotive Discussions | 28 | 07-05-2017 07:24 PM |
| dip stick dilemma | notout86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 04-15-2015 06:52 AM |
| I should stick to my bicycle | SeanBlader | Northern California | 1 | 11-18-2014 01:09 AM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 02:10 PM |
| Car Name; Reason why FT-86 won't stick | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-17-2011 01:52 PM |
