Old 02-10-2018, 08:01 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Most reliable catback exhaust?
Had a long discussion with some tuners and decided i dont want to go UEL/FD not until ive mastered the car’s limits stock at the track. But since im itching for better sound and cover the artificial cabin sound generator, id like to settle with a quality exhaust that should last pretty much as long as OEM as i plan to stick with this for the car’s lifetime. Im just talking on quality since ive heard inividias eventually “burn out”. Any suggestions?
leevanf is offline   Reply With Quote
Old 02-10-2018, 08:14 AM   #2
15limited
15limited's Avatar
I'm not sure how an exhaust will "burn out", unless you're referring to like... muffler packing? You can't really go wrong with any reputable catback, essentially the most basic exhaust component since it doesn't involve any sensors and has little impact on performance. More or less comes down to sound , build quality/fitment, stainless or titanium, and of course price. It will be Be very hard to fit a suitable catback to work with an oem header and also an aftermarket one down the road. I'd personally recommend an axleback muffler delete until you begin upgrading other components upstream. They're pretty cheap and the Nameless, that's the company name, trackpipe I used sounded great with the stock header.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-10-2018, 08:32 AM   #3
Teseo
Drives: frs
Cant go wrong with perrin products. If you add UEL will sound neat. For cabin sound you can add inlet house to the engine
Old 02-10-2018, 08:36 AM   #4
leevanf
leevanf's Avatar
Ive read some posts on people saying the q300 eventually loses its bass rumble and sounds rattle can after long use. Will there be any drawback to an axleback muffler delete? Maybe i can buy an extra muffler for 100 usd and keep my stock
Old 02-10-2018, 08:55 AM   #5
15limited
15limited's Avatar
It will be louder, and you wont have a muffler?way lighter than oem too, With the stock everything else I don't think it will be too raspy.
Old 02-10-2018, 11:00 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Amuse makes a pretty good one for us. Lightweight and durable.
If you can swallow the price.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 02-10-2018, 11:22 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Almost any of the exhausts using a large suitcase style muffler will work. Get stainless and roll on. If you don't want a packed muffler there is corsa and flowmaster.
Old 02-10-2018, 12:58 PM   #8
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I’d suggest looking at some of the JASMA certified exhausts, as the certification specifically refers to maintaining noise suppression at a specified level over time due to the breakdown of muffler or silencer packing. I have a Blitz Nür Spec R stainless steel exhaust that’s JASMA certified and sounds great with my ACE 4-2-1 Type-A 350 equal length header, although it will be on the quiet side if the rest of the exhaust is stock. The only possible downside is that it’s a single exit exhaust, which may not be the look you want. Good luck!
RJasonKlein is offline   Reply With Quote
Old 02-10-2018, 01:24 PM   #9
RJasonKlein
Here are a few pictures of the exhaust on and off the car:
Last edited by RJasonKlein; 02-10-2018 at 02:46 PM. Reason: Corrected a typographical error.
Old 02-10-2018, 10:51 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Nur Spec R is quiet? Got any sound clips with your set-up? And are you stock FP?
Old 02-11-2018, 02:53 AM   #11
RJasonKlein
Yep, in my opinion it’s very tame. My system consists of an ACE 4-2-1 Type-A 350 equal length header, Motiv catted front pipe, and the Blitz Nür Spec R stainless steel exhaust, and there’s no drone and conversation is easily held at any RPM. At full throttle it’s got a great bark and a refined sound, but I suspect without the header it would be extremely quiet. I don’t have any clips of the car running through gears and it’s been put away for the winter, but maybe I can shoot something for you in the spring.
Old 02-12-2018, 02:18 PM   #12
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We have the CSG Touring86 Exhaust that has been on boosted cars seeing over 300WHP without any degradation over the past 2.5 years of heavy track use.
CounterSpace Garage is offline   Reply With Quote
Old 02-12-2018, 02:24 PM   #13
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I'm a huge fan of the Nameless Axelback myself. With stock header and front pipe, the tone is nice and focused, good rumble and zero drone. Not super loud if you go with the 5" mufflers but can get pretty loud if no mufflers. Low rasp as well.
Nameless is also an incredibly reputable company that makes quality parts.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 02-12-2018, 02:40 PM   #14
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I second that 😎. Perrin rock solid.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Exhaust J2 quad tip catback vs tsudo catback! Cris_chavez1 Engine, Exhaust, Transmission 0 05-09-2017 08:36 AM
Catback - perrin 2.5 catback exhaust (non resonated) vs greddy sp supreme Raychee Engine, Exhaust, Transmission 11 05-26-2016 11:24 AM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
HKS Catback Exhaust Group Buy - Legamax Premium Exhaust & Hi-Power Spec L Catback FT-86 SpeedFactory Groupbuys 11 10-21-2012 08:59 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
