Old 01-19-2018, 04:42 AM   #29
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Lunatic View Post
Like I did.
Gosh, the last time I saw JPS on car was way back.. a Lotus Esprit.
Old 01-19-2018, 09:50 AM   #30
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I styled my car in the old John Player Special F-1 livery.
Lunatic is offline   Reply With Quote
The Following 8 Users Say Thank You to Lunatic For This Useful Post:
chaoskaze (01-19-2018), Dadhawk (01-19-2018), dattran86 (01-19-2018), JD001 (01-19-2018), Leonardo (01-19-2018), Lonewolf (01-19-2018), new2subaru (01-21-2018), StraightOuttaCanadaEh (01-19-2018)
Old 01-19-2018, 11:00 AM   #31
JD001
JD001's Avatar
Drives: Subaru BRZ
Very good. It reminds of the ole Hertz Mustangs. Similar stripes.
Old 01-19-2018, 12:50 PM   #32
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by gtengr View Post
I saw that model and I don't think it's detailed enough to check. I've already discarded the idea due to HVAC interference, but you realize the vent would be recessed under the back of the hood about 4 inches or so towards the front? And the CFD model doesn't consider the radiator airflow, which is the target of the venting. If airflow into the engine compartment is high enough, the firewall can create a high pressure zone too. I'm guessing that is what makes the hood dance at speed.
I haven't seen CFD, or tunnel testing, that did not show the cowl area as a high pressure zone. The turning of the air from a general horizontal, to more vertical direction, causes high pressure.
Granted, there are probably cases where something else is influencing it, and making it low pressure, but i have not seen it.
Old 01-19-2018, 02:23 PM   #33
plucas
plucas's Avatar
Drives: Subaru
This is true.
That area of the car is always higher pressure. I am sure there is a way to make it low pressure, but in general, that area is a terrible choice for evacuating air.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
Gunman (01-19-2018)
Old 01-19-2018, 05:15 PM   #34
gtengr
Drives: 2017 BRZ
Right, but it's nearly always modeled as the hood running into the windshield as if it's a simple obtuse-angled corner, ignoring the void area that is recessed towards the front of the car and under the rear of the hood. And the influence of an engine bay that has trapped a lot of air that wants to escape is also generally ignored. The Corvette example I pointed to earlier, while it is a different car, demonstrates that the high pressure area doesn't necessarily have to travel below the hood line and towards the front of the car. I'm not trying to say that I'm right, because I do understand your point. I just haven't seen enough to convince me it is 100% factual in this case.
gtengr is offline   Reply With Quote
Old 01-19-2018, 09:49 PM   #35
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Going back to your case, I have attached the same picture with some arrows to point out areas.
Red Arrow: Best for evacuation, lowest pressure
Orange Arrow: Good for evacuation, low pressure
Yellow Arrow: Worst place for evacuation on the entire hood. This location has the highest pressure and would result in the least productive evacuation. Likely air would actually make its way *into* the engine bay.
People reduce complexity on CFD models to aid in solving. There are industry standards (followed by OE's, privateers, and race teams) that are accepted because they do not result in incorrect results.
Hope that helps,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Gunman (01-19-2018)
Old 01-19-2018, 10:32 PM   #36
gtengr
Drives: 2017 BRZ
Hope that helps,
Eric
I agree, but my aim wasn't to investigate this as the best option. I was looking at is as a possible way to get "some" venting without cutting the stock hood or dealing with aftermarket hoods. Also, the theoretical vent location is not on the surface of the hood, it would be on flat vertical face under the rear of the hood, and recessed about 4" toward the front of the car as measured from the vertical plane at the back edge of the hood.
I don't mind if I'm wrong. I just don't think pointing to the pressure distribution on the top surface of the hood tells the full story, or that the underhood pressure isn't a factor.
Old 01-19-2018, 10:49 PM   #37
NRXRaptor
Originally Posted by Pat View Post
Defeats the purpose? What is the purpose?
To see the carbon weave. It doesn't sound like OP is making a literal race car, so the carbon is purely cosmetic. That's why I get carbon parts for my car
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Brink (01-20-2018)
Old 01-20-2018, 05:41 AM   #38
Kodename47
Kodename47's Avatar
Drives: UK GT86
May I put forward the Beatrush Underpanel. No cutting, modding or replcing of the bonnet required. Proven to work, might even add downforce if claims are correct. Pulls heat directly past and away from the manifold too. Only downside is that it's not cheap, but still cheaper than a modded or aftermarket bonnet.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-20-2018, 10:42 AM   #39
Lunatic
Lunatic's Avatar
I also thought that might be a good addition.
Old 01-20-2018, 11:01 AM   #40
Pat
Pat's Avatar
Drives: 2023 BRZ
For what it's worth, carbon parts can add functionality to street cars, too. To say it is "purely cosmetic" I think is selling carbon short. Maybe that's all he cares about, but true carbon parts bring more to the table than style, regardless of implementation or appreciation.
Old 01-20-2018, 11:08 AM   #41
makinen
makinen's Avatar
Drives: Toyota 86
Under hood pressure should be counted for the venting. Pressure difference really makes air move.
I did an experiment for the vent at the cowl area on 2016. With the help of a Gurney flap, at least it blows out some air. I guess a blocking vertical barrier that divides low pressure zone and high pressure zone could help more.
I know it cannot blow out as much air that hood vent can. But could be better than nothing.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
gtengr (01-20-2018), Pat (01-20-2018)
Old 01-20-2018, 11:19 AM   #42
makinen
makinen's Avatar
Drives: Toyota 86
Or do make your own like this, @gtengr .
HELP: hood pins/latches on carbon fiber hood scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2016 01:10 PM
Custom GT 300 hood vents/heat managment kuczynskika Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2015 01:00 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 11:52 AM
