Old 02-14-2018, 06:45 PM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
You're replacing the crush washer in the drain plug? If no, chance that's the cause. First see how much oil drains... But I'm in the camp of "it's low"
Old 02-14-2018, 06:57 PM   #16
GrantedTaken
If you weren't planning on changing the oil, just add a qt. and check again.
If same, repeat.
GrantedTaken is offline   Reply With Quote
Old 02-14-2018, 07:18 PM   #17
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
pricey for what it is, but i've been thinking of getting it anyway because reading the stock dipstick kind of sucks
JeremyR is offline   Reply With Quote
Old 02-15-2018, 01:48 AM   #18
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Your low bro.
Or on an unlevel surface.
That's only two (possible) reasons why you can't read your dipstick
Old 02-15-2018, 02:05 AM   #19
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
..in my experience checking the oil level through the dipstick for the twins is pretty hit or miss, kinda just tells you whether there's oil or not.. if you know how much you put in on the last oil change and you know there isn't a leak then i wouldn't be too worried and take that dipstick reading as good.
HKz is offline   Reply With Quote
Old 02-15-2018, 07:56 AM   #20
Thorpedo
The SquadWhisperer
Rub dipstick with scotchbrite.
Run engine for 5 min.
PARK ON LEVEL GROUND.
Shut engine off, pull dipstick.
Let sit for 3 minutes.
Insert dipstick, pull out dipstick
Read both sides, lowest side is right.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 3 Users Say Thank You to Thorpedo For This Useful Post:
Beachin86 (02-15-2018), BirdTRD (02-15-2018), Tcoat (02-15-2018)
Old 02-15-2018, 11:40 AM   #21
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Originally Posted by Beachin86 View Post
I almost bought that drain valve but I wasn't sure if it was magnetic. I like to see how much metal has built up, so I have a magnetic drain plug (no valve).
As far as FT86SF's dip stick, from what I can tell it just has a button that relieves the pressure caused by the O-Ring. I think unscrewing the oil fill cap has the same effect, but I'm no expert. It also seemed a bit overpriced for a dip stick, so I didn't give into it.
you shouldn't be seeing a significant amount of metal on a magnetic drain plug at all. 90% of the FA20 engine is non-ferrous metals so they aren't magnetic.
My recommendation for you here is to get the Fumoto valve, and send a sample to Blackstone for analysis when you do change the oil.
mjanmohammad is offline   Reply With Quote
The Following User Says Thank You to mjanmohammad For This Useful Post:
Old 02-15-2018, 12:31 PM   #22
ermax
ermax's Avatar
Originally Posted by mjanmohammad View Post
Fumoto valve
Had to google that and obviously had to buy one. Hahaha.
Thanks for the tip!
Old 02-15-2018, 01:26 PM   #23
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If you're really serious about ferrous metals in the oil,
get some neodymium magnets to put on the outside of the oil filter.
It all gets stuck in the filter and you can re-use them on the next filter.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Cole (02-15-2018), SmaxxSmith (02-17-2018)
Old 02-15-2018, 02:22 PM   #24
mjanmohammad
Thanks for the tip!
I installed one on every single car I owned and it makes oil changes a breeze, and way less messy. Pro tip for the BRZ though, get the one without the nipple, I believe its the "s" designation for short. The nipple sticks out below the metal cover and gets hit by debris.
Old 02-15-2018, 02:31 PM   #25
ermax
ermax's Avatar
I read a review on Amazon that it sticks out 3-5mm past the engine cover on the FRS. So I went with the SX that has the really short nipple. I thought about going without a nipple but I live right off a river so the wind rips at my house most days and makes a mess when changing the oil. Hopefully the stuby version doesn't come past the cover.
Old 02-15-2018, 02:37 PM   #26
mjanmohammad
My workaround is a clear flexible plastic tube that fits snugly around the end of the valve without a nipple, and doesn't interfere with the valve switch operation. drain that straight into my oil receptacle.
Old 02-15-2018, 04:15 PM   #27
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
F108S for the win!
BirdTRD is offline   Reply With Quote
Old 02-15-2018, 04:17 PM   #28
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
@Tcoat page
Bring in the cavalry! XD
I did do this on the last change but almost forgot those need to be changed as well. Picked one up from the dealer last night. Thanks for the reminder.
If same, repeat.
The problem with this is not knowing how much was in there. I was scared of overfilling, so I just swapped it out.
I DID have a bit of gunk buildup on the OEM plug when I swapped it out. I did all my fluid swaps first thing when I got the car. This is now my second oil change, and no gunk on the new drain plug. I would send in the oil but I'm lazy and overwhelmed with work to put in that effort.
Interesting, never heard of this one but it makes sense. Would this restrict the oil flow?
That's a shame, I love nipples.
Allright, here's the verdict. I swapped the oil out last night. There was still quite a bit in there, but I'm sure we'd all agree it's considered low for these cars. I had about ~4.8 qt drain out and it was pretty dark. There were no signs of leaks whatsoever. I took off the under panel and there wasn't single drop to be found. I guess these cars just eat oil? My driving habits: DD, no track use, daily stop-n-go commute both ways in LA traffic so I don't even get to open it up all that often, but I do drive "spiritedly" on the weekends when there's less traffic. I could count on one hand how many times I've taken it to redline. I WAS checking my oil often after my first change but will admit it's been a good 4-5 weeks since the last time I looked. I know, I know, shame on me. Life just got in the way.
I guess considering how much oil was missing, I might cut my oil change intervals in half. I was going by the recommended 7500 mile interval, but it was 5k since my last change and it looks like it was overdue. Also going to add the Fumoto Drain Valve to my wishlist for the next change since I'll be doing them more often. I did like the Greddy Mag Plug while I used it, but seeing that there was no gunk on it this time, quicker swaps seem like the better deal.
I also experimented with the dip stick a bit more since I knew it was full. I can get a proper reading now, but it's not consistent. I still get oil only showing on the edge sometimes, following the exact same steps. I'm going to look into reviews before buying FT86SF's dip stick. I usually shop from them the most, but that dip stick just seems way overpriced.
Thanks for all the help everyone! I didn't want to seem like a total noob since this isn't my first oil change, but this flippin dip stick had me stumped.
Beachin86 is offline   Reply With Quote
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 06:24 PM
dip stick dilemma notout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 04-15-2015 05:52 AM
I should stick to my bicycle SeanBlader Northern California 1 11-18-2014 12:09 AM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 01:10 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 12:52 PM
