Old 02-08-2018, 11:04 AM   #15
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Originally Posted by BigTuna View Post
Just raise them up and soften the damping. If that's not enough then swap them out. You'd actually probably make a profit selling them and buying stock coilovers.
FWIW, I've driven through Detroit a few times maxed on Flex Z's with no issues. Granted, it wasn't the comfiest ride on Michigan roads..
Pretty much what I was going to say. '13 stock suspension is pretty stiff for DD in the first place. I can't imagine that on the softest setting the Flex Z's would be any stiffer.
Th3rdSun is offline   Reply With Quote
Old 02-08-2018, 11:06 AM   #16
PSim
Drives: BRZ or FR-S (soon)
You think? I feel like by by the time I pay for labor and an alignment I might not come out ahead.
PSim is offline   Reply With Quote
Old 02-08-2018, 11:27 AM   #17
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Hey, if you end up getting this car I'm located in Chicago and will have a set of Koni Sport shocks with stock '13 springs and strut mounts (so full strut assemblies) for sale soon, they have ~15k miles on them.
Swapping suspension shouldn't be too difficult for you since everything is complete, and the coilovers should sell for pretty much the same as I'd be asking for the Koni setup (possibly a bit more). So it'd be pretty much a break even for you, just be the cost of your time to swap the suspension and price of an alignment. Shoot me a message if you're interested.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 02-08-2018, 12:41 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by PSim View Post
I thought the spring rates weren't adjustable. I'd read the stock FR-S spring rate is 2.3K (front) and 3.8K (rear), whereas the Flex Z's have a spring rate of 6K.
All spring rates are adjustable:
1. Take apart coilover
2. Replace spring
3. Reassemble coilover
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
finch1750 (02-08-2018), Tcoat (02-08-2018)
Old 02-08-2018, 01:28 PM   #19
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I got a set of stock struts and springs for sale
Lunatic is offline   Reply With Quote
Old 02-08-2018, 01:36 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Just remember, the most important question about aftermarket coilovers is whether you have the ability to inspect/maintain them every month or so.
Adjustments means that there are more things that can come apart. Loose spring perches or lower brackets are normal from usage, so it's one more thing to keep on top of.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
ImAdopted (02-08-2018), strat61caster (02-08-2018), Tcoat (02-08-2018)
Old 02-08-2018, 01:51 PM   #21
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
2. Replace spring
Doesn't mean the valving adjustment range will be able to cope with it though
Old 02-08-2018, 01:54 PM   #22
You would have to go really, really, different for the valving to be so far off that it won't be able to cope with a different spring rate.
Old 02-08-2018, 01:57 PM   #23
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
is that pretty easy to check for? what else are required steps for maintain them? im conflicted between coils or spring/shock combo
ImAdopted is offline   Reply With Quote
Old 02-08-2018, 02:54 PM   #24
finch1750
finch1750's Avatar
Most entry level coils are over damped to start with though so going softer could happen. BC, Feal, etc need a few more clicks off stiff to not bounce but then they run fairly rough. I'm sure they could easily handle a fair bump up in spring rate though. Don't know about the Flex Z specifically though
Old 02-08-2018, 03:02 PM   #25
If you want adjustability then coil overs.
If you want to set and forget then spring/shock combo (still coil overs)
Old 02-08-2018, 03:04 PM   #26
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
im in a pickle cause i want to be able to adjust it but also dont know how i can maintain and look for things loose or broken lol
Old 02-08-2018, 03:08 PM   #27
mav1178
mav1178's Avatar
Most people forget that the OEM hardware is supposed to be replaced after you break them loose. The bolts/nuts have a locking mechanism on them, usually in the form of a lock nut.
It's really no different than checking things in your engine bay... you take off the wheel, inspect suspension for any loose bolts, anything that has moved since the last time you checked, etc.
The OE bolts always have some paint on them out of the factory, it's because this is part of the safety/inspection as they complete assembly. A general rule is, if you want to keep your car running well, you should do something similar by marking spring perches so you can visually see movement.
Some more high-end coilovers have fancy locking perches, but that does not mean movement is prevented. At the end of the day, what you put in is what you get out of them.
(For what it's worth, many people often complain about "poor handling" after weeks/months of use of cheaper coilovers. Sometimes it's just because the spring perches are loose... )
Old 02-08-2018, 03:12 PM   #28
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
ah okay gotcha, i mean i could try out the coils and then just learn as i go with what part is what and what i should watch out for lol. i will have to bookmark this thread for future assistance/reference if need be lol thanks
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 12:34 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
