Old 12-30-2016, 01:31 PM   #155
teotl
Drives: fr-s
Does anyone have the part # for BRZ Limited dash harness?
teotl is offline   Reply With Quote
Old 07-19-2017, 06:55 PM   #156
dezmoondo
dezmoondo's Avatar
Drives: Whiteout FRS
i bought the parts over a year ago to do the swap and stopped mid way while making the harness. I remember I am missing one connector and some pins still. Where did most people source out their connectors and pins? I know some go to the junkyard.
dezmoondo is offline   Reply With Quote
Old 09-28-2017, 03:55 AM   #157
dezmoondo
dezmoondo's Avatar
@sly is it possible to have the temperature to show for both passenger and driver when doing single temp set up?
Old 09-28-2017, 10:53 AM   #158
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
On the Climate panel, it shows the temp on both sides that it is set at. As long as the driver side is the only temp switch to be changed, it will change both. If you move the passenger temp switch, it switches to dual mode and nothing will happen. I can get a video if you would like.
Old 09-28-2017, 01:16 PM   #159
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Yes. This is how it normally works. Both sides show the temperature setting and show the same value as long as you don't have the 'dual' toggle selected. Setting dual unlocks the 2 temperature settings so that you can control the driver and passenger side independently. Without 'dual' selected, you just control both sides by the driver's side knob.
sly is offline   Reply With Quote
Old 09-28-2017, 01:28 PM   #160
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
So what I'm hearing is that there is still no harness that anyone has made that I can buy... I will continue to hold out hope for this.
Sent from my E6883 using Tapatalk
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 09-28-2017, 11:48 PM   #161
dezmoondo
dezmoondo's Avatar
@DustinS @sly
I am glad you guys are still active on the forum. I am trying to be lazy and not even gonna bother wiring a connector for passenger temp sensor and passenger servo.
In the second picture that @sly posted for the single temp set up, I don't see the passenger's temp showing on the display, hence I want to ask if it will work.
Old 10-08-2017, 10:40 PM   #162
sly
sly's Avatar
I'm not sure it it will work or not. The only time it shows one temperature is when defrost is selected. All other settings show 2 temperatures. If 'dual' is selected, the temperatures will be different. If 'dual' is not selected then they both show the same temperature.
If you select defrost, the passenger temp goes blank and you control it with the driver temp knob only.
Old 11-26-2017, 03:58 AM   #163
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Originally Posted by lextrueno View Post
I have time now to sit down and start working on making multiple harnesses. I first have to go and build one for myself. But once that is done I will be sure to message you when I have a solid product.
Looking forward to an update!
Sent from my SM-G935W8 using Tapatalk
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 02-07-2018, 11:53 AM   #164
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Originally Posted by Chaetagnath View Post
Most of the important information is already in this thread leading up to the single temp install. With the posted PDF files, the info for dual is there now too. ......
Did you all the engine coolant or just topped off whatever leaked out?
Thank you.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 02-07-2018, 04:16 PM   #165
FRSToyota86
I purchased a BRZ limited Dash harness, thinking it would have most connectors, but there were only 3 connectors on there that fit. Basically it was a money thrown in garbage and a learning experience since returns were not accepted.
I ended up using connectors that I ordered.
Old 02-07-2018, 05:58 PM   #166
Chaetagnath
Thank you.
Just topped it off.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
FRSToyota86 (02-07-2018)
Old 02-07-2018, 06:03 PM   #167
Chaetagnath
Thank you.
Just topped it off.
Old 02-15-2018, 03:29 AM   #168
FRSToyota86
Thank you @Chaetagnath, @phanguy, @DustinS. I was able successfully execute a fully functioning Dual Climate control swap.
The Following User Says Thank You to FRSToyota86 For This Useful Post:
DustinS (02-15-2018)
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 05:11 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 07:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 11:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 09:52 PM
