Old 02-02-2018, 10:11 PM   #1
brazy
brazy's Avatar
Drives: '14 LR BRZ Limited
OEM shocks going out?
Looking for some guidance before I go to the dealership with this issue:
I replaced the stock Primacys with some Bridgestone Potenza 980 A-S (on the stock wheels) at about 40,000mi on the odometer.
I've gotten to almost 50,000mi now and the front tires both have cupping on the inner half of the tread. The passenger side is more noticeable than the driver side, but both have the issue.
I'm wondering if this is an indicator that the OEM shocks are about finished. The ride has gotten slightly more noisy and jarring in the egregious road conditions of Northern Virginia over the past 2-3 months. I had plans to lower the car this summer anyways, so in a way I'm hoping that the factory shocks ARE the problem. Just want to know if anyone has had this experience or has any insight into the problem.
My plan is to, first, have Subaru inspect the suspension components. Then, if they don't find anything I will get an alignment. I have already confirmed that tire pressure is good, and the mounting and balancing was done correctly.
Anything else I should look for, check myself, etc. before this plan of action? Any input is appreciated.
brazy is offline   Reply With Quote
The Following User Says Thank You to brazy For This Useful Post:
humfrz (02-03-2018)
Old 02-02-2018, 10:35 PM   #2
Teseo
Drives: frs
2L;DR
Get alignment
Old 02-03-2018, 03:21 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
This should help.
http://http://perfectcircletire.com/images/tirewear.png
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (02-03-2018)
Old 02-03-2018, 03:35 AM   #4
You have been awful helpful here lately ........ are you low on used civics ....??
Old 02-03-2018, 03:38 AM   #5
Sounds like a good plan......
Old 02-03-2018, 04:02 AM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Aww you know...I'm just trying to be nice. Cause heaven forbid I tell these kids my honest dislike for tow straps and I cause bloody physical and emotional harm to them because of words they read.
But civic sales are good, had a friend of mine trade in his frs for a new Turbo accord. He lives in up in Seattle so I can't really get to joy ride with him. But he says it's a little beast on the freeway.
And now as to not totally de-rail the thread,
In my experience i seen with center cupping is over inflated tires. For the longest time my moms car would eat tires like crazy. The problem was she bought those cheap stick type tire pressure gauge. The gauge was off by 15psi and her alignment was off. Lol.
humfrz (02-03-2018)
Old 02-03-2018, 05:26 AM   #7
ermax
ermax's Avatar
When you say inner I assume you mean inner edge of the tire. If so, front toe is off. Bad toe can eat a set of tires extremely fast.
The Following User Says Thank You to ermax For This Useful Post:
brazy (02-08-2018)
Old 02-03-2018, 08:07 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Toe wont cause cupping. That'd be a feathered even wear pattern. It's not camber either because that'd cause even wear on the shoulder of the tire. Cupping is common on trucks, but not cars. It could be several emergency braking lock ups- but that's a stretch too.
There's some damage or it could be simple tire imbalance (but if it was that bad, you'd feel it). It could be a blown damper, but there's other things it could be too. Get it up on a rack and check out the front suspension.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
strat61caster (02-03-2018)
Old 02-03-2018, 03:06 PM   #9
ermax
ermax's Avatar
I assume he is describing something like this which is definitely toe.
Old 02-05-2018, 10:28 AM   #10
brazy
brazy's Avatar
Mine are not center cupping... its happening on the inner half - starting from the inner shoulder and goes about 2 inches towards the center. The Primacys that were replaced had no abnormal wear so my first thought was improper balancing or wrong pressure. But I've double and tripled checked everything with the tires.
Yeah, I have no reason to believe I'm out of alignment. Previous tires wore normally and the car isn't lowered. Not saying it's impossible that I need an alignment, I just think it's more likely that I have an issue with the damper or some other suspension component. Just wasn't really sure exactly what to look for.
Old 02-05-2018, 12:24 PM   #11
Still need to rule out alignment since it is the number one issue that can destroy tires. Just because the last tires wore fine does not mean the alignment has changed. I would at least have it checked before trying to chase down suspension issues that may not exist.
Old 02-05-2018, 01:26 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
A good alignment check will inspect all the joints in the suspension for wear or damage (bushings, ball joints, arms/links for straightness, subframe, all the important nuts and bolts etc.) which would be the quickest way to narrow in on a problem. If a full suspension inspection returns nothing and the tires aren't out of round or unbalanced then I'd be thinking dampers, but usually you'll feel dampers go to shit before you see it on the tire wear, dampers can be spectacularly bad before impacting tire wear.
Had a buddy with some weird ride characteristics he was fully blaming on the transmission, turns out the rear subframe bushings were prematurely worn and that was found on the alignment rack. It didn't solve the issue but it certainly helped.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
brazy (02-07-2018), Tcoat (02-05-2018)
Old 02-07-2018, 04:19 PM   #13
brazy
brazy's Avatar
front right camber was out of factory spec. Don't have an exact figure yet as I'm still at work, but service advisor said it was just barely too negative. Will order camber bolts for front.. Hopefully that corrects the issue. I'll provide an update if it doesn't lol
Thanks to all for helpful input
EDIT: Correction now that I have the alignment figures from Subaru - Front Right toe was out of spec. Started 0.22 toe in, corrected to 0.04 but apparently that ever-so-slightly moved the camber out of spec. But assuming that alignment was the issue, toe-in was the cause. Cheers @ermax
Tcoat (02-07-2018)
Old 02-09-2018, 09:19 AM   #14
ermax
ermax's Avatar
As guybo pointed out, camber actually doesn't impact wear that much. Toe will though and .22 is a fair bit off.
TBH, when you said cupping I thought you meant concave on the inner edge which screams toe. But after reading guybo's post about balance I googled the term "cupping" and realized it was a term used for flat spots. That's when I posted that picture to show what my original interpretation of your report was. But you never confirmed if your tires looked like that. Anyways, glad you got it sorted.
WTB: Shocks ThucP Canada Classifieds 0 08-08-2017 09:47 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 09:31 AM
FS: OEM Shocks (SOLD) SuiSid3l Brakes, Suspension, Chassis 0 12-15-2014 02:39 PM
What shocks _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-31-2012 03:18 PM
